many folders do not register
qwertyrg
Post Tue Jul 10, 2012 2:16 am
great piece of software guys, thanks!
i have a bit of a problem though. all my video files registered and can be played on my samsung tv just fine, but when i add folder with pictures, only a few of many folders and only one picture are visible on TV. i use windows vista 64bit and current serviio version (just downloaded 2 days ago). what am i doing wrong?
Thanks a lot!
xs2inattar
Post Wed Jul 11, 2012 6:21 pm
Re: many folders do not register
I have noticed one thing that if a folder or file name contains apostrophe ('), the file will not register with serviio.
May be there are other special characters as well.
qwertyrg
Post Thu Jul 12, 2012 12:11 pm
no, no special characters. plain boring digits and letters.
patters
Post Tue Jul 17, 2012 7:29 am
Interesting. I don't think this is an issue on Serviio running on Linux. Will check...
qwertyrg
Post Wed Jul 18, 2012 2:58 am
i am running windows vista 64
qwertyrg
Post Wed Jul 25, 2012 10:37 pm
so, no one knows? as far as i can tell it may be indicating that there is a fairly limited number of files that can be registered...
Post Wed Jul 25, 2012 11:42 pm
no, there is no limit. Can you try 1.0? It should write into the log if it can access the folders or not
qwertyrg
Post Sun Jul 29, 2012 1:29 am
updating to 1.0 definitely helped, but there appears to be a limit of 1020 files and/or folders per folder (or 57 pages of files as shown on samsung tv screen.
thanks for the advice!
Post Sun Jul 29, 2012 8:14 pm
that is a Samsung restriction
qwertyrg
Post Sun Jul 29, 2012 9:46 pm
it look,s like it is samsung. but it' easy to avoid by distributing files in multiple folders.
thanks for the help!
Users browsing this forum: Bing [Bot] and 23 guests
