ITV Player (UK only) - Web Resource
• Page 2 of 3 • 1, 2, 3
Hi, sorry to hijack your thread but I'm also having issues with programs that require age verification. I can't get them to list on the tv. Have you got any ideas what I can try or won't it work? Thanks
Re: ITV Player (UK only) - Web Resource
That is not implemented in the plugin currently.
Petr
Help translate Serviio
G60ff wrote:having issues with programs that require age verification. I can't get them to list on the tv.
Which programmes are they?
I'm not able to get Primeval to work which has a guidance rating, is there any way round this?
Cheers
Cheers
Sorry to come back to this after so long but I was wondering if there is a way to get these programs working. The one I'm trying now is called Homefront
http://www.itv.com/itvplayer/video/?Filter=Homefront
Unfortunately a high proportion of ITV programmes have some sort of guidance on them and won't show up. Has anybody found a way round this yet?
Bad news for this plugin, new changes are coming - http://www.engadget.com/2012/10/29/itv- ... v-rentals/
You can trial it here:
https://beta.itv.com/itvplayer/
Hello, I'm having difficulty making this plugin work. I'm using as an example "The big match revisited" as I can't imagine it will have any age restrictions. The url I am using is http://www.itv.com/itvplayer/video/?Filter=326904. I am using serviio 1.0.1 and compiled the ffmpeg from the serviio site (on ubuntu 12.10 64bit)
The exception it is throwing is
I noticed earlier in the log the line
2012-10-31 19:53:13,720 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
Though when I check ffmpeg it appears to be there ( I think )
- Code:
2012-10-31 19:53:44,366 WARN [FeedUpdaterThread] Failed to retrieve online item
information for rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEdldzaxdGcraEc3dqcu
bxbKapbvalc9aJdlcTb.b2ckcJd7dEc9cocqakc.dga9ch-bqKyhj-eS-5Ar1FDplCrwr&aifp=v002&
slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf play
path=mp4:production/priority/rtmpecatchup/800/C7/1-6464-0026-001/1-6464-0026-001
_the-big-match-revisited-(series-2)_tx201012_itv800_4x3-reg.mp4 swfvfy=true. It
might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFo
rmatException: Unknown video file type.
- Code:
todd@liszt:~$ ffmpeg -protocols
built on Oct 27 2012 20:28:29 with gcc 4.7.2
configuration:
Supported file protocols:
Input:
applehttp
cache
concat
crypto
file
gopher
hls
http
httpproxy
mmsh
mmst
pipe
rtmp
rtmphttp
rtmpt
rtp
tcp
udp
Output:
file
gopher
http
httpproxy
md5
pipe
rtmp
rtmphttp
rtmpt
rtp
tcp
udp
those are (I think) the built-in rtmp functionalities, you have to link librtmp for it to work with Serviio
Petr
Looks like they have changed urls ect now.
Is it possible for a plugin upgrade ?
magnoman wrote:Looks like they have changed urls ect now.
My test runs, what URL are you using?
Petr
Everytime i try to put your urls in from the first page i get a referal to
https://www.itv.com/itvplayer/
This has the itv player beta.
I do not have an option for a video the new format i get is
For example.
https://www.itv.com/itvplayer/the-x-fac ... -results-8
***** Nevermind i cleared the cookies and now i have the old site back.. sorry
For example.
It appears ITV are using the new site that was in Beta
Updated the plugin to work with the new itv [player (beta). Report any issues, I tried it on a couple shows and it seems to parse correctly. It should skip the paid content (rent).
Petr
Excellent, I'll update the contents in http://www.serviiDB.com very soon as the new site uses a different URL format
Edit: Plugin works great!! Added some popular shows in serviiDB, so fire up ServiiDroid, ServiiWP or WebUI to add it on!
Have upgraded to the latest ITV plugin (31/12/2012) and serviio 1.1 but am seeing the occasional program not working (most programs seem to be fine though). Here is the log:
2013-01-07 22:09:40,881 DEBUG [OnlineLibraryManager] Resource https://www.itv.com/itvplayer/doors-open not in cache yet, loading it
2013-01-07 22:09:40,881 DEBUG [WebResourceParser] Parsing web resource 'https://www.itv.com/itvplayer/doors-open'
2013-01-07 22:09:40,883 DEBUG [FeedItemUrlExtractor] Playlist extractor: - transmitted from WebResourceParser - playlistUrl: null
2013-01-07 22:09:40,884 DEBUG [WebResourceParser] Found matching url extractor (ITVPlayer (UK only)) for resource https://www.itv.com/itvplayer/doors-open
2013-01-07 22:09:40,884 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Starting parsing resource: https://www.itv.com/itvplayer/doors-open
2013-01-07 22:09:42,368 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ITVPlayer (UK only)): String index out of range: -1
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1943)
at java.lang.String.substring(String.java:1916)
at java_lang_String$substring$0.call(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at ITVPlayerExtractor.extractItems(ITVPlayer.groovy:96)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:679)
Any ideas?
Any ideas?
Updated the plugin to fix the above
Petr
All working. Thanks for the quick fix.
scot
scot
Hi, does anyone know the URL for catch-up? I had it once, but restored my pc and cant remember it.
I am trying https://www.itv.com/itvplayer/categorie ... r/catch-up but so far no luck.
What I had last time gave me a list of recent TV programmes.
Serviio 1.1 | Intel i7 2600K 3.4GHz | Windows 7 | SONY Bravia KDL-40W5500
Users browsing this forum: No registered users and 216 guests
