Transcode DVVIDEO files
pdneri
Post Wed May 30, 2012 7:46 pm
I have some AVI files captured by Windows Live Movie Maker from my DV video camera.
ffmpeg -i returns the following:
C:\Temp>ffmpeg -i test1.avi
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Input #0, avi, from 'test1.avi':
  Duration: 00:01:25.60, start: 0.000000, bitrate: 28886 kb/s
    Stream #0:0: Video: dvvideo, yuv420p, 720x576, 28800 kb/s, SAR 16:15 DAR 4:3
, 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: pcm_s16le, 32000 Hz, 2 channels, s16, 1024 kb/s
    Stream #0:2: Audio: pcm_s16le, 32000 Hz, 2 channels, s16, 1024 kb/s
When I play the files from my PC the video is quite good.
When I see them on my TV using serviio, they are transcoded but something is wrong with the interlacing (I guess): a sort of horizontal lines are shown.
My profile is customized like this:
Is there something I can do to improve the quality when watching these files?
Davide
Post Wed May 30, 2012 9:44 pm
Re: Transcode DVVIDEO files
can you upload a small sample somewhere for me to reproduce?
pdneri
Post Sun Jun 03, 2012 8:27 am
hi Zip, do you face the same issue?
Post Sun Jun 03, 2012 10:15 am
sorry, didnt have time to look at it and am on holidays now, will try to look in a week, ping me here to remind me in a case I forget :-)
pdneri
Post Mon Sep 10, 2012 9:24 am
... a very late ping ... but a solution would still be appreciated! Thanks!
Post Mon Sep 10, 2012 12:57 pm
yes, it's interlaced. I tried to de-interlace it in ffmpeg, but the result was pretty bad. Your best bet is to deinterlace it in some good tool and share then - or try to find a setting on your camera to not use interlaced streams.
