Database size limit...?
Dysturbia
Post Mon Jul 09, 2012 9:48 am
Hi all, just curious if Serviio has any sort of database size limit. Reason I ask is, at the moment Serviio is sharing about 4000 files from my HTPC at any given time, although I know that not all files are actually being shared(empty directories) through to my TV(40" 3D samsung 5500 series) nor my bluray player(3d something). I also notice that when its updating for any newly acquired files that some of them arent being listed. If there is a size limit its no problem, i can reduce the amount of media being listed, but at the moment im having to clear the database(removing paths) restart the system and then add them again and it seems to work fine for about a week before the process needs repeating again. Also, there is a chance this issue has come up and been addressed, but I lack patience to search through forums to find an answer.
Otherwise im immensely happy about how its working and how easily it was to get going.
Running Serviio 6.2.something(pretty sure its latest release), on Ubuntu 11.04.
Cheers
Chris
Post Mon Jul 09, 2012 11:21 am
Re: Database size limit...?
no, there is no (reasonable, other than what the OS has) size limit
Dysturbia
Post Tue Jul 10, 2012 12:01 pm
Any ideas as to what could cause the random library updates then?
Post Tue Jul 10, 2012 12:07 pm
Check under folders and see if they are being added but cannot find metadata info.
Dysturbia
Post Wed Jul 11, 2012 5:49 am
Thanks I'll have a look and mess around with it and see if that's the case.
Users browsing this forum: Google [Bot] and 63 guests
