Site Login's
Post Sun Mar 04, 2012 4:29 pm
Site Login's
I have a groovy which requires a site login to get an extended set of links.
Here is the login page http://www.ilive.to/login
Any suggestions on how to program this in a groovy?
I note the NHLgamecenter groovy seems to use httpbuilder to do this.
I don't know if User-agent can be used in this way.
Post Tue Mar 06, 2012 7:46 pm
Re: Site Login's
Anyone???
smmortazavi
Post Sat Apr 21, 2012 4:25 am
Re: Site Login's
I have done this in one groovy before and I share it here hoping it helps.
use login() method bellow first and after a successful login include login cookie ("PHPSESSID=$loginCookie") in all subsequent requests:
    def String login() {
     def url = "http://www.ilive.to/login"
     def userName="myuser"
     def paswd="mypass"
     String loginCookie = getCookie(url,"PHPSESSID");
     String loginResult = doPOST(url, "username=$userName&password=$paswd", "PHPSESSID=$loginCookie")
     return loginResult
     //If login is successfull make all other subsequent requests with the above cookie ("PHPSESSID=$loginCookie") to get the extended channel list
    def String getCookie(String _url, String cookieName) throws Exception{
        def headerName, rv = "Not Found";
        // creeating the url connection object
        URL url = new URL(_url)
        URLConnection urlConnection = url.openConnection();
        // checking for each headers
        for (int i=1; (headerName = urlConnection.getHeaderFieldKey(i))!=null; i++) {
            // if its set-cookie, then take it
            if (headerName.equalsIgnoreCase("Set-Cookie")) {
                String cookie = urlConnection.getHeaderField(i);
                String cName = cookie.split("=")[0];
                String cValue = cookie.split("=")[1];
                if (cName.equalsIgnoreCase(cookieName))
                 return cValue.replaceAll(";.*","")
        return rv;
    def String doPOST(String _url, String data, String cookie) {
        // Construct data
        def rv = ""
        URL url = new URL(_url);
        URLConnection conn = url.openConnection();
        conn.setRequestProperty("Cookie", cookie);
        conn.setDoOutput(true);
        OutputStreamWriter wr = new OutputStreamWriter(conn.getOutputStream());
        wr.write(data);
        wr.flush();
        // Get the response
        BufferedReader rd = new BufferedReader(new InputStreamReader(conn.getInputStream()));
        String line;
        while ((line = rd.readLine()) != null) {
            rv += line
        wr.close();
        rd.close();
    return rv
Post Sun May 13, 2012 5:54 pm
Re: Site Login's
I don't know how I missed your post, but thank you, its exactly what I was looking for. I'll try it and post back.
Return to Plugin development
