Online Content - "Add" does nothing
trip
Post Mon Jul 02, 2012 4:44 pm
I'm using Serviio 0.6.2 on Win7 64bit.
When I click the [Add] button on "Online Sources" tab nothing happens. I can remove existing sources but cannot add new ones.
I've attached a log file. To reduce it size I deleted lines regarding updating of existing local media files.
Thanks for any help!
(44.52 KiB) Downloaded 564 times
Post Mon Jul 02, 2012 6:33 pm
Re: Online Content - "Add" does nothing
try to update your Java
trip
Post Tue Jul 03, 2012 3:29 pm
Tried that.
Also tried to install Serviio again, but still nothing happens when I click "Add". :(
Post Tue Jul 03, 2012 5:13 pm
what is your Java version? If you have more versions installed at the same time, remove all and install the latest again.
trip
Post Sat Jul 07, 2012 2:27 pm
I had both JRE 6 & 7.
I uninstalled both, restarted, downloaded and intsalled JRE 7 (from oracle.com) and restarted again. The problem still occurs, sadly.
Should I try to completely remove Serviio and install it from scratch? I tried running over the current installation (I already had 0.6.2, so I just installed it again).
Thanks for the help!
Post Mon Jul 09, 2012 12:29 pm
You can try that but it should not matter. As a last possibility you could try some of the other UI's available (web UI, ServiiDroid, etc)
trip
Post Mon Jul 09, 2012 6:04 pm
Thank for the help.
Is this a Java issue? Should I try different versions of JVM or JRE?
I just noticed that I don't even have the "Edit" button:
trip
Post Sat Jul 28, 2012 10:17 am
Update:
Completely removing Serviio and installing v1.0 solved the problem. No other changes were made to the machine besides that.
thanks for the help!
Users browsing this forum: Baidu [Spider] and 69 guests
