Serviio Not Detecting Episodes
elementus
Post Thu Jun 07, 2012 6:20 pm
Hey all, I tried googling this earlier in the day and searching the forums but I couldn't find anything that applied directly to me. I tried importing all of my TV shows earlier today and noticed that a lot of them were not showing up. I then moved all of the folders except for two: Adventure Time and Alphas to try to test why it won't detect my shows. My folder layout is:
Adventure Time > Season 1, Season 2, Season 3, Season 4
Alphas > Season 1
All of these files are .mkv When I run a scan it detects Adventure Time Seasons 1 and 2 and sometimes 3, but never 4. It also never detects Alphas at all. I've tried lots of things, changing around where the metadata is coming from (I'm currently using exported nfo files from XBMC). The file format should be readable. One of the files it's not detected is: Adventure time - 4x01 - Hot to the Touch.mkv
When I look at the log it just stop looking after Adventure Time Season 3.
And help would be appreciated.
Post Sat Jun 09, 2012 8:13 am
Re: Serviio Not Detecting Episodes
If you use .nfo files (and select this metadata source in the console) the file name doesn't matter, it reads metadata from the nfo file. Note that only one metadata source type is always active, you can either have onlne metadata or .nfo, not both. Also check the Folders category to see if the file itself has been added (and only not showing in Series category)
elementus
Post Sat Jun 09, 2012 7:08 pm
I have tried both online metadata and the .nfo files and neither of them worked. The files do not show up in the Folders category either. When I look at the log it is not detecting the shows at all.
Post Sat Jun 09, 2012 8:26 pm
Are all the files in the same folder?
elementus
Post Sat Jun 09, 2012 9:03 pm
Yes the layout is:
TV
=> Adventure Time
===> Season 1
===> Season 2
===> Season 3
===> Season 4
=> Alphas
===> Season 1
Only the first 3 folders are detected and then they stop. All files are renamed with TheRenamer and XBMC detects them. The Adventure Time episodes all have the same filename format so it blows my mind why it would detect Seasons 1 - 3 but not 4.
Post Sun Jun 10, 2012 11:19 am
If they are not even in Folders then it's either unrecognized file format (I doubt it, but you can paste ffmpeg -i for a file here anyway) or access rights to the folder or files within it.
It might also be caused by a single dodgy file that blocks adding any files after that. you could check the log which file has been added last.
elementus
Post Sun Jun 10, 2012 2:24 pm
All local users on my computer have full 777 access to the folders that are not being accessed.
These are the last 5 lines in the log:
2012-06-10 10:11:00,814 INFO  [LibraryAdditionsCheckerThread] Added file 'Adventure Time with Finn and Jake - 322 - Paper Pete (720p.x264.ac3-5.1) [449].mkv' (title: Adventure Time with Finn and Jake - 322 - Paper Pete (720p.x264.ac3-5.1) [449]) to Library
2012-06-10 10:11:01,525 INFO  [LibraryAdditionsCheckerThread] Added file 'Adventure Time with Finn and Jake - 323 - Another Way (720p.x264.ac3-5.1) [449].mkv' (title: Adventure Time with Finn and Jake - 323 - Another Way (720p.x264.ac3-5.1) [449]) to Library
2012-06-10 10:11:02,209 INFO  [LibraryAdditionsCheckerThread] Added file 'Adventure Time with Finn and Jake - 324 - Ghost Princess (720p.x264.ac3-5.1) [449].mkv' (title: Adventure Time with Finn and Jake - 324 - Ghost Princess (720p.x264.ac3-5.1) [449]) to Library
2012-06-10 10:11:04,381 INFO  [LibraryAdditionsCheckerThread] Added file 'Adventure Time with Finn and Jake - 325 - Dad's Dungeon (720p.x264.ac3-5.1) [449].mkv' (title: Adventure Time with Finn and Jake - 325 - Dad's Dungeon (720p.x264.ac3-5.1) [449]) to Library
2012-06-10 10:11:05,262 INFO  [LibraryAdditionsCheckerThread] Added file 'Adventure Time with Finn and Jake - 326 - Incendium (720p.x264.ac3-5.1) [449].mkv' (title: Adventure Time with Finn and Jake - 326 - Incendium (720p.x264.ac3-5.1) [449]) to Library
The last working file:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\TV\Adventure Time\Season 3\Advent
ure Time with Finn and Jake - 326 - Incendium (720p.x264.ac3-5.1) [449].mkv"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 48.00 (48/1)
Input #0, matroska,webm, from 'D:\TV\Adventure Time\Season 3\Adventure Time with
 Finn and Jake - 326 - Incendium (720p.x264.ac3-5.1) [449].mkv':
    title           : Adventure Time with Finn & Jake - 313b - Incendium (720p.x
264.ac3-5.1) [449]
  Duration: 00:11:43.52, start: 0.000000, bitrate: 1671 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 2
3.98 fps, 48 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s (default)
First file that doesn't work:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\TV\Adventure Time\Season 4\Advent
ure time - 4x01 - Hot to the Touch.mkv"
nfig
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (2997/5
0) -> 59.94 (60000/1001)
Input #0, matroska,webm, from 'D:\TV\Adventure Time\Season 4\Adventure time - 4x
01 - Hot to the Touch.mkv':
  Duration: 00:11:11.59, start: 0.000000, bitrate: 2199 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 29.97
 fps, 59.94 tbr, 1k tbn, 59.94 tbc (default)
    Stream #0:1: Audio: aac, 48000 Hz, 5.1, s16 (default)
Post Mon Jun 11, 2012 3:36 pm
777? You are on windows. Or is that a remote disk (D:)? The user that runs the service (probably System) must have the access
elementus
Post Thu Jun 14, 2012 2:23 pm
I guess 777 isn't the right terminology, I don't often use Windows. I was just trying to say they have full permissions. I gave every user full permissions including System.
LACHAPELLE
Post Tue Jul 17, 2012 1:47 am
I was wondering if there was a solution to this? I am having the exact same problem.
patters
Post Tue Jul 17, 2012 7:19 am
I find that episode recognition with filenames like you have there can be sketchy. I generally go through the folders renaming just the episode number to this format: s01e04. Always works for me.
Users browsing this forum: Baidu [Spider], Google [Bot] and 59 guests
