Video OK , Audio stops and starts
AndrewW
Post Sun May 27, 2012 6:47 am
I'm trying to play home movies on a samsung le46c750. The video playes ok but the audio keeps starting and stopping.
I've attached the file info below.
Is there a profile adjustment needed. If so any ideas ?
Kind Regards
Andrew
FFmpeg version SVN-r22888, Copyright (c) 2000-2010 the FFmpeg developers
built on Apr 16 2010 06:08:05 with gcc 4.4.2
configuration: --enable-memalign-hack --cross-prefix=i686-mingw32- --cc=ccache-i686-mingw32-gcc --arch=i686 --target-os=mingw32 --enable-runtime-cpu
detect --enable-avisynth --enable-gpl --enable-version3 --enable-bzlib --enable-libgsm --enable-libfaad --enable-pthreads --enable-libvorbis --enable-
libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libxvid --enable-libschroedinger --enable-libx264 --enable-libopencore_a
mrwb --enable-libopencore_amrnb
libavutil 50.14. 0 / 50.14. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.61. 0 / 52.61. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[mpegts @ 017a85f0]MAX_READ_SIZE:5000000 reached
Input #0, mpegts, from '05-12-2012_104231.m2ts':
Duration: 00:00:27.87, start: 0.801622, bitrate: 10177 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
Stream #0.2[0x1200]: Subtitle: pgssub
Post Sun May 27, 2012 8:28 pm
Re: Video OK , Audio stops and starts
try to update your ffmpeg
AndrewW
Post Mon May 28, 2012 4:18 pm
sorry, ran the ffmpeg -i on another machine, please find below the results from the machine hosting serviio
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --e
nable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=
mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[h264 @ 02ceb180] Increasing reorder buffer to 1
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 50.00 (50/1)
Input #0, mpegts, from 'c:\temp\05-12-2012_104231.m2ts':
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 50
tbc
Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, s16, 256 kb/s
Stream #0:2[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
AndrewW
Post Mon May 28, 2012 5:02 pm
just tried a few other simular files and all the same
The debiug log look like
2012-05-28 17:56:32,554 DEBUG [VideoDeliveryEngine] Delivering item '144771' for client 'IPAddress=/192.168.0.50, Profile=Samsung TV / player (C/D-series)'
2012-05-28 17:56:32,554 DEBUG [VideoDeliveryEngine] Delivering file '05-21-2012_122947.m2ts' in native format
so no transcoding happening ?
Andrew
Post Mon May 28, 2012 6:22 pm
yes, not transcoding. Try to upgdare the firmware. Otherwise it might be down to the network.
AndrewW
Post Mon May 28, 2012 7:00 pm
just checked no firmware updates, and all other files work fine except those from my panasonic hd camcorder
I may try to convert the file but way hoping to avoid transcoding the originals
AndrewW
Post Tue May 29, 2012 5:50 pm
FIxed it by transcoding the audio to aac format, leaving the video alone.
ffmpeg -i source -vcodec copy -strict -2 -acodec aac -ar 48000 dest
is there a way the profile can be adjusted to have the same effect ?
Post Tue May 29, 2012 9:50 pm
Try to add this on the top of the profile's transcoding config. There might be typos ;-)
<Video targetContainer="mpegts" targetACodec="aac">
  <Matches container="mpegts" aCodec="ac3" />
