Some .mkv files unrecognised.
bcbrit
Post Thu Jun 28, 2012 8:35 pm
Some, not all, .mkv files show as "unrecognised file format" and will not play. I did a search for the "log4j.xml" to help with debugging but it does not exist on my PC. I am using windows 7, Intel CPU 650@3.2ghz, 8g memory, Samsung BD player connected via Homewire.
Any help appreciated.
Post Fri Jun 29, 2012 7:01 am
Re: Some .mkv files unrecognised.
bcbrit wrote:Some, not all, .mkv files show as "unrecognised file format" and will not play.
Could you provide information about these files format ? http://wiki.serviio.org/doku.php?id=file_np (ffmpeg -i <file>, and MediaInfo tools result in text format)
bcbrit
Post Fri Jun 29, 2012 6:31 pm
Mediainfo is
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Format settings, ReFrames                : 5 frames
Duration                                 : 35mn 54s
Frame rate                               : 25.000 fps
Writing library                          : x264 core 125 r2200 999b753
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : A_AAC
Duration                                 : 35mn 54s
Title                                    : English
Hope this is enough, I am having problems saving ffmpeg info.
Thanks for your help
Post Fri Jun 29, 2012 8:01 pm
It seems that the mkv container is "wrecked".
Try to remux the file with MkvMerge tool : http://www.videohelp.com/tools/MKVtoolnix
