[SOLVED] GT30 - File not Supported
russellg
Post Thu Jun 14, 2012 11:27 am
Hi, The following two files generate 'File not Supported' on my GT30'.
In a (probably useless and unrelated) attempt to make them work I have run them through virtualdub and then DivFix but still the same error. I assume it's a combination of Xvid and MP4 'stuff' causing the issue .. :?
Thanks, for any help.
FFMPEG output below.
D:\UTILS>ffmpeg.exe -i "E:\videos\file1.avi"
ffmpeg version N-36890-g67f5650 Copyright (c) 2000-2012 the FFmpeg developers
built on Jan 16 2012 22:02:45 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 34.100 / 51. 34.100
libavcodec 53. 56.105 / 53. 56.105
libavformat 53. 30.100 / 53. 30.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 59.100 / 2. 59.100
libswresample 0. 6.100 / 0. 6.100
libpostproc 51. 2.100 / 51. 2.100
Input #0, avi, from 'E:\videos\file1.avi':
encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 01:39:39.22, start: 0.000000, bitrate: 981 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 608x336 [SAR 1:1 DAR 38:21], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 32 kb/
s
D:\UTILS>ffmpeg.exe -i "E:\videos\file2.avi"
Input #0, avi, from 'E:\videos\file2.avi':
encoder : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
JUNK :
Duration: 02:12:01.65, start: 0.000000, bitrate: 1406 kb/s
420p, 608x256 [SAR 1:1 DAR 19:8], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), s16, 320
kb/s
Post Thu Jun 14, 2012 1:37 pm
Re: GT30 - File not Supported
Could you provide MediaInfo tool result in text format?
russellg
Post Thu Jun 14, 2012 1:47 pm
As requested.
Thanks, Russell
eneral
Complete name : E:\Videos\file1.avi
Format : AVI
File size : 700 MiB
Duration : 1h 39mn
Overall bit rate : 982 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 39mn
Bit rate : 842 Kbps
Width : 608 pixels
Height : 336 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.172
Stream size : 600 MiB (86%)
Writing library : XviD 64
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 39mn
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 90.3 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 177 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Complete name : E:\Videos\File2.avi
Format : AVI
Format profile : OpenDML
Format settings : rec
File size : 1.30 GiB
Duration : 2h 12mn
Overall bit rate : 1 406 Kbps
Writing application : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
Codec ID : XVID
Duration : 2h 12mn
Bit rate : 1 081 Kbps
Width : 608 pixels
Height : 256 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.290
Stream size : 1 021 MiB (77%)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2h 12mn
Bit rate mode : Constant
Bit rate : 320 Kbps
Channel(s) : 6 channels
Bit depth : 16 bits
Stream size : 302 MiB (23%)
Interleave, duration : 64 ms (1.53 video frames)
Interleave, preload duration : 192 ms
Post Thu Jun 14, 2012 3:07 pm
Seems good. Post on Panasonic support forum. (Not sure AVI/XVID/AC3 is supported, MP3 should be preferred)
Look at this:
viewtopic.php?f=13&t=6294#p45474
russellg
Post Thu Jun 14, 2012 4:02 pm
Thanks, the FFMPEG cmd referenced in the link you provided sorted out File 1, however File 2 now generates 'Audio format not supported' which you picked up regarding AC3 not being supported.
Edit: I put the second file through AviDemux and changed it from AC3 to MP3 and now it works.
Post Thu Jun 14, 2012 6:39 pm
OK, enjoy.
Sorry, I don't really know the avi limitation of Panasonic devices.
Return to Panasonic
