No profiles in Serviio
moles
Post Sat May 12, 2012 1:40 pm
I installed Serviio on my 2 laptops (one with Ubuntu 10.04, other with RHEL 6).
On Ubuntu everything is working great. On RHEL 6 I have problem with no profiles in Serviio (and also RHEL server can't be seen in Panasonic TV).
Log looks like this:
2012-05-12 15:38:04,736 DEBUG [ActionsServerResource] Action with name 'startServer' was requested
2012-05-12 15:38:04,737 INFO  [WebServer] WebServer starting on port 8895
2012-05-12 15:38:04,737 DEBUG [DiscoveryManager] UPNP device d527e9e3-bde1-300c-8dab-d8ebc157c4d5 (192.168.0.20) is available
2012-05-12 15:38:04,765 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-12 15:38:04,765 INFO  [EventDispatcher] Starting EventDispatcher
2012-05-12 15:38:04,765 INFO  [RendererSearchSender] Searching for Renderer devices
2012-05-12 15:38:04,765 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:38:04,765 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-12 15:38:04,765 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:38:04,765 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-05-12 15:38:04,806 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:38:04,807 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:38:06,611 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 15:38:10,768 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-05-12 15:38:16,611 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:38:16,613 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:38:18,418 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 15:38:25,084 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-12 15:38:25,084 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-12 15:38:28,419 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:38:28,420 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:38:30,224 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:10
And than it's repeating advertisement and nothing much. I've searched everywhere and I didn't find solution. Can somebody help?
Post Sat May 12, 2012 1:42 pm
Re: No profiles in servio
Can you stop the server, delete the log, then start the server up again, wait a few min and then post the log as it only loads the profiles during startup. May even be worth turning on detailed logging (see sig) before starting up the server.
Can you also confirm that your plugin.xml file is there and contains the profiles.
moles
Post Sat May 12, 2012 1:58 pm
Re: No profiles in Serviio
Of course. I'm using detailed log and everything looks like this:
2012-05-12 15:54:21,215 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-05-12 15:54:21,230 INFO  [MediaServer] ------------------------------------------------------------------------
2012-05-12 15:54:21,231 INFO  [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. 6a61243292ee)
2012-05-12 15:54:21,231 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-05-12 15:54:21,231 INFO  [MediaServer] http://www.serviio.org
2012-05-12 15:54:21,231 INFO  [MediaServer] Java 1.6.0-IBM Corporation
2012-05-12 15:54:21,231 INFO  [MediaServer] OS Linux amd64 2.6.32-220.7.1.el6.x86_64
2012-05-12 15:54:21,231 INFO  [MediaServer] File encoding: UTF-8
2012-05-12 15:54:21,232 INFO  [MediaServer] Headless mode enabled: true
2012-05-12 15:54:21,232 INFO  [MediaServer] User home dir: /home/mmalenda
2012-05-12 15:54:21,232 INFO  [MediaServer] Temp dir: /tmp
2012-05-12 15:54:21,232 INFO  [MediaServer] ------------------------------------------------------------------------
2012-05-12 15:54:21,312 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-05-12 15:54:21,351 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-12 15:54:21,359 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-05-12 15:54:22,323 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-05-12 15:54:22,324 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-05-12 15:54:22,326 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-05-12 15:54:22,327 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-05-12 15:54:22,328 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-05-12 15:54:22,329 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-05-12 15:54:22,330 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-05-12 15:54:22,331 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-05-12 15:54:22,332 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-05-12 15:54:22,333 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-05-12 15:54:22,334 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-05-12 15:54:22,603 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-12 15:54:22,667 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-05-12 15:54:22,881 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-12 15:54:22,881 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-05-12 15:54:23,028 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-12 15:54:23,029 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-05-12 15:54:23,119 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-12 15:54:23,120 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-05-12 15:54:23,258 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-12 15:54:23,259 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-05-12 15:54:23,340 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-12 15:54:23,340 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-05-12 15:54:23,386 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-12 15:54:23,387 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-05-12 15:54:23,583 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-12 15:54:23,584 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-05-12 15:54:23,599 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-12 15:54:23,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2012-05-12 15:54:23,775 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-12 15:54:23,775 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-05-12 15:54:24,058 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-12 15:54:24,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2012-05-12 15:54:24,186 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-12 15:54:24,187 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-05-12 15:54:24,313 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-12 15:54:24,314 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-05-12 15:54:24,407 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-12 15:54:24,409 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-05-12 15:54:24,427 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-12 15:54:24,429 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-05-12 15:54:24,491 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-12 15:54:24,492 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-05-12 15:54:24,517 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-12 15:54:24,518 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-05-12 15:54:24,604 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-12 15:54:24,605 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2012-05-12 15:54:24,644 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-12 15:54:24,645 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-05-12 15:54:24,753 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-12 15:54:24,754 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 21
2012-05-12 15:54:24,817 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-12 15:54:24,879 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-05-12 15:54:24,903 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-05-12 15:54:24,903 INFO  [Device] Created UPnP Device with UUID: d527e9e3-bde1-300c-8dab-d8ebc157c4d5, bound address: 192.168.0.20
2012-05-12 15:54:24,920 INFO  [PluginCompilerThread] Looking for plugins at /opt/serviio-0.6.2/plugins
2012-05-12 15:54:24,920 INFO  [PluginCompilerThread] Started looking for plugins
2012-05-12 15:54:24,923 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2012-05-12 15:54:24,926 DEBUG [ProcessExecutor] Starting ffmpeg
2012-05-12 15:54:24,967 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-12 15:54:24,989 INFO  [WebServer] WebServer starting on port 8895
2012-05-12 15:54:24,993 DEBUG [DiscoveryManager] UPNP device d527e9e3-bde1-300c-8dab-d8ebc157c4d5 (192.168.0.20) is available
2012-05-12 15:54:24,994 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-12 15:54:24,994 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-12 15:54:24,996 INFO  [EventDispatcher] Starting EventDispatcher
2012-05-12 15:54:24,999 INFO  [RendererSearchSender] Searching for Renderer devices
2012-05-12 15:54:24,999 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:54:24,999 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-12 15:54:25,001 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:54:25,011 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-05-12 15:54:25,058 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:54:25,059 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:54:26,865 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 15:54:31,017 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-05-12 15:54:36,867 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:54:36,870 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:54:38,676 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 15:54:48,677 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:54:48,681 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:54:50,486 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:17
2012-05-12 15:54:51,024 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-05-12 15:54:51,025 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-12 15:54:51,033 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-12 15:54:51,034 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-12 15:54:51,041 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-12 15:54:51,059 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-12 15:54:51,059 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-12 15:55:51,088 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-12 15:55:51,088 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-12 15:56:08,402 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:56:08,403 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:56:10,207 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-05-12 15:56:51,089 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-12 15:56:51,090 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-12 15:57:28,223 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.20, timeout = 0
2012-05-12 15:57:28,224 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d527e9e3-bde1-300c-8dab-d8ebc157c4d5
2012-05-12 15:57:30,028 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:10
I don't have plugin.xml file. Did you mean profiles.xml file? If yes it contains profiles as you can see in attached file.
profiles.xml
profiles.xml
(57.01 KiB) Downloaded 755 times
Post Sat May 12, 2012 2:07 pm
Yes sorry i ment profiles.xml
Ok so the server is loading them ok. Can you explain your problem in a little more detail, do you mean you have no profiles available in the console or?
Just for a sanity check, go to http://192.168.0.20:23423/rest/refdata/profiles and you should see a list of the profiles.
moles
Post Sun May 13, 2012 7:25 am
It's problem with connection between TV and Laptop with RHEL. After Serviio start I'm opening servioo-console.sh and when it's open there is an information that the server is running but there are no machines in "Renderer Profile". When I do the same thing on Ubuntu I can see my TV and I can choose profile for it.
Also when in my TV I can only see Serviio from Ubuntu and I can't see Serviio from RHEL. I think it's a problem with multicasting but I don't know how to solve it.
Users browsing this forum: No registered users and 49 guests
