Galaxy S2 - File not supported (used to work fine)
reyna12
Post Sun Jul 01, 2012 4:52 pm
Hi there,
I am using the latest version of serviio and a galaxy s2 with allshare, but have tried various of the other apps i've seen suggested but to no avail.
It used to work fine, even files which i know previously used to display no longer work, it just pops up "file not supported".
One of the other apps, can't remember which now, zoosk with mobileplayer or something came close, it displayed the first frame but wouldn't move from there and near enough crashed the phone, had to wait a good wee while before it would quit.
Any help would be appreciated :)
Post Sun Jul 01, 2012 4:54 pm
Re: Galaxy S2 - File not supported (used to work fine)
Have you tried Buble UPnP + MX Player? This seems to be a good combination.
reyna12
Post Sun Jul 01, 2012 7:20 pm
Same again :( plays 1st frame then few seconds later it skips to another frame and stops.
I can stream to my western digital player fine so i know server works ok
Users browsing this forum: Google [Bot] and 3 guests
