YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
grolschie
Post Sat Jun 16, 2012 2:05 am
Re: YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
Hello.
Is there any chance that you could possibly add leading zeros to the numbers please? i.e. 001, 002,..,010, 011,..,099, 100, etc. The XBox sorts these into numerical order, so I see videos out of order i.e. 1, 10-19, 2, 20-29, 3, ....
Also, I see some html special codes e.g. &amp; in the titles of the videos.
Xmantium
Post Sat Jun 16, 2012 9:36 pm
grolschie wrote:Hello.
Best to keep it two digits if thats the case, not many users will go to the last 100
Thanks for the updates jhb50!
grolschie
Post Sat Jun 16, 2012 11:06 pm
If someone retrieves all 100 items (i.e. max feeds = Unlimited), then they will see 01, 02, 03, 04, 05, 06, 07, 08, 09, 10, 100, 11, 12...
But that's cool. I won't be retrieving that many items. I wonder if it's possible to set the number of preceding 0's depending on the max number of items to retrieve i.e. if 10, 20, 30, 40 or 50, add one 0. If "Unlimited", add two 0's?
TheOne.PC
Post Sun Jun 17, 2012 11:34 am
It will be great if it will be possible to create a top100 filtering by genre. Like "dance", "rock", "metal", "pop"... =)
Post Sun Jun 17, 2012 12:31 pm
Per Microsoft
Q20: How do the "Sort by type" and "Sort by title" options work when I browse my own generated video content?
A20: The "Sort by type" option is the typical Windows Explorer view that a computer would use to show your files. It will first alphabetically sort your folders and then alphabetically sort your files. The "Sort by title" option allows you to sort all folders and files alongside each other. Both of these sort options are persistent and linked to your profile so that you do not need to set them every time. See question 21 for more information.
When I use Windows explorer, [1],[2],[10],[20],[100] sort correctly in that order without needing leading zeros. Same with 1,2,10,20,100, as they should.
Post Sun Jun 17, 2012 3:16 pm
TheOne.PC wrote:It will be great if it will be possible to create a top100 filtering by genre. Like "dance", "rock", "metal", "pop"... =)
Version 7 now has a genre option. See post 1. Note that the number of videos will vary from none to 100 based on the genre. Also fixed special character display.
grolschie
Post Sun Jun 17, 2012 9:25 pm
Per Microsoft
Well, regardless, the sort order is still messed up for Xbox all the same. Just sayin'.
seahorse
Post Mon Jun 18, 2012 1:49 pm
Thanks for the great plugin.
Works as a charm on my Samsung D5000.
Post Tue Jun 19, 2012 1:16 pm
Version 8 - Added nform=xbox option to pad title numbers to 3 digits for correct ordering on xbox
Xmantium
Post Tue Jun 19, 2012 7:09 pm
This groovy keeps evolving! :)
Excellent work jhb50
grolschie
Post Tue Jun 19, 2012 9:30 pm
jhb50 wrote:Version 8 - Added nform=xbox option to pad title numbers to 3 digits for correct ordering on xbox
Brilliant! Thanks heaps for this jhb50!
One minor issue is the displaying/handing of other alphabets/accents e.g. "Michel Teló - Ai Se Eu Te Pego - Oficial (Assim você me mata)" which appears in the log with:
012-06-20 09:21:19,937 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting extraction of url for item: [008] Michel Teló - Ai Se Eu Te Pego - Oficial (Assim você me mata)
2012-06-20 09:21:20,766 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Getting item: [008] Michel Teló - Ai Se Eu Te Pego - Oficial (Assim você me mata)
But this is a minor thing. Thanks heaps for your hard work.
Post Mon Jun 25, 2012 5:16 pm
Version 9 corrects the display of extended characters as reported in previous post. See post 1.
grolschie
Post Mon Jun 25, 2012 7:59 pm
Thank you. :D
Xmantium
Post Fri Aug 03, 2012 8:25 pm
By far this has become my most used plugin for Serviio! :D
Not sure this would be possible, since the quality can be over-ridden by using res=XXX
Can the 'Max number of feeds to retrieve' also be over-ridden?
My default in Serviio is 30, but for this plugin only i want it to be 50
Post Fri Aug 03, 2012 9:35 pm
No, a groovy can limit to less than the console value but not above it.
Just create successive feeds using the start value and they will play consecutively. 1-30 31-60 61-90 91-100
Xmantium
Post Fri Aug 03, 2012 9:49 pm
jhb50 wrote:Just create successive feeds using the start value and they will play consecutively. 1-30 31-60 61-90 91-100
I have done it like this but theres too many to list, hoping your proposal of folder options to come very soon to fix having too many online feeds, then it can be neatly organised in folders
TheOne.PC
Post Sun Aug 05, 2012 8:06 am
After upgrading to 1.0 i'm having problems
2012-08-04 22:54:04,370 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (YouTubeTop100): The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
   ... 4 more
Post Sun Aug 05, 2012 11:24 am
Verify you are using V9 of the plugin (see comments at start of the groovy)and post more of the log so I can see where the delay is occuring when parsing the feed.
TheOne.PC
Post Sun Aug 05, 2012 3:33 pm
jhb50 wrote:Verify you are using V9 of the plugin (see comments at start of the groovy)and post more of the log so I can see where the delay is occuring when parsing the feed.
I'm using the V9 of the plugin ;)
The delay starts immediatly when searching for feed updates
2012-08-05 17:25:44,817 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-08-05 17:25:44,847 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-05 17:28:33,286 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-08-05 17:29:03,293 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-08-05 17:29:33,304 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
Post Sun Aug 05, 2012 5:28 pm
V10 released to fix timeout with Serviio 1.0
Return to Available plugins
Users browsing this forum: No registered users and 130 guests
