hide empty directory (no playable media)
Xtream
Post Mon Jan 23, 2012 1:27 pm
i think that an option allowing to hide empty directory if there is no playable media in it would be usefull.
for exemple, "myStuff/holliday 1" folder contain only photos, and "myStuff/holliday 2" folder contains video and photos.
when i browse videos on my tv, i would like to see "myStuff/holliday 2" but not "myStuff/holliday 1" (because there's no videos in this folder).
when i browse images on my tv, i would like to see "myStuff/holliday 1" and "myStuff/holliday 2" because they both contain photos.
Post Mon Jan 23, 2012 1:47 pm
Re: hide empty directory (no playable media)
share each folder sperately then u can select in the console the correct types for each folder.
Post Mon Jan 23, 2012 4:33 pm
I think I was looking into this earlier and found it quite difficult to do, it would also slow down browsing in general.
pdneri
Post Sat Jan 28, 2012 11:44 am
I also strongly need this feature.
I have a parent folder with several child folders with both pictures and videos inside.
Some folders contains only pictures.
When I am browsing videos in this folder tree I don't want to see folders not containing videos.
I can't share folders separately because I often update and add new child folders and I don't want to update shares each time.
Just for yor info, twonky server works like this, hiding empty folders, and browsing doesnt't seem slow.
Post Sat Jan 28, 2012 5:58 pm
pdneri wrote:I also strongly need this feature.
share the child folders and not just the parent folder then.
Post Sun Jan 29, 2012 11:10 am
Twonky implements it its way, serviio different way. In the way serviio works it'd make browsing slower.
JeppeTh
Post Tue Feb 21, 2012 7:28 pm
Yes - this I really would appreciate as well. I think I tried about 3 other DLNA servers which all hides folders with children=0.
I think this is one of the best advantages with DLNA, i.e. possibility to browse only folders with video etc.
So please consider this again.
mbailey
Post Tue May 15, 2012 5:01 pm
I would also like to request support for this feature please.
I have a massive structure for all my photos with the occasional video files included.
When I look at the structure on my PC using Picasa I can just view the photos and videos together so no issue.
When I use Serviio and say the directories have both photos and videos it is really hard to find the videos as most of the directories are empty.
Having an option on Serviio to not show any empty directories would solve the problem.
grolschie
Post Thu Dec 06, 2012 7:25 pm
I too would like this feature for the video Folder view, if it can be done without a performance hit, please.
For example, if I add my entire iTunes music folder and there are a small number of music videos...
Return to Feature requests
