Video not playing on my Argosy HV335T
robertsmith
Post Sat Jun 02, 2012 3:19 am
I have an Argosy HV335T and a Patriot Box Office. I can get Serviio to work fine on the PBO, but for some reason I can't play videos on the Argosy. I can browse to the video, but when I try to play it, nothing happens. I believe the Argosy can play everything the PBO can and I have tried many different files. I did try changing "generic DLNA profile" to some others on the list, but none seemed to get things to work.
I have attached a log file where I tried playing a Youtube video, and then 2 videos off my PC, none of which worked. Please help.
serviio - Copy.zip
Log File
(7.67 KiB) Downloaded 520 times
robertsmith
Post Mon Jun 04, 2012 11:29 pm
Re: Video not playing on my Argosy HV335T
Does the log file look ok? Please let me know if there are any errors or if the log file was note logged properly.
Post Tue Jun 05, 2012 9:35 am
You've got IP address with different sub address, and you've two NIC (eth3 net6), be carefull with your network setup !
192.168.123.1
192.168.10.102
192.168.123.16 (from 192.168.123.16 (headers = [Host: 192.168.123.1:8895,User-Agent: POSIX UPnP/1.0 Intel MicroStack/1.0.2718, RealtekMediaCenter, DLNADOC/1.50]))
Could you identify devices with IP address?
Could you check this http://wiki.serviio.org/doku.php?id=device_sf ?
robertsmith
Post Wed Jun 06, 2012 12:03 am
Oh I could see how that might be confusing. It looks a lot worse than it is :)
So 192.168.10.102 is the PC hosting the media, it is leasing its IP from the main router through a powerline ethernet unit.
Connected to this PC is a USB soft Access Point with IP 192.168.123.1. I use this device to lease to wireless devices on the main and upper floors (to extend the range). It leases the Argosy HV335T on 192.168.123.16.
Just so you are aware, the Patriot Box Office was on 192.168.123.12 (this is not in the log) and this played the media off the PC fine.
robertsmith
Post Fri Jun 08, 2012 2:22 am
I ran Device Spy, but it does not show the Argosy unit.
It only shows:
Internet Gateway Device (Access Point)
Serviio
Trendnet Wireless Router
robertsmith
Post Thu Jun 14, 2012 4:37 am
Please clarify if Device Spy should be automatically detecting my DLNA unit?
Am I to assume that the Argosy is not compatible with Serviio? I have TVersity and it worked fine with that.
