Profile for Logitech Revue?
Crouton
Post Wed May 30, 2012 10:28 am
I know I'm a minority in having the Logitech Revue but I like it. With that said I do have some issues with streaming to the Revue versus my XBOX and I'm wondering if its because I have to choose the Default DLNA profile rather than a Revue profile which currently doesn't exist. The problems I'm running into and I hope can be resolved through this feature have to do with videos audio being off sync on a fairly consistent basis whereas on my XBOX the audio/video are in perfect sync.
Long story short there's a problem here and a proposed solution in way of an added feature, help?
--Crouton
grolschie
Post Sat Jun 23, 2012 5:13 am
Re: Profile for Logitech Revue?
How about we try to help you create a custom profile for your device?
1). Can you search and find anything relating to your Logitech device in the C:\Program Files\Serviio\log\serviio.log file please? Specifically the user-agent string or "name=". Thanks. You might need to turn on detailed logging.
2). Then you will need to find out what formats your device supports.
3). Specifically, what filetypes are playing out of sync?
DarkDot
Post Sun Sep 02, 2012 6:38 pm
I know I'm new here but I'd love to do the same. Here is all the logitec revue information:
Logitech Revue
AVI/DIVX - Video: MPEG4 ASP, XVid, DivX4/5/6; Audio: MP3, AC3, PCM.
MKV - Video: H.264; Audio: PCM, MP3, AAC (multichannel), AC3, Vorbis;
MP4/M4V - Video: H.264 (HiP 4.1), MPEG4 ASP; Audio: AAC, AC3;
MOV - Video: H.264(HiP 4.1); Audio: AAC, MP3;
3GPP - Video: H.263, H.264; Audio: AAC, MP3;
FLV - Video: H.263, H.264, VP6; Audio: MP3, AAC;
TS/MTS/MPEGTS/M2TS - Video: MPEG4 ASP, H.264(HiP 4.1), WMV9/VC-1; Audio: AAC, AC3, WMA;
WMV/ASF - Video: Windows Media Video 9 (WMV9), VC-1; Audio: WMA;
Logitech Revue notes and issues:
MPEG1 and MPEG2 are NOT supported.
DTS sound is NOT supported.
VOB is supported but only audio.
DivX3.11 is NOT supported.
WMV version lower then 9 is NOT supported. WTV is NOT supported.
MJPEG is not supported.
10-bit video (H.264 Hi10P) is NOT supported.
Zoom is not supported.
I believe this should be enough to create a profile. Also in that profile I'd love to increase the pixel size of the cover art to maybe 500x500 since currently the cover art that shows with the defualt dlna client is very low resolution.
Thank you for all your help in advance!
grolschie
Post Mon Sep 03, 2012 9:51 pm
Hi. Did you want to make a start on a profile, and we could possibly help if you have problems?
Return to Feature requests
