Web UI in PHP - support thread
npuser
Post Sun May 20, 2012 7:44 pm
Re: Web UI in PHP (revised)
I believe you can simply comment the line 126 per Mark... Here is previous post about the issue.http://forum.serviio.org/viewtopic.php?p=43658#p43658
NPuser
lmd
Post Mon May 21, 2012 2:09 am
npuser wrote:I believe you can simply comment the line 126 per Mark... Here is previous post about the issue.http://forum.serviio.org/viewtopic.php?p=43658#p43658
NPuser
Thanks for the suggestion - I'd searched but hadn't come across that post before.
I've now done as suggested, but am getting the following in the debug 'response' box:
<result>
  <errorCode>0</errorCode>
  <httpCode>200</httpCode>
</result>
I was just using www.google.com as the url this time as a test. The strange thing is, when I hit 'Add' nothing appears in the list. In the normal behaviour, does this appear before you hit the 'Save' button (like adding a local path - which works just fine on my set up)?
Thanks for the help!
Andy
mpemberton5
Post Mon May 21, 2012 2:21 am
NPuser
<result>
</result>
I was just using http://www.google.com as the url this time as a test. The strange thing is, when I hit 'Add' nothing appears in the list. In the normal behaviour, does this appear before you hit the 'Save' button (like adding a local path - which works just fine on my set up)?
Andy
Yep, an error code 0 states all was successful. Turn debugging off and you should be 100% now. Give it a whirl and let us know!
lmd
Post Mon May 21, 2012 5:48 am
This is very strange - I go to add the Online Resource, and then nothing appears when I hit 'Add' in the popup box.
Click 'Save' on the Library page and... nothing.
What is happening?
Thanks again for all the input! :)
lmd
Post Mon May 21, 2012 2:29 pm
mpemberton5 wrote:
NPuser
<result>
</result>
Andy
Mark - the thing is, I enter all of the details into the pop-up box and then click 'Add' and nothing appears in the Online Source library list. So saving the changes is going to give a successful result. It fails at the point of clicking the 'Add' button - is this a webpage problem or something I've not configured on my server?
Thanks for all the help - I appreciate you must be busy with work and doing this in your spare time!
Cheers,
Andy
mpemberton5
Post Mon May 21, 2012 5:21 pm
Cheers,
Andy[/quote]
Understood. I'm at work now so tonight I'll look at possible reasons and maybe even look at ways to do additional debugging. It is definitely a javascript issue on the client side since the table isn't getting updated after you click ADD. What browser do you use? Are you familiar with Chrome's development tools or FF's Web Developer add-on? Those tend to help with javascript errors.
lmd
Post Mon May 21, 2012 6:17 pm
I've tested this in Firefox, Chrome and Safari.
I've got Firebug in Firefox, is there another plugin I can use to check for Javascript errors?
Next thing to try is switch off my antivirus software. Will report back!
Cheers,
Andy
lmd
Post Mon May 21, 2012 6:27 pm
OK, I've tried all 3 browsers with my antivirus switched off (AVG up to date). No difference.
I've switched off Windows Firewall and tried again - still the same.
I checked through all of the JavaScript settings and everything should be good to go.
I have the latest version of Firefox as my main browser (12.0).
Hope this is helpful - thanks again!
Andy
lmd
Post Mon May 21, 2012 6:40 pm
OK, I've installed 'Web Developer' plugin for FireFox and I've come up with the following 'Warning' messages when using the library page to try and add an Online Source.
Timestamp: 22/05/2012 01:31:36
Warning: Use of getAttributeNode() is deprecated. Use getAttribute() instead.
Source File: http://mediabox/serviioweb/
Line: 0
Timestamp: 22/05/2012 01:31:40
Warning: Use of attributes' specified attribute is deprecated. It always returns true.
Line: 0
Timestamp: 22/05/2012 01:31:46
Warning: Key event not available on some keyboard layouts: key="c" modifiers="accel, alt"
Source File: chrome://browser/content/browser.xul
Line: 0
Warning: Key event not available on GTK2: key="u" modifiers="accel,shift"
Line: 0
Timestamp: 22/05/2012 01:31:51
Warning: Error in parsing value for 'background-repeat'.  Declaration dropped.
Line: 0
Timestamp: 22/05/2012 01:32:24
Line: 0
Is this what you need? There were quite a few minor warnings about the CSS, but I'm pretty sure this won't have anything to do with those.
Cheers!
Andy
lmd
Post Sat May 26, 2012 9:37 pm
Well, I've started again with a fresh install and come across the same problem.
Is there a security setting that might be affecting it in my browser? I've looked in FF and everything looks pretty 'open' including JavaScript.
If somebody has any clue it would be great! Also, if I could get a pointer to see if I can log the error that would also be handy.
Andy
lmd
Post Sat May 26, 2012 10:01 pm
I'm not sure, but I think this could be helpful - I had debugging on the page switched on at the time, so some might relate to that. But I've tried it again since and slightly different errors come up, but all relate to something not right with the JS.
[code]Timestamp: 27/05/2012 04:48:48
Warning: reference to undefined property j[d]
Source File: http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js
Line: 3
Warning: reference to undefined property i.nodeType
Source File: http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.17/jquery-ui.min.js
Line: 14
Warning: reference to undefined property a.nodeType
Line: 3
Warning: reference to undefined property a.selector
Line: 2
Timestamp: 27/05/2012 04:48:10
Warning: reference to undefined property this.tools[name]
Source File: chrome://firebug/content/bti/inProcess/browser.js
Line: 315
Warning: reference to undefined property b[l[ka](c / 6)]
Source File: http://www.google-analytics.com/ga.js
Line: 22
Warning: reference to undefined property b.dh
Line: [/code]
Is this helpful at all?
Cheers :)
mpemberton5
Post Sun May 27, 2012 10:01 pm
So I found the issue. It was related to having a blank list and attempting to add the first entry. The HTML section the javascript code was attempting to add to was non-existent. So I added the section regardless if there were any entries or not. I failed to add that in my testing.
Please go to the wiki (link in signature line) to download the latest. This update also includes the known issue with the erroneous line described in some of the previous posts.
Cheers to all,
Xmantium
Post Mon May 28, 2012 12:36 am
Hello Mark, have got a build ready for the upcoming v1.0? :)
zip has provided the documentation in the beta section
mpemberton5
Post Mon May 28, 2012 12:59 am
Xmantium wrote:Hello Mark, have got a build ready for the upcoming v1.0? :)
Going through it now. Also would like to integrate into serviidb.com. Lots of fun stuff to do. :)
qoolbox
Post Mon May 28, 2012 10:03 am
Hi
Does the WebUI v1.0.2 fix the UTF-8 indexing issue ? directories and files with special caracter like éàè... are not indexed actually
thanks
Third Party Thecus NAS Develloper
http://forum.thecus.com
http://www.tsuga.fr
lmd
Post Mon May 28, 2012 1:42 pm
mpemberton5 wrote:So I found the issue. It was related to having a blank list and attempting to add the first entry. The HTML section the javascript code was attempting to add to was non-existent. So I added the section regardless if there were any entries or not. I failed to add that in my testing.
Cheers to all,
Great news! Downloading now :)
Andy
lmd
Post Mon May 28, 2012 2:12 pm
Tested and works - I'm now a very happy man as my home media setup becomes nearly complete.
Waiting for payday for a 2TB hard drive, then it's nearly complete! A local computer shop sells a 'Cube Pro500' for about $60 which can fit another hard drive, which would go perfect in the bedroom with the TV in there...
Oh dear, what am I saying, these things are never complete! Damn my consumerist mind ha ha!
Thanks again Mark :)
Andy
mpemberton5
Post Mon May 28, 2012 2:35 pm
qoolbox wrote:Hi
thanks
Sorry, this definitely fell off my list somewhere. I did go back and find your original post on this shown below.
qoolbox wrote:Bugs confirmed :
- UTF-8 FIles are not display on the DLNA Client (but WEBUI turned in french display well the éèà characters, and localdef is well set in the NAS Environnement)
- adding files by browsing in the Shared Folder TAB doesnt work because interface seems to add a "/" at the end of the Path removing it manually, make it works
I fixed the trailing trailing slash. As far as UTF-8 files and directories, I've got some updates, but not sure if I'm able to test it 100%. Would you be willing to perform a test or two for me?
qoolbox
Post Mon May 28, 2012 3:05 pm
Sure i can test it...
is it the 1.0.2 that i must download ?
Thecus NAS Users will be very Glad of the update ;)
http://www.tsuga.fr
Xmantium
Post Fri Jun 01, 2012 2:58 pm
Mark im free next five day to test out anything we can do about the presentation save button bug QNAP NAS users are having.
qoolbox who has Thecus NAS somehow fixed the same bug issue somehow
He thinks just update PHP but QNAP does have a very close to the latest version of PHP part of the firmware
Users browsing this forum: Baidu [Spider], Google [Bot] and 11 guests
