[Solved] No device can see Serviio
rbk123
Post Wed Jul 04, 2012 2:37 pm
For some reason, none of my devices can see Serviio any longer; it was working fine and now it's not. I have 2 WD TV Live Plus's and a PS3 and none of them can see it although Serviio can see them. Serviio says it's running, and I've stopped/restarted the server several times - either within the console or from the Start Menu - and no luck.
- I have another media server software running and the devices can see it, but they can't see Serviio
- I haven't tried uninstalling/reinstalling yet
- I tried removing the devices and then refreshing
- my version is 6.2
- I have not made any changes to my network
Any ideas?
Post Wed Jul 04, 2012 3:19 pm
Re: No device can see Serviio
Check that there were no port conflict with other media server.
Do you try to reboot your rooter ?
or try to reinstall serviio (1 make a library folder backup, 2 uninstall-install serviio and check if serviio appears on renderer, 3 try to reload library folder and check if serviio still appear on renderers)
rbk123
Post Wed Jul 04, 2012 10:34 pm
- I rebooted the router and same - no difference
- I uninstalled and re-installed and the same thing - devices can't see Serviio
- although I made a copy of the library directory, I tried renaming the existing library directory to then copy back the old library directory, but Windows won't let me change the name saying another application has the directory open. I tried closing and killing Serviio and it still wouldn't let me rename.
- I have tried stopping the other media server and it makes no difference
- Both media servers worked just fine together on the PC until the recent problems I'm now having with Serviio
Post Thu Jul 05, 2012 8:10 am
rbk123 wrote:- I uninstalled and re-installed and the same thing - devices can't see Serviio
When uninstalled, do you check that there were no more serviio folders? Do you reboot your PC?
rbk123 wrote:- although I made a copy of the library directory, I tried renaming the existing library directory to then copy back the old library directory, but Windows won't let me change the name saying another application has the directory open. I tried closing and killing Serviio and it still wouldn't let me rename.
?? Strange, probably because serviio service was still opened (on windows start menu : execute : "services.msc" and check that serviio service is not started)
Do you update java version ?
No more ideas, sorry.
rbk123
Post Thu Jul 05, 2012 11:33 am
I did check to make sure there are no folders, but I can give it another go.
I did not update the java version.
Thanks for trying to help. Are there any log files I can look at to see if it's generating any messages that would be helpful?
rbk123
Post Sat Jul 07, 2012 4:13 pm
It works now. I manually went into the Win7 firewall and opened the ports, plus I added them to the McAfee firewall as well. I am guessing they were closed by one of the Win7 auto updates recently - that's the only thing that I can think of that changed.
I also was able to rename the library directory name once I stopped the service via services.msc as you suggested. Then I moved back the old library and all my info is there. Thanks for your help with this.
Users browsing this forum: No registered users and 53 guests
