java.lang.NoClassDefFoundError
esel
Post Tue May 01, 2012 6:35 pm
I know that this error has been posted a few times, but the solutions described there did not work for me.
I've downloaded to serviio (0.6.2) server and unpacked the files to /home/esel/serviio-0.6.2. When I try to run the server I get this message:
esel@esel-server:~/serviio-0.6.2> ./bin/serviio.sh
Exception in thread "main" java.lang.NoClassDefFoundError: org.serviio.MediaServer
   at gnu.java.lang.MainThread.run(libgcj.so.12)
Caused by: java.lang.ClassNotFoundException: org.serviio.MediaServer not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:/home/esel/serviio-0.6.2/config/], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
   at java.net.URLClassLoader.findClass(libgcj.so.12)
   at java.lang.ClassLoader.loadClass(libgcj.so.12)
I don't know why this happens. Is there something wrong with the classpath? I'm running openSUSE 12.1 and i'm quite new to linux.
If I try the same thing with sudo I get no reply, also when I try the serviio-console.sh to start the console.
esel
Post Thu May 10, 2012 6:10 pm
Re: java.lang.NoClassDefFoundError
Well it has been over a week now, and nobody replyed.
Is the problem too trivial?
Or is the problem to specific?
Or is it more likely that theres is something wrong with my installation?
Post Thu May 10, 2012 7:51 pm
Users browsing this forum: Baidu [Spider], Google [Bot] and 57 guests
