Running multiple instances of Serviio
narse
Post Fri Jun 15, 2012 4:43 pm
I suppose what I am really hoping to achieve is to be able to restrict what folders are available to different clients.
I thought that if I ran multiple instances of the Serviio service on different ports then each could have a different library and I could use Windows firewall (I am running Serviio on Windows Home server 2011) to restrict what IP addresses are able to connect to each.
Is this possible? i.e. is there a way of running multiple instances on different ports?
Thanks,
Rob
Post Fri Jun 15, 2012 5:04 pm
Re: Running multiple instances of Serviio
You cannot run multiple instances at once (unless you run them in virtual machines), but restricting certain folders to certain devices is coming in Serviio 1.0 via the new Access Groups feature.
narse
Post Sat Jun 16, 2012 10:22 am
Cool, thanks for the info. Looking forward to 1.0 :)
Rob
Users browsing this forum: Google [Bot] and 27 guests
