Install Problems in Win7
cdbrander
Post Fri Jun 08, 2012 3:02 pm
Hi ther every one.
I have installed Serviio on my PC running Vista. Is works perfect and I am very pleased that you can use such an open source application for free.
My problem is that the main operating system on my PC is a legal version of Windows7 and Serviio will not run on this OS.
Looking in administartor tools for running services it will appear. That should mean that Serviio is running good, but I can not start the Serviio console.
Is there a solvation for this problem? :idea:
Greetz from CDBrander
Post Fri Jun 08, 2012 8:44 pm
Re: Install Problems in Win7
It works on Win7. Post detailed log.
cdbrander
Post Sat Jun 09, 2012 11:51 am
Which log file do you mean: there are 2 log files: derby.log and serviio.log. This last one is the greatest of both.
And a detailed log file do y mean copy/paste the whole file?
Post Sat Jun 09, 2012 12:23 pm
serviio.log and look at his signature for detail logging.
cdbrander
Post Mon Jun 11, 2012 5:31 pm
Hi Zip
Here is my detailed log. I hope you can find out what the problem could be.
2012-06-11 19:26:15,981 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-06-11 19:26:15,986 INFO [MediaServer] ------------------------------------------------------------------------
2012-06-11 19:26:15,986 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-06-11 19:26:15,986 INFO [MediaServer] Petr Nejedly 2009-2011
2012-06-11 19:26:15,986 INFO [MediaServer] http://www.serviio.org
2012-06-11 19:26:15,987 INFO [MediaServer]
2012-06-11 19:26:15,987 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-06-11 19:26:15,987 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-06-11 19:26:15,987 INFO [MediaServer] File encoding: windows-1252
2012-06-11 19:26:15,987 INFO [MediaServer] Headless mode enabled: true
2012-06-11 19:26:15,987 INFO [MediaServer] User home dir: C:\
2012-06-11 19:26:15,987 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-06-11 19:26:15,987 INFO [MediaServer] ------------------------------------------------------------------------
2012-06-11 19:26:16,080 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-06-11 19:26:16,119 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-06-11 19:26:16,125 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-06-11 19:26:16,915 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-06-11 19:26:16,916 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-06-11 19:26:16,916 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-06-11 19:26:16,917 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-06-11 19:26:16,917 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-06-11 19:26:16,918 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-06-11 19:26:16,919 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-06-11 19:26:16,919 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-06-11 19:26:16,920 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-06-11 19:26:16,920 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-06-11 19:26:16,921 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-06-11 19:26:17,130 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-06-11 19:26:17,172 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-06-11 19:26:17,661 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-06-11 19:26:17,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-06-11 19:26:17,982 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-06-11 19:26:17,983 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-06-11 19:26:18,177 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-06-11 19:26:18,178 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-06-11 19:26:18,432 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-06-11 19:26:18,434 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-06-11 19:26:18,578 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-06-11 19:26:18,580 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-06-11 19:26:18,687 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-06-11 19:26:18,688 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-06-11 19:26:19,118 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-06-11 19:26:19,120 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-06-11 19:26:19,154 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-06-11 19:26:19,156 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2012-06-11 19:26:19,583 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-06-11 19:26:19,584 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-06-11 19:26:20,140 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-06-11 19:26:20,142 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2012-06-11 19:26:20,394 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-06-11 19:26:20,396 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-06-11 19:26:20,688 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-06-11 19:26:20,690 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-06-11 19:26:20,825 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-06-11 19:26:20,826 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-06-11 19:26:20,855 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-06-11 19:26:20,857 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-06-11 19:26:20,961 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-06-11 19:26:20,962 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-06-11 19:26:21,010 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-06-11 19:26:21,011 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-06-11 19:26:21,184 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-06-11 19:26:21,187 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2012-06-11 19:26:21,268 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-06-11 19:26:21,270 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-06-11 19:26:21,486 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-06-11 19:26:21,488 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 21
2012-06-11 19:26:21,620 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-06-11 19:26:21,702 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-06-11 19:26:24,672 INFO [WebServer] Socket buffer set to 65535 bytes
2012-06-11 19:26:24,672 INFO [Device] Created UPnP Device with UUID: 64edc58c-8a19-36ca-89ad-53dccbb5ee39, bound address: 192.168.2.247
2012-06-11 19:26:24,691 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-06-11 19:26:24,693 INFO [PluginCompilerThread] Started looking for plugins
2012-06-11 19:26:24,695 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-06-11 19:26:24,698 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-06-11 19:26:24,792 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-06-11 19:26:24,817 INFO [WebServer] WebServer starting on port 8895
2012-06-11 19:26:24,821 DEBUG [DiscoveryManager] UPNP device 64edc58c-8a19-36ca-89ad-53dccbb5ee39 (192.168.2.247) is available
2012-06-11 19:26:24,822 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-06-11 19:26:24,822 INFO [EventDispatcher] Starting EventDispatcher
2012-06-11 19:26:24,823 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-06-11 19:26:24,827 INFO [RendererSearchSender] Searching for Renderer devices
2012-06-11 19:26:24,827 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-06-11 19:26:24,905 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.247, timeout = 0
2012-06-11 19:26:29,078 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.247, timeout = 0
2012-06-11 19:26:29,086 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:26:29,157 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.247, timeout = 0
2012-06-11 19:26:29,158 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-06-11 19:26:29,158 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth6 (VirtualBox Host-Only Ethernet Adapter) and address 192.168.56.1, timeout = 0
2012-06-11 19:26:29,158 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.247:59530
2012-06-11 19:26:29,164 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.247:59530
2012-06-11 19:26:29,165 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.247:59530
2012-06-11 19:26:30,887 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth6 (VirtualBox Host-Only Ethernet Adapter) and address 192.168.56.1, timeout = 0
2012-06-11 19:26:30,888 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:26:32,690 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-06-11 19:26:35,165 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-06-11 19:26:45,714 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.247, timeout = 0
2012-06-11 19:26:45,715 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:26:47,515 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth6 (VirtualBox Host-Only Ethernet Adapter) and address 192.168.56.1, timeout = 0
2012-06-11 19:26:47,516 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:26:49,316 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-06-11 19:26:55,167 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-06-11 19:26:55,168 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-11 19:26:55,171 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-11 19:26:55,172 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-11 19:26:55,175 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-06-11 19:26:55,182 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-11 19:26:55,182 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-06-11 19:27:02,296 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.247, timeout = 0
2012-06-11 19:27:02,297 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:27:04,097 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth6 (VirtualBox Host-Only Ethernet Adapter) and address 192.168.56.1, timeout = 0
2012-06-11 19:27:04,098 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 64edc58c-8a19-36ca-89ad-53dccbb5ee39
2012-06-11 19:27:05,898 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:17
Post Mon Jun 11, 2012 5:35 pm
log looks ok, try upgrading your Java
cdbrander
Post Thu Jun 14, 2012 8:01 am
I have updated the Java to Version 7 Update 5 . It was not easy to install, but finaly - after de-install older java versions java finaly works.
Then restarted the serviio services and after 2 or 3 times trying to start de serviio console it works.
Your last sugestion of updating java was the best option.
Thanks for your support and now I can enjoy serviio.
