serviidb.com
Post Fri May 04, 2012 11:28 am
Re: serviidb.com
I have turned back on the old site, until I get the new site completed. I am redesigning the code base so it is easier to update and maintain in the future.
Once I have this completed, I will transfer the site to the new server and publish the official API Documents.
Post Mon May 07, 2012 2:48 pm
Re: serviidb.com
A few more minor things for your todo list :)
1. On the side bar
Resolution
High Resolution
SD
Change High Resolution to HD.
2. Add an icon for live steams
3. http://serviidb.com/installs doesn't work at the moment, although the api method of getting it via json works.
Xmantium
Post Mon May 21, 2012 10:38 pm
Re: serviidb.com
Hi moltra, spent some time today adding some new content from this amazing post for iPlayer
Few things
-Whats the difference between "Language" and "Media Resource Language" - Best to keep it as one me thinks
- English should be the default language
-Required Plugin Revision - should be deleted, zip stated user should always have the latest plugin installed, groovy plugins currently has no way of checking what version it is
- Live TV streaming seems to be very popular, my post alone is going beyond 100,000 views, think there should a seperate "Live TV Streams" section
This is because live feeds come and go, ive been watching PPV Pay Per View events of boxing with live streaming on Serviio but the feeds never last, it would be great i can share the links or get it from others
So there should be three sections
"By Plugins" - Your usual iPlayer, ITVPlayer, HULU etc links that require plugin
"By Feeds" - Standard feeds that dont need plugins, most of the URLs can be found in catergories here
"By Live Streams" - You could have live Sports broken down to Football, Boxing ect, then TV channels mostly found in my post
Post Mon May 21, 2012 10:46 pm
Re: serviidb.com
I am actually rebuilding the site and it will be clearer. Plus alot faster. I hope to have it up the next day or two
Xmantium
Post Sun May 27, 2012 2:15 pm
Re: serviidb.com
When do think the new serviidb.com will be live?
Post Tue May 29, 2012 10:58 am
Re: serviidb.com
Xmantium wrote:When do think the new serviidb.com will be live?
I have created about 10 versions of it and have ended up not liking the way they responded. I have went back and tweaked the original serviidb.com to make it faster. I am looking at setting up serviidb as a web directory now, and I think it will be what I want. I could have it up in a couple of days if everything goes well.
Are you looking for a certain thing or just asking?
Post Tue May 29, 2012 11:32 am
Re: serviidb.com
We should start pushing users to fill it with content, possibly the live streams? Not sure how durable those are though.
Post Tue May 29, 2012 11:47 am
Re: serviidb.com
yes, I can always move the content to any new system that I go to.
I am thinking about adding a new status field. That that users could change to let others now that a feed is down. And if the UI developers want to they could change this status field via the API.
Xmantium
Post Tue May 29, 2012 3:51 pm
Re: serviidb.com
Ive tried adding content, seems to be very slow even on Chrome
Have you ever used nzbmatrix.com for usenet downloads?
Out of all the nzb database website this is the best in terms of user interface storing a large database. Its content is very clear and they have a wide API system in place.
Theres even Chrome and Firefox extentions to add content
Post Tue May 29, 2012 9:28 pm
Re: serviidb.com
That is my current host. Transitioning to a vps.
Xmantium
Post Sat Jul 14, 2012 11:21 pm
Re: serviidb.com
Whats the latest update on the new serviidb.com?
Post Tue Jul 31, 2012 9:24 pm
Re: serviidb.com
Hi moltra, is this still live?
Post Wed Aug 01, 2012 3:15 pm
Re: serviidb.com
I haven't heard from moltra in a while. He had set up a new site, but needed to transfer the content, I was in the process of working out the best way to transfer the info from the old db to import it across without doing it manually and then I guess he has been busy as I haven't heard from him. Although looking at the new site, it has a large amount of the content.
Post Mon Aug 06, 2012 9:49 pm
Re: serviidb.com
yes it is having one small issue with the sql since the mysql is a newer version. Hope to have it up and transfered in the next few days.
Xmantium
Post Mon Aug 06, 2012 10:02 pm
Re: serviidb.com
Good to see you back! ;)
Post Mon Aug 06, 2012 10:28 pm
Re: serviidb.com
had a busy end of june and july. Was working two jobs, and then on vacation with family. Plus my last job was where I was doing most of my work on the site.
Post Wed Aug 22, 2012 10:32 am
Re: serviidb.com
Any update on the new site, I see it has part of the content already added. Anything we can do to help?
Post Wed Aug 22, 2012 11:21 am
Re: serviidb.com
just a small bug in the PHP /SQL if you do an empty search it does not return anything. Something is different in the two SQL installs I think
you can try it just use serviidbgroup.info instead of the serviidb.com.
Also need people to start adding more content.
Post Wed Aug 22, 2012 12:04 pm
Re: serviidb.com
OK, I'll test it tonight.
Post Wed Aug 22, 2012 7:47 pm
Re: serviidb.com
Doesn't seem to work. I just get the following back.
taskhandler
{"resource":"video","requestedSize":0,"totalSize":0,"items":[]}
