accessing serviio db (derby) from remote
mbil74
Post Sat May 12, 2012 8:27 am
Hi.
I would like to enable network connection to derby db running on serviio (I would like to start a jdbc connection from another pc).
Can this be done? How? Is there a tutorial available?
regards.
Post Sat May 12, 2012 3:39 pm
Re: accessing serviio db (derby) from remote
I dont think it's possible as it's enbedded DB and doesn't run derby server. You'd have to access is locally only (by pointing the jdbc driver at the library folder)
mbil74
Post Sun May 13, 2012 7:53 am
ok... waiting for serviio to support mySQL, then... ;)
regards :)
jabrown0604
Post Wed May 16, 2012 9:08 pm
Could you map a network drive to the location of the db and the access it locally from the remote client?
We do this all the time at work for access databases.
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
KrisDech
Post Wed Dec 05, 2012 12:22 pm
http://db.apache.org/derby/docs/dev/getstart/ has a tutorial how to set up a server for a derby db
C:\Program Files\Serviio\library>java -jar %DERBY_HOME%\lib\derbyrun.jar server start
You can then acces the DB from e.g. the associated ij client using:
ij> CONNECT 'jdbc:derby://localhost:1527/db';
However this is only possble while Serviio Service is not running. While Serviio is running the database can not be mounted/changed from another program. Depending on your use case you might consider to copy the db to a sepeare folder and work on copied image.
Return to General discussion
