Duplicate folder names
thingy
Post Wed May 23, 2012 11:27 am
I have two folders named hdtv on two different harddrives.
Browsing the folder index, shows two folders named hdtv, however both links go to the first added hdtv folder.
So I am unable to browse to the second hdtv folder.
It does however work when I browse Series without a problem, but when an episode isn't recognized, because of naming or not in thetvdb I can't reach that episode from the folder view.
My suggestion: if two folders have the same name, they should internally be name [folder] (1) and [folder] (2), et.c.
Post Wed May 23, 2012 4:00 pm
Re: Duplicate folder names
I assume this is on Samsung? If yes it's a known bug in their software. Each folder has a unique ID which they don't seem to use.
Return to User experiences
