Re: ServiiDroid (Android Console) - Get it on Google Play
will wrote:What would you want them to display/do?
will wrote:@zip is there a way to force a refresh of all online sources in one go?
zip wrote:No, what do you need it for?
Xmantium wrote:My wife is asking will you make an iPhone ServiiDroid!?
Although Marks Web UI works perfectly on the iPad, it's very tiny on her iPhone 4S.
iOS users tend to pay for apps so I'm sure you'll recoup development costs
Don't need to buy a Mac when you can dual boot OS X on your PC
==== 1.5 ====
*Fixed #65: New files added displays on two lines
*Fixed FC if an invalid string is entered into the ServiiDB search box
*Added [Serviio 1.0] Enable/disable devices
*Added [Serviio 1.0] Manage access groups
*Added [Serviio 1.0] Set default quality for the media browser
*Serviio 1.0 Beta 1 & Beta 2 are no longer supported
Xmantium wrote:On "Devices" tab i think it lists the devices fine the way it is, i can clearly see which devices are limited
What would be cool, in beween the + icon and refresh icon, theres an eye logo
http://julien.coron.free.fr/my_icons/48/eye-logo.png
It has the options "All", "No Restrictions", "Limited"
This ofcourse can be expanded when zip eventually has user groups such as "kids" on is later build
On "Shared folders" and "Online sources"
Remove the word "Options", most users should know by now what those icons represent
Move the icons where "Options" was.
On the right indicate if the content is limited
Also can the "Remote Settings" display the user value without having to go into it
Example
"User password" to "User Password: Not Set" or ""User Password: LoveUsingServiio"
and same for preffered quality
