[SOLVED] Make DIVX files look like XVID
FrostyWinnipeg
Post Thu May 10, 2012 12:44 am
The LG BD645 Bluray player supports XVID files but not DIVX(No doubt LG saving a buck by not paying DIVX for the codec).
Is there a way that Serviio could be set up so that it could make the player play DIVX files? Sort of putting a fake face on the file :)
Post Thu May 10, 2012 9:01 am
Re: Make DIVX files look like XVID
FrostyWinnipeg wrote:The LG BD645 Bluray player supports XVID files but not DIVX(No doubt LG saving a buck by not paying DIVX for the codec).
Not yet, avi is delivered in native format, no change by serviio...
Do you try this : http://wiki.serviio.org/doku.php?id=avi4cc ?
Post Thu May 10, 2012 10:26 pm
unless a changed mime-type would work
Post Fri May 11, 2012 8:35 am
zip wrote:unless a changed mime-type would work
For example, edit serviio/config/profiles.xml file, on profile id=8 "LG TV"...
Change
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
by
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
or
         <MediaFormatProfile mime-type="video/x-ms-avi" name="">AVI</MediaFormatProfile>
then restart serviio services for each test.
FrostyWinnipeg
Post Sat May 12, 2012 4:31 am
That program worked :D
Return to LG
