PS3 Wont Play Any MKV
AntonZdz
Post Thu May 17, 2012 10:00 pm
Hi All
Firstly I am loving Serviio, what a great product. Only slight problem is that I cant play any .MKV, almost certainly an issue with my setup though not with the product!
I have tried 7 or 8 different MKVs and each time I get 'The date type is not supported'. I can play AVIs without issue. I have tried remuxing one of the MKVs as a test to see if it was the header issue but that didnt resolve it, and it would seem odd to me (although I am new to this transcoding/remuxing wizardry) that all my MKVs suffer the same issue.
Has anyone got any thoughts, I have set the device to use the PS3 Profile FYI.
Thanks for any thoughts and help.
Anton
Post Fri May 18, 2012 12:14 pm
Re: PS3 Wont Play Any MKV
Could you provide information about this mkv file ? (ffmpeg -i <file> and MediaInfo Tools result in text format )
AntonZdz
Post Fri May 18, 2012 1:32 pm
Thanks for the reply. I will get this information when I get home, I tried 6 MKVs, should I send details of all 6 of them?
AntonZdz
Post Sat May 19, 2012 7:46 am
Ok
So here is the most recent MKV I tried.
MediaInfo data
Unique ID                                : 254073239198572738589634220507382020310 (0xBF24B9D7774751F59EE27B6FCA19F8D6)
Complete name                            : E:\!PERSONAL!\MOVIES\Thor - 2011.mkv
File size                                : 7.96 GiB
Duration                                 : 1h 54mn
Overall bit rate                         : 9 919 Kbps
Encoded date                             : UTC 2012-05-17 21:38:17
Writing application                      : mkvmerge v5.5.0 ('Healer') built on Apr  6 2012 21:43:24
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 54mn
Bit rate                                 : 8 397 Kbps
Height                                   : 816 pixels
Display aspect ratio                     : 2.35:1
Bits/(Pixel*Frame)                       : 0.224
Stream size                              : 6.59 GiB (83%)
Writing library                          : x264 core 116 r2044 392e762
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.02:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=45 / rc=2pass / mbtree=1 / bitrate=8397 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=48000 / vbv_bufsize=40000 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.80
Color primaries                          : Generic film
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : ES
Codec ID                                 : A_DTS
Duration                                 : 1h 54mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.21 GiB (15%)
Text #1
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Text #2
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Menu
00:00:00.000                             : en:00:00:00.000
00:10:38.137                             : en:00:10:38.137
00:17:33.135                             : en:00:17:33.135
00:26:02.603                             : en:00:26:02.603
00:32:28.196                             : en:00:32:28.196
00:37:28.413                             : en:00:37:28.413
00:42:14.198                             : en:00:42:14.198
00:52:10.377                             : en:00:52:10.377
01:01:24.973                             : en:01:01:24.973
01:08:45.538                             : en:01:08:45.538
01:15:39.160                             : en:01:15:39.160
01:21:19.249                             : en:01:21:19.249
01:30:35.347                             : en:01:30:35.347
01:40:58.177                             : en:01:40:58.177
01:45:13.724                             : en:01:45:13.724
01:53:06.196                             : en:01:53:06.196
ffmpeg data
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:/!PERSONAL!/Movies/Thor - 2011.mkv
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 48.00 (48/1)
Input #0, matroska,webm, from 'E:/!PERSONAL!/Movies/Thor - 2011.mkv':
  Duration: 01:54:50.67, start: 0.000000, bitrate: 9919 kb/s
    Chapter #0.0: start 0.000000, end 638.137000
      title           : 00:00:00.000
    Chapter #0.1: start 638.137000, end 1053.135000
      title           : 00:10:38.137
    Chapter #0.2: start 1053.135000, end 1562.603000
      title           : 00:17:33.135
    Chapter #0.3: start 1562.603000, end 1948.196000
      title           : 00:26:02.603
    Chapter #0.4: start 1948.196000, end 2248.413000
      title           : 00:32:28.196
    Chapter #0.5: start 2248.413000, end 2534.198000
      title           : 00:37:28.413
    Chapter #0.6: start 2534.198000, end 3130.377000
      title           : 00:42:14.198
    Chapter #0.7: start 3130.377000, end 3684.973000
      title           : 00:52:10.377
    Chapter #0.8: start 3684.973000, end 4125.538000
      title           : 01:01:24.973
    Chapter #0.9: start 4125.538000, end 4539.160000
      title           : 01:08:45.538
    Chapter #0.10: start 4539.160000, end 4879.249000
      title           : 01:15:39.160
    Chapter #0.11: start 4879.249000, end 5435.347000
      title           : 01:21:19.249
    Chapter #0.12: start 5435.347000, end 6058.177000
      title           : 01:30:35.347
    Chapter #0.13: start 6058.177000, end 6313.724000
      title           : 01:40:58.177
    Chapter #0.14: start 6313.724000, end 6786.196000
      title           : 01:45:13.724
    Chapter #0.15: start 6786.196000, end 6890.678000
      title           : 01:53:06.196
    Stream #0:0(eng): Video: h264 (High), yuvj420p, 1920x816 [SAR 1:1 DAR 40:17]
, 23.98 fps, 48 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
    Stream #0:2(eng): Subtitle: dvd_subtitle (default)
    Stream #0:3(eng): Subtitle: dvd_subtitle
Thanks for taking a look!
Anton
Post Sun May 20, 2012 3:30 pm
I think there were some problem to remux DTS audio. Could you try to remux this mkv to mpegts with TsMuxer tool for testing ?
AntonZdz
Post Mon May 21, 2012 5:11 pm
Hi
More than happy to try this. I have downloaded the tsMuxer Tool, In terms of file output choices, I get 'TS Muxing', 'M2TS muxing', 'Bluray disk','AVCHD Disk' and 'Demux', I am after the first choice, correct? Or have I got the wrong end of the stick :)?!
Post Mon May 21, 2012 6:48 pm
AntonZdz wrote: In terms of file output choices, I get 'TS Muxing', 'M2TS muxing', 'Bluray disk','AVCHD Disk' and 'Demux', I am after the first choice, correct?
I think "M2TS" output file is the best, "TS Muxing" is another solution.
AntonZdz
Post Thu May 24, 2012 1:49 pm
Sorry for the delayed reply! Have been out and about for work the past few days. I am re-muxing now and will try with the PS3 tonite, and I will let you know how this goes!
Thanks for your help so far
AntonZdz
Post Sat May 26, 2012 10:36 am
Good and Bad News!!! I can now play the file and I have video, but I dont have any audio now! Still, its a step closer than before!
Users browsing this forum: Google [Bot] and 7 guests
