Jumpy playback on PS3 but not iPad
Evostance
Post Fri Apr 27, 2012 1:34 pm
When playing "some" media to my PS3 via Wireless, the playback is choppy like it can't buffer it (or its transcoding)
The files are AVI's and it stated the media was compatible with PS3 without the need to transcode - if i put it on a USB and play it on the PS3 it works fine.
However if i run xmbc on my iPad (wireless) it plays smoothly with no jumps etc. Switch back to the PS3 just to check and its still jumpy and stuttering.
I can't figure out what whether its the Network, Media or PS3. This has happened several times now
Post Fri Apr 27, 2012 3:45 pm
Re: Jumpy playback on PS3 but not iPad
Evostance wrote:The files are AVI's and it stated the media was compatible with PS3 without the need to transcode - if i put it on a USB and play it on the PS3 it works fine.
Please do not compare play a file over DLAN with playing a file over USB, its not the same PS3 firmware used.
Could you provide information about your avi file?
When you use xbmc, does the file is played in native format or transcoded?
Evostance
Post Fri Apr 27, 2012 5:51 pm
Didn't know that.
XMBC was native, no transcoding for this. Here's the MediaInfo for the file
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 1.74 GiB
Duration                                 : 1h 54mn
Overall bit rate                         : 2 168 Kbps
Writing application                      : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
Writing library                          : VirtualDubMod build 2550/release
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 3
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (MPEG)
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 1h 54mn
Bit rate                                 : 1 711 Kbps
Width                                    : 720 pixels
Height                                   : 304 pixels
Display aspect ratio                     : 2.35:1
Bits/(Pixel*Frame)                       : 0.326
Stream size                              : 1.37 GiB (79%)
Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
Codec ID                                 : 2000
Duration                                 : 1h 54mn
Bit rate                                 : 448 Kbps
Stream size                              : 368 MiB (21%)
Alignment                                : Split accross interleaves
Interleave, duration                     : 42 ms (1.00 video frame)
Interleave, preload duration             : 500 ms
Evostance
Post Sun Apr 29, 2012 7:51 am
Anyone?
guitman
Post Mon Apr 30, 2012 11:27 pm
I have a similar issue, high definition AVI files play choppy on my PS3 but play fine on my Bravia TV. Both my PS3 and Bravia are connected wireless. 720p mkv files play fine on PS3, 1080p are choppy.
Evostance
Post Mon May 14, 2012 12:13 pm
I assume nobody is really sure? Perhaps i'll put it down to internal wifi
Post Mon May 14, 2012 1:31 pm
This is your file format : AVI / MPEG4 Part2 AS@L5 720x304 XVID/ AC3
The only information I have about similar format supported by PS3 is:
DivX and VC-1 (WMV)
To play VC-1 (WMV) format files, you must go to (Settings) > (System Settings) and set [Enable WMA Playback].
Copyright-protected files or files that were encoded by using DivX 3.11 cannot be played.
No QPel, No GMC (No warppoints)
On 17 December 2007, firmware upgrade 2.10 was released for the Sony PlayStation 3, which included official DivX Certification. Firmware version 2.50 (released on 15 October 2008) included support for the DivX Video on Demand (DivX VOD) service, and firmware version 2.60 (released on 20 January 2009) included official DivX Certification and updated Profile support to version 3.11.[40]
Do you try to activate the DIVX (VOD) account on your PS3 ?
