fast forward
lorenzo23
Post Tue May 22, 2012 8:35 pm
fast forward
does anyone experienced problems with fast forward in serviio+linux ubuntu?
It plays at normal speed works, but fast forward interrupts the stream. I experienced it with normal avi files.
I remember in the past a similar issue, deriving from a specific ffmpeg package build.
Thank you
Post Wed May 23, 2012 6:08 pm
Re: fast forward
what's your FFmpeg version?
lorenzo23
Post Wed May 23, 2012 6:12 pm
Re: fast forward
ffmpeg version 0.8.1-4:0.8.1-0ubuntu1, Copyright (c) 2000-2011 the Libav developers
built on Mar 22 2012 05:09:06 with gcc 4.6.3
This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes).
Post Wed May 23, 2012 6:53 pm
Re: fast forward
try to get FFmpeg from the main branch, not the one from libAV - you can download sources from serviio website
lorenzo23
Post Wed May 23, 2012 7:44 pm
Re: fast forward
as of Natty, Ubuntu has switched from FFmpeg to the libav fork
Post Thu May 24, 2012 4:31 pm
Re: fast forward
lorenzo23 wrote:as of Natty, Ubuntu has switched from FFmpeg to the libav fork
I know, and it's unsupported with Serviio. I'll stick with the main FFmpeg distribution.
lorenzo23
Post Thu May 24, 2012 7:01 pm
[SOLVED] Re: fast forward
switched to ffmpeg from the main branch and it works. thanks.
