Adding transcoding support for the speex audio codec
wae3iejohhohZae5
Post Sat May 26, 2012 1:56 pm
some "desktop broadcasting programs" such as XSplit use speex as an audio codec. While support for speex seems to be lacking on most of the televisions (and at least my Samsung D6 does not play it), ffmpeg seems to be able to convert it just fine. So the only thing that seems to be missing is a conversion rule in profiles.xml in order to get the speex audio codec supported. I would appreciate if that could be added to Serviio.
Here is some more info:
ffmpeg -i "rtmp://owned.fc.llnwd.net:1935/owned/imhirai_195802 swfVfy=1 live=1" -f mpegts -vcodec copy -vbsf h264_mp4toannexbodec ac3 -ab 192k pipe: | vlc -
VLC media player 2.0.1 Twoflower (revision 2.0.1-0-gf432547)
ffmpeg version 0.8.1-4:0.8.1-0ubuntu1, Copyright (c) 2000-2011 the Libav developers
  built on Mar 22 2012 05:09:06 with gcc 4.6.3
This program is not developed anymore and is only provided for compatibility. Use avconv instead (see Changelog for the list of incompatible changes).
[0x23d1108] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
HandShake: client signature does not match!
  author
  copyright
  description
  keywords
  rating
  title
  presetname            Custom
  creationdate          Sat May 26 21:27:13 2012
  videodevice           XSplitBroadcaster
  framerate             25.00
  width                 1280.00
  height                720.00
  videocodecid          avc1
  avclevel              51.00
  avcprofile            100.00
  videodatarate         390.62
  videokeyframe_frequency0.00
  audiodevice           VHAudioCustom
  audiosamplerate       16000.00
  audiochannels         1.00
  audioinputvolume      100.00
  audiocodecid          11.00
  audiodatarate         27.15
  bufferSize            1000k
  maxBitrate            1000k
  xsplitBroadcasterVersion1.3.0.10
  xsplitCoreVersion     1.0.1204.1301 Version 1.0
  xsplitGameSourceVersion1.1.0.21
  xsplitMediaLibVersion 2.0.0.102
[libspeex @ 0x95e1a0] Missing Speex header, assuming defaults.
[flv @ 0x9339a0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 2000.00 (2000/1) -> 25.00 (25/1)
Input #0, flv, from 'rtmp://owned.fc.llnwd.net:1935/owned/imhirai_195802 swfVfy=1 live=1':
  Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264 (High), yuv420p, 1280x720, 25 tbr, 1k tbn, 2k tbc
    Stream #0.1: Audio: libspeex, 16000 Hz, 1 channels, s16
Incompatible sample format 's16' for codec 'ac3', auto-selecting format 'flt'
[ac3 @ 0x94b7e0] channel_layout not specified
[ac3 @ 0x94b7e0] No channel layout specified. The encoder will guess the layout, but it might be incorrect.
[mpegts @ 0xa49960] muxrate VBR, pcr every 100 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to 'pipe:':
    encoder         : Lavf53.21.0
    Stream #0.0: Video: libx264, yuv420p, 1280x720, q=2-31, 90k tbn, 1k tbc
    Stream #0.1: Audio: ac3, 16000 Hz, mono, flt, 192 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press ctrl-c to stop encoding
[h264 @ 0x7f1f9cd08380] illegal short term buffer state detected
frame= 7316 fps= 25 q=-1.0 size=   34385kB time=292.75 bitrate= 962.2kbits/s
Post Sat May 26, 2012 4:07 pm
Re: Adding transcoding support for the speex audio codec
Servio (Zip) have to add "libspeex" on audio codec matching to support transcoding. Add a ticket.
viewtopic.php?f=5&t=2
wae3iejohhohZae5
Post Mon May 28, 2012 4:00 pm
Illico wrote:Servio (Zip) have to add "libspeex" on audio codec matching to support transcoding. Add a ticket.
Thanks. Created a ticket: https://bitbucket.org/xnejp03/serviio/i ... -the-speex
Post Mon May 28, 2012 5:54 pm
can you upload a small file somewhere for me to test?
wae3iejohhohZae5
Post Wed May 30, 2012 7:30 pm
zip wrote:can you upload a small file somewhere for me to test?
Will do. This might take some more time however. Sorry, should have done this earlier.
Edit: Sent you the URL of the sample file via PM.
Return to Feature requests
