Need hel with Directv Dvr
cubanoviejo
Post Mon May 21, 2012 3:17 pm
:( Need help. I’m new to this so forgive me if don’t give all the correct info.
I’ve two Directv HD dvr one is connected via wireless and the other one is wire direct to my router.
The wireless work fine the other gets an orange status and gets a message “unable to access media”.
I’m using windows 7 and my router is a Motorola NVG510
Post Mon May 21, 2012 5:06 pm
Re: Need hel with Directv Dvr
Can you attach your serviio.log file?
cubanoviejo
Post Mon May 21, 2012 6:29 pm
Where do you go to see the service log?
cubanoviejo
Post Mon May 21, 2012 6:36 pm
Never mind
cubanoviejo
Post Mon May 21, 2012 6:46 pm
Here is a copy of todays log
2012-05-21 09:08:56,638 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-21 09:08:56,639 INFO [EventDispatcher] Leaving EventDispatcher
2012-05-21 09:08:56,639 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-21 09:08:56,638 INFO [WebServer] WebServer shutting down
2012-05-21 09:08:57,326 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-05-21 09:14:32,336 INFO [WebServer] WebServer starting on port 8895
2012-05-21 09:14:32,336 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-21 09:14:32,336 INFO [EventDispatcher] Starting EventDispatcher
2012-05-21 09:14:32,336 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-21 09:14:32,336 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-21 09:14:32,368 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (NVIDIA nForce 10/100 Mbps Ethernet ) and address 192.168.1.70, timeout = 0
2012-05-21 09:23:01,191 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-21 09:23:01,191 INFO [WebServer] WebServer shutting down
2012-05-21 09:23:01,208 INFO [EventDispatcher] Leaving EventDispatcher
2012-05-21 09:23:01,191 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-21 09:23:01,879 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-05-21 09:23:01,910 INFO [WebServer] WebServer starting on port 8895
2012-05-21 09:23:01,910 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-21 09:23:01,910 INFO [EventDispatcher] Starting EventDispatcher
2012-05-21 09:23:01,910 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-21 09:23:01,910 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-21 09:23:01,943 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (NVIDIA nForce 10/100 Mbps Ethernet ) and address 192.168.1.70, timeout = 0
2012-05-21 09:25:00,213 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
2012-05-21 09:54:37,222 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-259-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-259-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
2012-05-21 10:03:15,301 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-17-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-17-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
2012-05-21 10:03:15,321 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-17-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
2012-05-21 10:05:00,562 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-238-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-238-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
2012-05-21 10:05:00,578 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-238-MPEG2TS.stf' cannot be found, FFmpeg execution probably failed
2012-05-21 10:05:12,543 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-05-21 10:05:13,713 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
2012-05-21 10:05:13,728 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2012-05-21 10:14:18,003 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-21 10:14:18,049 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-21 10:14:18,149 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-21 10:14:18,150 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-21 11:18:47,778 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-21 11:18:47,778 INFO [WebServer] WebServer shutting down
2012-05-21 11:18:47,779 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-21 11:18:47,780 INFO [EventDispatcher] Leaving EventDispatcher
2012-05-21 11:18:48,311 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
Return to General discussion
