Panasonic Viera G20 and srt files
Scouser
Post Thu Jun 28, 2012 11:43 am
Everything works fine but is there a way to remove the xml tags on the rendered text?
I look in the srt file with Jubler and I can see that some text has "italic" attributes.
When this shows up on the TV it shows the tags too. E.g., "<i>Some text</i>" and the text is not rendered italic.
Is there a way I can get the TV to render the text in italic without the tags?
Is this a profile or transcription error?
I am running 0.6.2
Thanks in advance
Post Thu Jun 28, 2012 12:03 pm
Re: Panasonic Viera G20 and srt files
no, you'd have to remove the elements from the file yourself.
Scouser
Post Thu Jun 28, 2012 12:19 pm
If I remove the elements, I don't get italic rendering. Is Italic rendering text possible on this setup?
Post Thu Jun 28, 2012 3:52 pm
That is up to your renderer, it looks like its not
Scouser
Post Thu Jun 28, 2012 10:56 pm
Bummer. OK. Thanks Zip. I'll edit out the italics from the srt.
Thanks again for your support and brilliant work.
Cheers
Return to General discussion
