Comedy Central
insane822
Post Thu May 31, 2012 5:32 pm
Comedy Central
1) This will probably only work from the US, but I cannot confirm.
2) Web Resource
3) Serviio does not support "playlists", so each episode will be in a few different segments (files), but should play in sequential order. Once Serviio adds support, I'll update the plugin.
* Currently Supports:
The Daily Show:
http://www.thedailyshow.com/full-episodes/
Colbert Nation:
http://www.colbertnation.com/full-episodes/
South Park:
Just replace the season number (16) with the season number you want to add.
Season 16: http://www.southparkstudios.com/feeds/f ... 27dc7e0d5c
* Updated October 7, 2012
ComedyCentral.groovy
(10.8 KiB) Downloaded 2251 times
seahorse
Post Sun Jun 17, 2012 5:08 pm
Re: Comedy Central (Updated 6/14/12)
All links are working fine in Belgium (Europe)
Well done!
J K Kubius
Post Mon Jun 25, 2012 5:15 pm
Re: Comedy Central
Using this plug-in I encountered a problem regarding date parsing:
2012-06-25 19:06:52,979 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 33)
2012-06-25 19:06:52,979 DEBUG [OnlineLibraryManager] Resource http://www.thedailyshow.com/full-episodes/ not in cache yet, loading it
2012-06-25 19:06:52,979 DEBUG [WebResourceParser] Parsing web resource 'http://www.thedailyshow.com/full-episodes/'
2012-06-25 19:06:52,979 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.thedailyshow.com/full-episodes/
2012-06-25 19:06:52,980 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.thedailyshow.com/full-episodes/
2012-06-25 19:06:54,632 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-06-25 19:06:55,094 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): Unparseable date: "Jun 22, 2012"
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Caused by: java.text.ParseException: Unparseable date: "Jun 22, 2012"
   at java.text.DateFormat.parse(Unknown Source)
   at org.codehaus.groovy.runtime.DefaultGroovyStaticMethods.parse(DefaultGroovyStaticMethods.java:181)
   at org.codehaus.groovy.runtime.metaclass.ReflectionMetaMethod.invoke(ReflectionMetaMethod.java:51)
   at org.codehaus.groovy.runtime.metaclass.NewStaticMetaMethod.invoke(NewStaticMetaMethod.java:51)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120)
   at ComedyCentral.getFeeds(ComedyCentral.groovy:190)
   at ComedyCentral$getFeeds.callCurrent(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
   at ComedyCentral.extractItems(ComedyCentral.groovy:53)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
   ... 4 more
This is very similar to the problem I had with escapist plugin @ http://forum.serviio.org/viewtopic.php?f=20&t=4820 however I don't know how mike_metro solved the issue. I'm running windows 7 64-bit Home Premium SK, so it's Slovak localization with dd.mm.yyyy date format.
insane822
Post Tue Jun 26, 2012 9:16 pm
Re: Comedy Central
I have attached an update to the first post. If that does not fix the issue, let me know. :)
J K Kubius
Post Wed Jun 27, 2012 5:27 am
Re: Comedy Central
Unfortunately the update didn't solve my issue. Error looks pretty much the same:
2012-06-27 07:21:40,089 DEBUG [OnlineLibraryManager] Resource http://www.thedailyshow.com/full-episodes/ not in cache yet, loading it
2012-06-27 07:21:40,089 DEBUG [WebResourceParser] Parsing web resource 'http://www.thedailyshow.com/full-episodes/'
2012-06-27 07:21:40,089 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.thedailyshow.com/full-episodes/
2012-06-27 07:21:40,089 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.thedailyshow.com/full-episodes/
2012-06-27 07:21:41,653 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
   at ComedyCentral.getFeeds(ComedyCentral.groovy:192)
   ... 4 more
And thank you for fast response, I really appreciate it. :)
insane822
Post Fri Jun 29, 2012 2:16 am
Re: Comedy Central
Updated
J K Kubius
Post Wed Jul 04, 2012 6:06 pm
Re: Comedy Central
Sorry for the late reply - updated version is working fine for me. Thank you very much for this plugin, now i can finally leave my computer out of the living room :)
patters
Post Sat Jul 07, 2012 11:59 am
Re: Comedy Central
Didn't seem to work for me in the UK. The direct links to the videos on the web don't work either so I guess the UK is locked out.
insane822
Post Sat Jul 07, 2012 10:44 pm
Re: Comedy Central
patters wrote:Didn't seem to work for me in the UK. The direct links to the videos on the web don't work either so I guess the UK is locked out.
Strange, some others reported success in Europe, but I guess they blocked the UK. :(
If this URL doesn't work, then yeah you're blocked.
http://mtvnmobile.vo.llnwd.net/kip0/_pxn=0+_pxK=18639+_pxE=/44620/mtvnorigin/gsp.comedystor/com/dailyshow/TDS/season_17/episode_107/ds_17107_act2_1280x720_3500_h32.mp4
kyomi7502
Post Sun Jul 15, 2012 6:08 pm
Re: Comedy Central
Interesting problem, I just figured out all of this and tested it and it only works on the first video.
I've put in the website for The Daily show as instructed as a web resource and put the .groovy file in the serviio/plugins directory.
It works successfully on the first video file and plays through no problem, but when that segment ends and it tries getting the next one, it always comes back with a error.
(I'm using a ps3) "Media Server Error: An HTTP error (500) has occured"
It shows that on every video after and I can't even get the first segment to work again. I'm testing it on The Colbert Report list now too.
Edit: The Colbert Report does not work either, it gives the same exact symptoms. It will play the first segment just fine, but will not play the rest of them
Edit 2: Alright.. I'm completely confused. After testing The Colbert Report, I tried The Daily Show again but starting on "Act 2" and that worked perfectly. No problems when loading the next "Act"
insane822
Post Sun Jul 15, 2012 7:08 pm
Re: Comedy Central
I've tested two different clients on my end, and it appears to be working. If you're still having issues, can you post a debug log?
CigDangle
Post Sun Sep 02, 2012 3:59 am
Re: Comedy Central
I have been having issues with South Park. Colbert works fine, and SP was working prior to my Serviio 1.x upgrade.
Any ideas?
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
Opiomi
Post Wed Sep 05, 2012 3:53 pm
Re: Comedy Central
South Park doesn't seem to be working anymore. Anyone else having this problem?
peter1212
Post Sun Sep 09, 2012 11:37 pm
Re: Comedy Central
Fix the Southpark issue
Regex from Java destroys the newline in the json.
I do the replace with the java replace and substring.
ComedyCentral Plugin Southpark fixed
(10.33 KiB) Downloaded 1229 times
CigDangle
Post Sat Sep 22, 2012 1:33 am
Re: Comedy Central
Looks like the plug-in is not working again...
Anyone else having the issue? Seems to be the day for stuff breaking - Hulu is busted as well.
flancur
Post Sat Sep 22, 2012 9:53 am
Re: Comedy Central
Hi everyone,
as this is my first post in this forum, I want to thank everyone who's involved in developing this great media server. Serviio is so much fun working with.
Back to business ;)
I notice since two days or so, that my Daily Show and Colbert Report link is not showing up anymore in the list. They both worked great for a couple of weeks since I use the Comedy Central plugin (the original, not the South Park adjusted). But now they both are gone, but I didn't changed anything in my setup sind then, that's why I presume that something with the online ressource changed.
Here my debug log with the part, where he tries to load Daily Show and Colbert Report. I don't really get the error message, maybe one of you? Is anybody else having problems with loading these shows via the CC plugin?
2012-09-22 11:20:18,222 DEBUG [OnlineLibraryManager] Resource http://www.thedailyshow.com/full-episodes/ not in cache yet, loading it
2012-09-22 11:20:18,222 DEBUG [WebResourceParser] Parsing web resource 'http://www.thedailyshow.com/full-episodes/'
2012-09-22 11:20:18,223 DEBUG [MediaItemDAOImpl] Getting file of media item 22270
2012-09-22 11:20:18,223 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22270) and extractor EMBEDDED
2012-09-22 11:20:18,224 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22270) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,237 DEBUG [FeedItemUrlExtractor] Playlist extractor:   - transmitted from WebResourceParser - playlistUrl: null
2012-09-22 11:20:18,238 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.thedailyshow.com/full-episodes/
2012-09-22 11:20:18,238 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.thedailyshow.com/full-episodes/
2012-09-22 11:20:18,256 DEBUG [MediaItemDAOImpl] Getting file of media item 22271
2012-09-22 11:20:18,256 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22271) and extractor EMBEDDED
2012-09-22 11:20:18,256 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22271) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,275 DEBUG [MediaItemDAOImpl] Getting file of media item 22272
2012-09-22 11:20:18,275 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22272) and extractor EMBEDDED
2012-09-22 11:20:18,275 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22272) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,293 DEBUG [MediaItemDAOImpl] Getting file of media item 22273
2012-09-22 11:20:18,293 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22273) and extractor EMBEDDED
2012-09-22 11:20:18,294 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22273) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,312 DEBUG [MediaItemDAOImpl] Getting file of media item 22274
2012-09-22 11:20:18,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22274) and extractor EMBEDDED
2012-09-22 11:20:18,313 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22274) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,331 DEBUG [MediaItemDAOImpl] Getting file of media item 22275
2012-09-22 11:20:18,331 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22275) and extractor EMBEDDED
2012-09-22 11:20:18,331 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22275) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,350 DEBUG [MediaItemDAOImpl] Getting file of media item 22276
2012-09-22 11:20:18,350 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22276) and extractor EMBEDDED
2012-09-22 11:20:18,351 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22276) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,371 DEBUG [MediaItemDAOImpl] Getting file of media item 22277
2012-09-22 11:20:18,371 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22277) and extractor EMBEDDED
2012-09-22 11:20:18,371 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22277) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,395 DEBUG [MediaItemDAOImpl] Getting file of media item 22278
2012-09-22 11:20:18,396 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22278) and extractor EMBEDDED
2012-09-22 11:20:18,397 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22278) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,416 DEBUG [MediaItemDAOImpl] Getting file of media item 22279
2012-09-22 11:20:18,416 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22279) and extractor EMBEDDED
2012-09-22 11:20:18,416 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22279) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,436 DEBUG [MediaItemDAOImpl] Getting file of media item 22280
2012-09-22 11:20:18,436 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22280) and extractor EMBEDDED
2012-09-22 11:20:18,436 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22280) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,455 DEBUG [MediaItemDAOImpl] Getting file of media item 22281
2012-09-22 11:20:18,455 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22281) and extractor EMBEDDED
2012-09-22 11:20:18,455 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22281) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,478 DEBUG [MediaItemDAOImpl] Getting file of media item 22282
2012-09-22 11:20:18,478 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22282) and extractor EMBEDDED
2012-09-22 11:20:18,478 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22282) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,499 DEBUG [MediaItemDAOImpl] Getting file of media item 22283
2012-09-22 11:20:18,499 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22283) and extractor EMBEDDED
2012-09-22 11:20:18,500 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22283) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,530 DEBUG [MediaItemDAOImpl] Getting file of media item 22284
2012-09-22 11:20:18,530 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22284) and extractor EMBEDDED
2012-09-22 11:20:18,531 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22284) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,550 DEBUG [MediaItemDAOImpl] Getting file of media item 22285
2012-09-22 11:20:18,550 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22285) and extractor EMBEDDED
2012-09-22 11:20:18,550 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22285) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,570 DEBUG [MediaItemDAOImpl] Getting file of media item 22286
2012-09-22 11:20:18,570 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22286) and extractor EMBEDDED
2012-09-22 11:20:18,570 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22286) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,589 DEBUG [MediaItemDAOImpl] Getting file of media item 22287
2012-09-22 11:20:18,589 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22287) and extractor EMBEDDED
2012-09-22 11:20:18,589 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22287) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,607 DEBUG [MediaItemDAOImpl] Getting file of media item 22288
2012-09-22 11:20:18,607 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22288) and extractor EMBEDDED
2012-09-22 11:20:18,608 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22288) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,628 DEBUG [MediaItemDAOImpl] Getting file of media item 22289
2012-09-22 11:20:18,628 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22289) and extractor EMBEDDED
2012-09-22 11:20:18,628 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22289) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,650 DEBUG [MediaItemDAOImpl] Getting file of media item 22290
2012-09-22 11:20:18,650 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22290) and extractor EMBEDDED
2012-09-22 11:20:18,651 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22290) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,670 DEBUG [MediaItemDAOImpl] Getting file of media item 22291
2012-09-22 11:20:18,670 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22291) and extractor EMBEDDED
2012-09-22 11:20:18,670 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22291) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,690 DEBUG [MediaItemDAOImpl] Getting file of media item 22292
2012-09-22 11:20:18,690 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22292) and extractor EMBEDDED
2012-09-22 11:20:18,690 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22292) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,709 DEBUG [MediaItemDAOImpl] Getting file of media item 22293
2012-09-22 11:20:18,709 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22293) and extractor EMBEDDED
2012-09-22 11:20:18,709 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22293) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,727 DEBUG [MediaItemDAOImpl] Getting file of media item 22294
2012-09-22 11:20:18,727 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22294) and extractor EMBEDDED
2012-09-22 11:20:18,728 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22294) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,748 DEBUG [MediaItemDAOImpl] Getting file of media item 22295
2012-09-22 11:20:18,748 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22295) and extractor EMBEDDED
2012-09-22 11:20:18,748 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22295) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,769 DEBUG [MediaItemDAOImpl] Getting file of media item 22296
2012-09-22 11:20:18,770 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22296) and extractor EMBEDDED
2012-09-22 11:20:18,770 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22296) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,790 DEBUG [MediaItemDAOImpl] Getting file of media item 22297
2012-09-22 11:20:18,791 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22297) and extractor EMBEDDED
2012-09-22 11:20:18,791 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22297) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,809 DEBUG [MediaItemDAOImpl] Getting file of media item 22298
2012-09-22 11:20:18,809 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22298) and extractor EMBEDDED
2012-09-22 11:20:18,810 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22298) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,832 DEBUG [MediaItemDAOImpl] Getting file of media item 22299
2012-09-22 11:20:18,832 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22299) and extractor EMBEDDED
2012-09-22 11:20:18,832 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22299) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,850 DEBUG [MediaItemDAOImpl] Getting file of media item 22300
2012-09-22 11:20:18,851 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22300) and extractor EMBEDDED
2012-09-22 11:20:18,851 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22300) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,870 DEBUG [MediaItemDAOImpl] Getting file of media item 22301
2012-09-22 11:20:18,870 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22301) and extractor EMBEDDED
2012-09-22 11:20:18,870 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22301) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,891 DEBUG [MediaItemDAOImpl] Getting file of media item 22302
2012-09-22 11:20:18,891 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22302) and extractor EMBEDDED
2012-09-22 11:20:18,892 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22302) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,914 DEBUG [MediaItemDAOImpl] Getting file of media item 22303
2012-09-22 11:20:18,915 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22303) and extractor EMBEDDED
2012-09-22 11:20:18,915 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22303) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,935 DEBUG [MediaItemDAOImpl] Getting file of media item 22304
2012-09-22 11:20:18,935 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22304) and extractor EMBEDDED
2012-09-22 11:20:18,935 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22304) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,954 DEBUG [MediaItemDAOImpl] Getting file of media item 22305
2012-09-22 11:20:18,954 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22305) and extractor EMBEDDED
2012-09-22 11:20:18,954 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22305) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,973 DEBUG [MediaItemDAOImpl] Getting file of media item 22306
2012-09-22 11:20:18,974 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22306) and extractor EMBEDDED
2012-09-22 11:20:18,974 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22306) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:18,992 DEBUG [MediaItemDAOImpl] Getting file of media item 22307
2012-09-22 11:20:18,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22307) and extractor EMBEDDED
2012-09-22 11:20:18,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22307) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,011 DEBUG [MediaItemDAOImpl] Getting file of media item 22308
2012-09-22 11:20:19,011 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22308) and extractor EMBEDDED
2012-09-22 11:20:19,011 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22308) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,029 DEBUG [MediaItemDAOImpl] Getting file of media item 22309
2012-09-22 11:20:19,029 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22309) and extractor EMBEDDED
2012-09-22 11:20:19,029 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22309) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,047 DEBUG [MediaItemDAOImpl] Getting file of media item 22310
2012-09-22 11:20:19,047 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22310) and extractor EMBEDDED
2012-09-22 11:20:19,047 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22310) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,064 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): null
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.NullPointerException
   at java.io.Reader.<init>(Unknown Source)
   at java.io.InputStreamReader.<init>(Unknown Source)
   at org.serviio.util.StringUtils.readStreamAsString(StringUtils.java:65)
   at org.serviio.library.online.AbstractUrlExtractor.readResponse(AbstractUrlExtractor.java:162)
   at org.serviio.library.online.AbstractUrlExtractor.openURL(AbstractUrlExtractor.java:147)
   at org.serviio.library.online.AbstractUrlExtractor.openURL(AbstractUrlExtractor.java:129)
   at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite$PogoCachedMethodSiteNoUnwrapNoCoerce.invoke(PogoMetaMethodSite.java:267)
   at org.codehaus.groovy.runtime.callsite.PogoMetaMethodSite.callCurrent(PogoMetaMethodSite.java:52)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:145)
   at ComedyCentral.getFeeds(ComedyCentral.groovy:182)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
2012-09-22 11:20:19,075 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 42)
2012-09-22 11:20:19,076 DEBUG [MediaItemDAOImpl] Getting file of media item 22311
2012-09-22 11:20:19,076 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22311) and extractor EMBEDDED
2012-09-22 11:20:19,076 DEBUG [OnlineLibraryManager] Resource http://www.colbertnation.com/full-episodes/ not in cache yet, loading it
2012-09-22 11:20:19,076 DEBUG [WebResourceParser] Parsing web resource 'http://www.colbertnation.com/full-episodes/'
2012-09-22 11:20:19,076 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22311) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,076 DEBUG [FeedItemUrlExtractor] Playlist extractor:   - transmitted from WebResourceParser - playlistUrl: null
2012-09-22 11:20:19,076 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.colbertnation.com/full-episodes/
2012-09-22 11:20:19,077 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.colbertnation.com/full-episodes/
2012-09-22 11:20:19,096 DEBUG [MediaItemDAOImpl] Getting file of media item 22312
2012-09-22 11:20:19,096 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22312) and extractor EMBEDDED
2012-09-22 11:20:19,097 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22312) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,115 DEBUG [MediaItemDAOImpl] Getting file of media item 22313
2012-09-22 11:20:19,115 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22313) and extractor EMBEDDED
2012-09-22 11:20:19,115 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22313) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,133 DEBUG [MediaItemDAOImpl] Getting file of media item 22314
2012-09-22 11:20:19,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22314) and extractor EMBEDDED
2012-09-22 11:20:19,134 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22314) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,155 DEBUG [MediaItemDAOImpl] Getting file of media item 22315
2012-09-22 11:20:19,156 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22315) and extractor EMBEDDED
2012-09-22 11:20:19,156 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22315) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,174 DEBUG [MediaItemDAOImpl] Getting file of media item 22316
2012-09-22 11:20:19,174 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22316) and extractor EMBEDDED
2012-09-22 11:20:19,174 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22316) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,192 DEBUG [MediaItemDAOImpl] Getting file of media item 22317
2012-09-22 11:20:19,192 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22317) and extractor EMBEDDED
2012-09-22 11:20:19,193 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22317) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,210 DEBUG [MediaItemDAOImpl] Getting file of media item 22318
2012-09-22 11:20:19,211 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22318) and extractor EMBEDDED
2012-09-22 11:20:19,211 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22318) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,234 DEBUG [MediaItemDAOImpl] Getting file of media item 22319
2012-09-22 11:20:19,235 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22319) and extractor EMBEDDED
2012-09-22 11:20:19,235 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22319) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,253 DEBUG [MediaItemDAOImpl] Getting file of media item 22320
2012-09-22 11:20:19,253 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22320) and extractor EMBEDDED
2012-09-22 11:20:19,253 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22320) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,273 DEBUG [MediaItemDAOImpl] Getting file of media item 22321
2012-09-22 11:20:19,274 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22321) and extractor EMBEDDED
2012-09-22 11:20:19,274 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22321) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,294 DEBUG [MediaItemDAOImpl] Getting file of media item 22322
2012-09-22 11:20:19,294 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22322) and extractor EMBEDDED
2012-09-22 11:20:19,294 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22322) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,317 DEBUG [MediaItemDAOImpl] Getting file of media item 22323
2012-09-22 11:20:19,317 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22323) and extractor EMBEDDED
2012-09-22 11:20:19,317 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22323) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,335 DEBUG [MediaItemDAOImpl] Getting file of media item 22324
2012-09-22 11:20:19,335 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22324) and extractor EMBEDDED
2012-09-22 11:20:19,335 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22324) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,355 DEBUG [MediaItemDAOImpl] Getting file of media item 22325
2012-09-22 11:20:19,356 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22325) and extractor EMBEDDED
2012-09-22 11:20:19,356 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22325) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,374 DEBUG [MediaItemDAOImpl] Getting file of media item 22326
2012-09-22 11:20:19,374 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22326) and extractor EMBEDDED
2012-09-22 11:20:19,375 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22326) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,393 DEBUG [MediaItemDAOImpl] Getting file of media item 22327
2012-09-22 11:20:19,393 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22327) and extractor EMBEDDED
2012-09-22 11:20:19,393 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22327) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,415 DEBUG [MediaItemDAOImpl] Getting file of media item 22328
2012-09-22 11:20:19,415 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22328) and extractor EMBEDDED
2012-09-22 11:20:19,416 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22328) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,438 DEBUG [MediaItemDAOImpl] Getting file of media item 22329
2012-09-22 11:20:19,439 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22329) and extractor EMBEDDED
2012-09-22 11:20:19,439 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22329) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,457 DEBUG [MediaItemDAOImpl] Getting file of media item 22330
2012-09-22 11:20:19,457 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22330) and extractor EMBEDDED
2012-09-22 11:20:19,458 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22330) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,476 DEBUG [MediaItemDAOImpl] Getting file of media item 22331
2012-09-22 11:20:19,476 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22331) and extractor EMBEDDED
2012-09-22 11:20:19,477 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22331) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,688 DEBUG [MediaItemDAOImpl] Getting file of media item 22332
2012-09-22 11:20:19,689 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22332) and extractor EMBEDDED
2012-09-22 11:20:19,689 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22332) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,708 DEBUG [MediaItemDAOImpl] Getting file of media item 22333
2012-09-22 11:20:19,709 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22333) and extractor EMBEDDED
2012-09-22 11:20:19,709 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22333) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,730 DEBUG [MediaItemDAOImpl] Getting file of media item 22334
2012-09-22 11:20:19,731 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22334) and extractor EMBEDDED
2012-09-22 11:20:19,731 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22334) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,749 DEBUG [MediaItemDAOImpl] Getting file of media item 22335
2012-09-22 11:20:19,749 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22335) and extractor EMBEDDED
2012-09-22 11:20:19,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22335) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,768 DEBUG [MediaItemDAOImpl] Getting file of media item 22336
2012-09-22 11:20:19,768 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22336) and extractor EMBEDDED
2012-09-22 11:20:19,768 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22336) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,788 DEBUG [MediaItemDAOImpl] Getting file of media item 22337
2012-09-22 11:20:19,788 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22337) and extractor EMBEDDED
2012-09-22 11:20:19,788 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22337) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,811 DEBUG [MediaItemDAOImpl] Getting file of media item 22338
2012-09-22 11:20:19,811 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22338) and extractor EMBEDDED
2012-09-22 11:20:19,812 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22338) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,830 DEBUG [MediaItemDAOImpl] Getting file of media item 22339
2012-09-22 11:20:19,830 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22339) and extractor EMBEDDED
2012-09-22 11:20:19,831 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22339) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,851 DEBUG [MediaItemDAOImpl] Getting file of media item 22340
2012-09-22 11:20:19,851 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22340) and extractor EMBEDDED
2012-09-22 11:20:19,851 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22340) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,869 DEBUG [MediaItemDAOImpl] Getting file of media item 22341
2012-09-22 11:20:19,870 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22341) and extractor EMBEDDED
2012-09-22 11:20:19,870 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22341) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,888 DEBUG [MediaItemDAOImpl] Getting file of media item 22342
2012-09-22 11:20:19,888 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22342) and extractor EMBEDDED
2012-09-22 11:20:19,888 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22342) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,909 DEBUG [MediaItemDAOImpl] Getting file of media item 22343
2012-09-22 11:20:19,909 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22343) and extractor EMBEDDED
2012-09-22 11:20:19,909 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22343) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,931 DEBUG [MediaItemDAOImpl] Getting file of media item 22344
2012-09-22 11:20:19,931 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22344) and extractor EMBEDDED
2012-09-22 11:20:19,931 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22344) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,950 DEBUG [MediaItemDAOImpl] Getting file of media item 22345
2012-09-22 11:20:19,950 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22345) and extractor EMBEDDED
2012-09-22 11:20:19,951 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22345) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,968 DEBUG [MediaItemDAOImpl] Getting file of media item 22346
2012-09-22 11:20:19,969 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22346) and extractor EMBEDDED
2012-09-22 11:20:19,969 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22346) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:19,987 DEBUG [MediaItemDAOImpl] Getting file of media item 22347
2012-09-22 11:20:19,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22347) and extractor EMBEDDED
2012-09-22 11:20:19,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22347) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:20,005 DEBUG [MediaItemDAOImpl] Getting file of media item 22348
2012-09-22 11:20:20,005 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22348) and extractor EMBEDDED
2012-09-22 11:20:20,005 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22348) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:20,023 DEBUG [MediaItemDAOImpl] Getting file of media item 22349
2012-09-22 11:20:20,023 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22349) and extractor EMBEDDED
2012-09-22 11:20:20,023 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22349) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:20,041 DEBUG [MediaItemDAOImpl] Getting file of media item 22350
2012-09-22 11:20:20,041 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22350) and extractor EMBEDDED
2012-09-22 11:20:20,041 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22350) and extractor COVER_IMAGE_IN_FOLDER
2012-09-22 11:20:20,078 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
   at ComedyCentral.extractItems(ComedyCentral.groovy:56)
Serviio 1.3.1 Windows 7 Professional x64 Sony KDL-32EX705
cheese392
Post Fri Sep 28, 2012 8:03 pm
Re: Comedy Central
Mine also worked until a few days ago and then suddenly stopped (both Daily Show and Colbert). I haven't made any changes to the settings.
flancur
Post Sat Sep 29, 2012 10:14 am
Re: Comedy Central
Thanks cheese392, so at least I know, that it's not a problem on my end.
Can anybody explain the error message in the debug log I posted? Does this mean, that the groovy-file needs to be updated/adjudted? As I've no clue how to handle groovy-files, can anybody look at this please or tell me how to proceed to solve this problem. Unfortunatly, I can not use the Hulu plugin to watch Daily Show and Colbert Report, as Hulu is geoblocking everything, no matter if the specific content is geoblocked itself.
Thank you so much!
insane822
Post Wed Oct 03, 2012 12:09 pm
Re: Comedy Central
Hey Guys,
My apologies.. I'll look into this when I get home later tonight.
peter1212
Post Fri Oct 05, 2012 4:36 am
Re: Comedy Central
Return to Available plugins
