Samsung EH5300 - Static through PCM Digital-out playing MKV
shmulikgazit
Post Thu Jun 28, 2012 8:33 pm
Hi All,
I have a D6000 and I just bought an EH5300 for my bedroom.
Alas, the EH5300 only has digital-out so I had to connect it to a small box that converts Digital to analog so I can connect my wireless earphones. Digital-out is set to PCM.
I can hear great when I play mp4 files (HDTV downloads) but I hear static when I play 720p MKV files.
The difference in audio formats are:
mp4 - 2 channels at 48 Khz
MKV - AC-3 in 6 channels at 48 Khz.
Can you offer an idea why it doesn't work with MKV (the TV won't convert to PCM for Digital-out?) and if I can use transcoding to downgrade just the audio to 2 channels?
Apart from that, it works great with Serviio and I will be happy to see an E series profile soon (Currently I use the C/D one). Attached is a Device Spy output.
Thanks!
/Shmulik.
EH5300-DeviceSpy.txt
EH5300 Device Spy output
(16.62 KiB) Downloaded 681 times
shmulikgazit
Post Fri Jun 29, 2012 9:33 am
Re: Samsung EH5300 - Static through PCM Digital-out playing
OK,
I read the profiles article and educated myself a bit with codecs/containers/etc.
I hope I got it right:
<Video targetContainer="mpegts" targetACodec="mp3" forceStereo="true">
                 <Matches container="matroska" aCodec="ac3"/>
                 <Matches container="mp4" aCodec="aac"/>
I now hear correctly through the earphones.
I'll be happy though if someone more knowledgeable can have a look and say if it's the best way to do this.
Thanks!
/Shmulik.
Post Fri Jun 29, 2012 10:42 am
that looks ok. you are transcoding aac audio from the two containers to stereo mp3. If you want to keep the multichannel you could transcode to ac3 instead.
