A.P.P for Serviio 1.4.1 - Last Update (24/10/2013)
How often do you check to see if there is a plugin pack update?
Daily
37
19%
Weekly
77
39%
Monthly
63
32%
Never
20
10%
Total votes : 197
JerseyJoe123
Post Thu Mar 29, 2012 2:50 am
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (22/03
Could you update the Crackle plugin to the v2.0 version that mike_metro posted on March 15th? The Plugin Pack description show it containing an older version.
Thanks!
WildRushSykes
Post Thu Mar 29, 2012 1:23 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (29/03
Thanks for the heads up jerseyjoe all fixed :)
Xmantium
Post Sat Apr 21, 2012 5:44 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (16/04
Can you please add zips amazing ITV Player, its one plugin ive been waiting for!
Post Sat Apr 21, 2012 6:11 pm
Xmantium wrote:Can you please add zips amazing ITV Player, its one plugin ive been waiting for!
Can you confirm it works for you first? I just put it together yesterday night and didn't really test properly.
Xmantium
Post Sat Apr 21, 2012 6:46 pm
Works fine for me Zip on my QNAP Linux Nas running 0.6.2
Im using urls without "%20", seems to work on browser and works on Serviio too, urls looks cleaner too :D
Example
http://www.itv.com/itvplayer/video/?Filter=britainsgottalent
http://www.itv.com/itvplayer/video/?Filter=60minutemakeover
http://www.itv.com/itvplayer/video/?Filter=TheCube
WildRushSykes
Post Sun Apr 22, 2012 2:42 am
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (24/04
All done Xm will test it out for myself see what its like ;)
rjscott2005
Post Sun Apr 22, 2012 9:35 pm
Hi-
I read the howto wiki but I didn't see instructions for OS X. I can't seem to find a plugins folder on my Mac. Can anyone point me in the right direction?
Post Sun Apr 22, 2012 11:08 pm
rjscott2005 wrote:Hi-
http://www.serviio.org/index.php?option ... icle&id=42
peter1212
Post Tue May 15, 2012 12:36 pm
Re: All Plugins Pack For Serviio 0.6.2 - Last Updated (14/05
I can't download plugin pack.
A file permissions error has occurred. Please check the permissions on the script and the directory it is in and try again.
Can someone give a mirror, or reupload? Thx.
WildRushSykes
Post Tue May 15, 2012 1:32 pm
Same issue here seems something server side has gone wrong im sure zip will look into it ill try and reupload aswell. Thanks for the heads up :D
EDIT: Reuploaded the file still having the same issue. Seems the only way to fix it lies with Zip. Looks like Zips file host has some issues im sure it will be resolved soon :D
Ive provided a mirror until the issue is fixed ive used the guys at zippyshare to host just click the link then click download now.
DEIT 2: Seems like the issues been fixed by weird voodoo magic or something :) Will provide updates as per usual now.
Xmantium
Post Sat Jun 16, 2012 9:55 pm
Re: All Plugins Pack For Serviio - Last Updated (08/06/12)
Top 100 music has been updated to v6 - Probably one of my most used plugin
New CNN updated too
South Park Studios is now DISCONTINUED, he has merged it with Comedy Central plugin
Think its best to also put plugin status next to it so users have head start why its not working
For example TrailerAddict is not working, so you can put status saying in amber (but still provide the plugin as user could edit it)
TrailerAddicts - 08/02/2012 - NOT CURRENTLY WORKING
Confimed known currently not working are:
M6 and W9 replay
TrailerAddicts
Vimeo
Is it also possible to change from RAR to zip file, i got newbie friends at work who never used WinRAR, i zip it for them using Dropbox :roll:
WildRushSykes
Post Sun Jun 17, 2012 1:09 pm
Re: All Plugins Pack For Serviio - Last Updated (17/06/12)
damn you Xm creating more work for me lol. Done what you suggested but it will be important for each plugin maker to pm me when they release new versions and if theres a problem with one as i dont use all the plugins in the pack :)
Xmantium
Post Sun Jun 17, 2012 1:36 pm
Oops sorry! :lol: I always keep an eye on the forums, some plugin developers dont use their plugins as much, the forum feedback good source of information whats working and whats not. Thanks for the zip(compression not the admin :D) version, think most users will download this.
Im hoping in future there will be a repo XBMC/Cydia style of way getting the plugins and it auto updates
WildRushSykes
Post Tue Jun 19, 2012 1:34 pm
Cant see why not cant be that hard to incorporate a feature in serviio that connects to a secure repo where the latest versions are and extract them to the correct folder every time it launches
Powernout
Post Sun Jul 08, 2012 10:16 am
Re: All Plugins Pack For Serviio - Last Updated (07/07/12)
Hey guys,
I've been unsuccessful in finding a " How to" with regards to setting up online sources. Can anybody direct me to a setup guide or something? I'd like to see what these plugins can do!
WildRushSykes
Post Sun Jul 08, 2012 11:31 am
Hi Powernout,
There is a link in the OP with a link to the guide and also a howto guide within the plugin pack itself :)
http://wiki.serviio.org/doku.php?id=servio_plugins
Powernout
Post Sun Jul 08, 2012 1:31 pm
Thanks WildRushSykes,
Yep, those I found. But that surpasses my understanding and points towards the development of these plugins. I simply need to understand what I need to do to activate these plugins!
From the 1st page of this posting, I downloaded your plugin pack, unzipped it, copied the files into the C:\Program Files\Serviio\plugins folder, so now I have 67 *.groovy files there. Let's say I want to get the Syfy.groovy working, what do I do? In the Servio Console, I go to Library - Online sources. Then I can press the "Add" button. But what do I add???
WildRushSykes
Post Sun Jul 08, 2012 1:51 pm
most of the links you need to add are in the individual plugins thread as there is no space to add 67 plugins worth of links here lol. If you go to available plugins and go to the plugin you need setup it should have the setup instructions you need :)
Post Mon Aug 13, 2012 9:12 pm
Re: All Plugins Pack For Serviio 1.0.1 - Last Updated (13/08
I have no confidence that the plugins in this pack are current as of the 8/13 update.
3 of my included plugins are obsolete versions and people using the pack are reporting problems with Serviio V1 which have been corrected.
Specifically hahasports is dated May12 but version 5 was released on May23, Ilive is dated May4 but was updated on Aug5, and Top100 is dated June 26 but was also updated on Aug. 5. I have not checked the currency of any others.
People using the pack should verify they are using the current versions as per the plugins forum before posting any problems. In my case Top100, Ilive and hahasport as well as HDTrailers and Castalba have been further updated as of 8/13 after posting of the pack.
I will be adding Version number stamps to the DEBUG log for my groovys so that bug reports can be verified as being with the current version.
WildRushSykes
Post Mon Aug 13, 2012 11:57 pm
Re: All Plugins Pack For Serviio 1.0.1 - Last Updated (14/08
Ive added all your plugins jhb50 and re added all other plugins aswell to make sure and put a notification in the first post and added the time it was updated so that any new plugins added after that time people will know they are not in the pack most of your new plugins were added today and the pack was updated at around 1am this morning that's why they weren't included :D
Return to Available plugins
