VIDEO_TS Folder
kirkm
Post Sat Jun 23, 2012 6:11 am
VIDEO_TS Folder
Apologies if this is a silly question, and I could just try it and see, but interested in any replies/tips.
Can you stream the .vob files in a VIDEO-TS folder?
Post Sat Jun 23, 2012 3:05 pm
Re: VIDEO_TS Folder
yes, you will see them as separate files though
kirkm
Post Sun Jun 24, 2012 2:39 am
Re: VIDEO_TS Folder
Thanks, is there a means to show them all - or is the best solution convert to a single file format?
Post Sun Jun 24, 2012 10:05 am
Re: VIDEO_TS Folder
you will see them all, but as separate files... you could join them, there are tools for that (without reencoding)
Post Sun Jun 24, 2012 4:53 pm
Re: VIDEO_TS Folder
Just FYI I've tried a number of tools in the past (JoinVOBfiles,Combimovie,Streamclip,EastJoiner,DVDDecrypter) without success. Usually the timestamps get messed up and the total time is wrong or the vobs are in the wrong order. Only one that worked for me was the (paid) Womble editor...add the vobs and output a new mpeg2 movie.
If you are successful please post back what worked for you.
Post Sun Jun 24, 2012 6:27 pm
Re: VIDEO_TS Folder
jhb50 wrote:Just FYI I've tried a number of tools in the past (JoinVOBfiles,Combimovie,Streamclip,EastJoiner,DVDDecrypter) without success. Usually the timestamps get messed up and the total time is wrong or the vobs are in the wrong order. Only one that worked for me was the (paid) Womble editor...add the vobs and output a new mpeg2 movie.
Yes, I think timestamp are in "IFO" companion files, so to merge VIDEO_TS files, need .vob and .ifo source. (IFO is a part of DLNA, but don't know how to manage this).
http://en.wikipedia.org/wiki/VOB
kirkm
Post Sat Jun 30, 2012 9:37 am
Re: VIDEO_TS Folder
Thanks to everyone for their replies.
Haven't had much success with anything. The easiest solution seems to be to convert to mp4, and between Handbrake
and tmpGenc 4, Handbrake was best.
Return to General discussion
