No "Play with Serviio" in context menu
burdenofhope
Post Wed Jun 06, 2012 3:28 pm
Hi there,
I'm new here and unfortunately I couldn't find an answer in the existing threads. I just bought a new receiver and I am already using the Windows Media Player 12 to stream music, but I'd rather use Serviio: viewtopic.php?f=3&t=5681 My problem is, that there is no "Play with Serviio" in my right click context menu. My operating system is Windows 7 64bit. Does anyone know a solution or is this a known problem or am I just completely blind and cannot find the settings?
Thanks a lot, Michael.
Post Wed Jun 06, 2012 4:22 pm
Re: No "Play with Serviio" in context menu
Serviio does not support DMC (controller) feature, this is a DMS (server)...
viewtopic.php?f=3&t=5681#p40980
younoyouno post is a feature request !
burdenofhope
Post Wed Jun 06, 2012 5:33 pm
Thank you for your help. Sorry for getting probably a little too off-topic, but do you know of any (probably there are none) Digital Media Controllers for Windows 7? I am looking for an alternative to the Windows Media Player 12, since I do not want to adjust the Master Volume on my receiver with that "Play to" tool. My girlfriend wanted to raise the volume and used this volume control ( https://dl.dropbox.com/u/38537672/sreen ... eerwmp.JPG ) to do so. She dragged it all the way up and the roof nearly got blown off of this place. That's why I am looking for some alternatives. Thank you very much.
Users browsing this forum: Baidu [Spider] and 77 guests
