access serviio from the internet for use on android
maliczilyas
Post Fri Jun 08, 2012 1:06 pm
Hey
First congrats on this nice piece of software!
Is it possible to browse and stream from serviio from wan?
I was able to succesfully set this up with mediatomb and upnplay (wan server option). Trying this with serviio did not work.
Then I've tried using BubbleUpnp with the BubbleUpnp server. This listed my dlna servers but not serviio. It was not able to get respons from serviio.
I have set up a vpn using openvpn, serviio got listed but was not able to stream.
So I have tried a few things. But I was not able to get it setup
Using wifi on my lan, everything is perfect.
If I could connect to serviio directly using 3g would be really great.
Is there anyone who could give me a suggestion or a tip?
Thank you!
Malic
Post Fri Jun 08, 2012 4:32 pm
Re: access serviio from the internet for use on android
will be in next release in a month or so
Post Sat Jun 09, 2012 8:44 am
As said it is coming soon. I'm currently writing and android app that will use the new API built into 1.0, any comments/suggestions/feature requests that you might have would be great. viewtopic.php?f=17&t=6036
jalla
Post Sat Jun 09, 2012 4:31 pm
maliczilyas wrote:Hey
Try again. I switched from mediatomb to serviio some time ago and had no problems making this work.
Post Sat Jun 09, 2012 5:36 pm
Great..how about posting your method so others can benefit.
jalla
Post Sun Jun 10, 2012 9:50 am
There's an extensive recipe here on how to access Mediatomb using UPnPlay over a ssh tunnel. Adapting this to Serviio is just a matter of forwarding different portnumbers over the tunnel. The portnumbers are 8895 for serviio, and optionally 23423 for the serviio console.
maliczilyas
Post Mon Jun 11, 2012 6:30 am
Thank you all for your reply!
I must set a few things straight. I have retried connecting to serviio through wifi and it did not work also.
I have changed the user on wich serviio runs and it didn't function well because of file permissions.
Changing the ownership off the files made it all work.
So now I can access serviio using my VPN.
I can access serviio using BubbleUpnp server (dlna proxy)
I can also acces serviio by port forwarding tcp port 8895 and using upnp wan server function!
I'm eagerly waiting for the new version, the new app that connects to it really looks nice!
Users browsing this forum: Baidu [Spider] and 40 guests
