Sony SMP-N200 Profile?
Post Sun Jan 22, 2012 8:22 am
Re: Sony SMP-N200 Profile?
Clutch wrote:
Cerberus wrote:novid1.mp4 and novid1b.mp4 - yep they are adware infected files, that why it want to install its own special codec.
For future reference, how can one (me) tell? if it wants to install special codec when u play with VLC/WMP its infected.
Cerberus wrote:wrkvid1.mp4 - looks ok but might have header compression please provide mediainfo for that field.
Here's the mediainfo info.
Complete name                            : /media/Media/wrkvid1.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 1 001 MiB
Duration                                 : 37mn 30s
Overall bit rate                         : 3 732 Kbps
Encoded date                             : UTC 2011-02-22 18:33:12
Tagged date                              : UTC 2011-02-22 18:39:08
Writing application                      : HandBrake 0.9.5 2011010300
Format profile                           : Main@L3.0
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 37mn 30s
Bit rate                                 : 3 598 Kbps
Width                                    : 720 pixels
Height                                   : 480 pixels
Original display aspect ratio            : 16:9
Frame rate mode                          : Variable
Minimum frame rate                       : 19.969 fps
Maximum frame rate                       : 29.970 fps
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.434
Stream size                              : 965 MiB (96%)
Writing library                          : x264 core 112
Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3598 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Codec ID                                 : 40
Duration                                 : 37mn 30s
Bit rate                                 : 128 Kbps
Maximum bit rate                         : 316 Kbps
Stream size                              : 34.3 MiB (3%)
looks ok to me but i know that MP42 has been giving other users issues in past, but zip may have a fix.
And for possible educational purposes, the info for one of the infected files:
Complete name                            : /media/Media/novid1.mp4
Codec ID                                 : mp42
File size                                : 1.18 GiB
Duration                                 : 2h 43mn
Overall bit rate                         : 1 034 Kbps
Encoded date                             : UTC 2010-04-24 10:36:49
Tagged date                              : UTC 2010-04-24 10:36:49
Writing library                          : AVS
Format                                   : MPEG-4 Visual
Format profile                           : Simple@L1
Format settings, BVOP                    : Yes
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Codec ID                                 : 20
Duration                                 : 2h 43mn
Bit rate                                 : 891 Kbps
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 29.970 fps
Minimum frame rate                       : 29.960 fps
Maximum frame rate                       : 29.980 fps
Bits/(Pixel*Frame)                       : 0.097
Stream size                              : 1.03 GiB (87%)
Codec ID                                 : 40
Duration                                 : 2h 43mn
Nominal bit rate                         : 126 Kbps
Maximum bit rate                         : 128 Kbps
Sampling rate                            : 44.1 KHz
Material_Duration                        : 9822528
Material_StreamSize                      : 154122121
only odd thing i see is " Writing library : AVS " and when you look at normal file u see " Writing application: HandBrake 0.9.5 2011010300 " but then again that art of trojans ( no it not a virus its a trojan ) and thats fooling the system/user into thinking the file is legit.
Post Sun Jan 22, 2012 8:25 am
kappclark wrote:
Clutch wrote:
kappclark wrote:I have Ubuntu 10.04 running Serviio. I have put in all the latest plugins, but cannot play M2TS files using the Ubuntu box...they work fine on Windows XP, running same version of Serviio...The box does play all the files in the music collection...I am sure this video plm is an easy fix, just not sure where to start ... Any ideas ?
The only idea I have would be to try the sony bluray profile that Cerberus suggested. Keep in mind the extent of my knowledge on this topic is listed above (ie: close to nothing). :mrgreen:
*** Update --another poster recommended going to Ubuntu 10.10 ... so I upgraded, and just restarted new version, and the M2TS files play beautifully !! Thanks for the obvious suggestion ..
your welcomes ;)
Clutch
Post Sun Jan 22, 2012 7:52 pm
Cerberus wrote:if it wants to install special codec when u play with VLC/WMP its infected.
In this case it's a fresh install of Ubuntu and from past experience with Win Media player after a fresh OS install you may still need to install a few random codecs. I'm unfamiliar with what information one can extract from these file types with these tools. So I was hoping malicious intent would be easier to spot (wishful thinking I know). :)
Cerberus wrote:wrkvid1.mp4 header compression looks ok to me but i know that MP42 has been giving other users issues in past, but zip may have a fix.
No biggie. That's one of the ones that does play.
Cerberus wrote: novid2.avi - needs repairing use this link http://wiki.serviio.org/doku.php?id=avirepair
I ran the DivFix on novid2.avi and no go. It plays in Win or Ubuntu's media player but no go on the N2000.
Thanks again!
kappclark
Post Sun Jan 29, 2012 12:18 pm
Clutch wrote:
zip wrote:on another note, you have FFmpeg 0.5, we're now on 0.9 :-)
Noted - updating. Thanks. :mrgreen:
Just curious how to tell in linux/ubuntu what version of FFmpeg is running (I am assuming the latest, but want to verify)
adellarosa
Post Fri May 25, 2012 5:59 pm
Hey guys. So I'm really new to this - I'm not sure if this is the proper place to post this but its the only thread I see directly addressing the SMP-N200.
I am trying to add the wimp.com RSS feed to Serviio. I have downloaded and installed both wimp plugins (tried one, the other, and both), have the correct profile selected, and have updated FFMPEG to the latest version. Still when I navigate to the folder I created for WIMP on my N200, it gives me "There is no playable file." Does anyone here know of something that I am not doing properly?
Thank you all and I truly appreciate all of your hard work!!
v1p3r
Post Sun Jun 10, 2012 11:00 pm
I've just purchased a Sony SMP200 and have been fiddling with several different DLNA servers on my Ubuntu 11.10 server. Plex and Mobilitv show up fine on the Sony, however the files don't play. It looks as if Serviio is the choice Sony DLNA server however I cannot get it to show up on the Sony. I can see the SMP200 fine in the Serviio console and it shows as "green". very strange... Any ideas?
Post Sun Jun 10, 2012 11:40 pm
ty2010
Post Tue Aug 21, 2012 11:03 pm
I have an N200 US model and the only thing the BD profile would pass through is xvid avi, all other formats would report no content or bad format. I went to the Bravia 2011 Us profile and it plays everything, downside being that all MP4 and hd mkv get transcoded and show incorrect perspective(unless I had a 16/9 television), all AVIs are transcoded as well but perspective remains correct (so long as they are SD, they look better transcoded as well).
On the plus side, all mkv sd content with mpg4 level 3 main compression are muxed through as AVC 480i(as reported by the n200), regardless of sub sd resolution. Level 2 and high profiles are transcoded, no idea if the n200 would support those over DLNA. Level 4 may work but haven't tried it.
ty2010
Post Tue Aug 21, 2012 11:14 pm
zip wrote:
NoXion wrote:Anyone who has a Sony Network Media Player is told to get Serviio for the best performance.
Out of curiosity - by who?
1. There's a discussion on slick deals about it.
2. I read somewhere that Sony Home Media Server was a modified version of Serviio.
Previous
