[SOLVED] transcoding-temp-272-MPEG2PS.stf' cannot be found
cubanoviejo
Post Tue May 22, 2012 1:14 am
Help. I'm getting this error transcoding-temp-272-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
whene playing WMV movies in my directv drv :ugeek:
Post Tue May 22, 2012 7:25 am
Re: transcoding-temp-272-MPEG2PS.stf' cannot be found
Could you post the detailed logging ? see signature links.
cubanoviejo
Post Tue May 22, 2012 1:34 pm
Here is the log info.
2012-05-21 18:31:14,969 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-272-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file 'C:\Windows\TEMP\Serviio\transcoding-temp-272-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:129)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:96)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:121)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:116)
Post Tue May 22, 2012 1:36 pm
cubanoviejo wrote:'C:\Windows\TEMP\Serviio\transcoding-temp-272-MPEG2PS.stf' cannot be found, FFmpeg execution probably failed
Could you enable detailed logging, find the ffmpeg command line used for transcoding process and try the same command line locally in a windows terminal and post error output here?
cubanoviejo
Post Tue May 22, 2012 3:43 pm
After Disable Windows 7 Media Player Network Sharing all is working fin
Users browsing this forum: Baidu [Spider], Google [Bot] and 44 guests
