[SOLVED] PS3 won't play WTV (Windows 7 recorded TV)
Ben595
Post Fri Jun 15, 2012 6:33 pm
My PS3 can't read wtv file. The PS3 shows that thoses files are not supported. However, I can read them with an application on my iTouch, so the file is good.
What could I try?
Post Fri Jun 15, 2012 6:54 pm
Re: PS3 won't play WTV (Windows 7 recorded TV)
Provide information about this media (see signature links : ffmpeg -i <> and MediaInfo tool result in text format)
Ben595
Post Sun Jun 17, 2012 12:20 pm
I did the procedure in your signature with ffmpeg and here what i got:
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[mpeg2video @ 0287aca0] mpeg_decode_postinit() failure
Last message repeated 6 times
Input #0, wtv, from 'aaa.wtv':
WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
Title : Enregistrement manuel
WM/OriginalReleaseTime: 2012
WM/MediaCredits : ;;;
service_provider: CBMT-DT
service_name : CBMT-DT
WM/MediaNetworkAffiliation: CBMT-DT
WM/MediaOriginalChannel: 6
WM/MediaOriginalChannelSubNumber: 1
WM/MediaOriginalBroadcastDateTime: 2012-01-22T05:00:00Z
WM/MediaOriginalRunTime: 71984227659
WM/MediaIsStereo: false
WM/MediaIsRepeat: false
WM/MediaIsLive : false
WM/MediaIsTape : false
WM/MediaIsDelay : false
WM/MediaIsSubtitled: false
WM/MediaIsMovie : false
WM/MediaIsPremiere: false
WM/MediaIsFinale: false
WM/MediaIsSAP : false
WM/MediaIsSport : false
WM/Provider : MediaCenterDefault
WM/VideoClosedCaptioning: false
WM/WMRVEncodeTime: 2012-01-22 22:00:01
WM/WMRVServiceID: !Generated!0d395eee21004835837e2b86450e70f5
WM/WMRVProgramID: !Generated!ea13952dabad4ff7acb757669e92a44e
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 0
WM/WMRVOriginalSoftPrePadding: 300
WM/WMRVOriginalSoftPostPadding: 0
WM/WMRVHardPrePadding: -300
WM/WMRVHardPostPadding: 0
WM/WMRVATSCContent: true
WM/WMRVDTVContent: true
WM/WMRVHDContent: false
Duration : 71991487678
WM/WMRVEndTime : 2012-01-23 00:00:00
WM/WMRVBitrate : 8.880537
WM/WMRVKeepUntil: -1
WM/WMRVActualSoftPrePadding: 298
WM/WMRVActualSoftPostPadding: 0
WM/WMRVContentProtected: false
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationSpan: 9223372036854775807
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : false
WM/MediaThumbWidth: 352
WM/MediaThumbHeight: 198
WM/MediaThumbStride: 1056
WM/MediaThumbRet: 0
WM/MediaThumbRatingSystem: 9
WM/MediaThumbRatingLevel: 9
WM/MediaThumbRatingAttributes: 0
WM/MediaThumbAspectRatioX: 16
WM/MediaThumbAspectRatioY: 9
WM/MediaThumbTimeStamp: -4616189618054758400
WM/MediaThumbType: 3
Duration: 01:59:58.29, start: 302.998720, bitrate: 15463 kb/s
Stream #0:0[0x1b]: Subtitle: dvb_teletext
Stream #0:1[0x1c](eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s
Stream #0:2[0x1d](es): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0:3[0x1e]: Video: mpeg2video (Main), yuv420p, 1280x720 [SAR 1:1 DAR
16:9], 15000 kb/s, 79.92 fps, 59.94 tbr, 10000k tbn, 119.88 tbc
Stream #0:4[0x0]: Attachment: mjpeg
title : TV Thumbnail
Post Mon Jun 18, 2012 7:32 am
Could you try to add this on "Play Station 3" profile section just before the <Audio ...> element ?
<Matches container="wtv" />
Ben595
Post Tue Jun 19, 2012 2:16 am
It works!
Post Tue Jun 19, 2012 7:15 am
Cool, enjoy!
This modification will be implemented in the next 1.0 version.
