Fast Forward Problem
mws
Post Fri Jul 06, 2012 7:52 am
I have a Problem with a Panasonic Plasma and a serviio Server installed at a WHS 2011.
Every time I use fast forward at MPEG2 Files - comming from my fortherecord recorded via a Cine S2 tv card - stream ist stopped between 10 or 35 minutes.
The full screen mode will close and the movie will stand at the start point.
I do not have the problem with DivX or mp4 files.
I have installed the last Version using the serviio-0.6.2-win-setup.exe.
This is the only problem I have but it is very tedious because it reduces the WAF extremly.
mws
Post Fri Jul 06, 2012 6:15 pm
Re: Fast Forward Problem
enable detailed log and check if the file is transcoded by playing it again.
mws
Post Sun Jul 08, 2012 9:56 am
transcoding is of because the server has an Atom processor to slow to transcode.
However if the problem occures the process mfpmp.exe will run and take as many memory it coud become, in the moment more than 6GB!
Can this process make the trouble?
The log can be found here: http://tamiga-home.de/serviio.zip
Post Mon Jul 09, 2012 12:27 pm
no, that process is not related to Serviio. I'd only guess the TV doesn't like something about the file. There is nothing in the log either.
mws
Post Mon Jul 09, 2012 2:56 pm
Mh sound strange. I have tried mezzmo in the meantime and here it looks like fast forwarding is no problem with recorded files however with this prog there are other problems.
