Library data - how to save a copy
castalla
Post Thu Jul 12, 2012 12:37 pm
I need to reinstall serviio after an OS reinstall.
How do I export my existing library data, and import into the new serviio?
patters
Post Thu Jul 12, 2012 3:52 pm
Re: Library data - how to save a copy
Stop the Serviio service, copy the entire Serviio\library folder.
Put it back when you re-install, then start the service.
castalla
Post Thu Jul 12, 2012 4:43 pm
Thanks for the info.
Post Thu Jul 12, 2012 5:59 pm
patters, if the console options/library sharedfolders/online sources on the reinstalled serviio are diiferent than those in the previous install/library, will it make any difference when the library is restored? What happens to those onlinelinks that show enabled in the library but are not present or disabled in the new Serviio, or does the restored library also restore all the previous console settings?
patters
Post Fri Jul 13, 2012 11:16 am
AFAIK the library contains all Serviio settings too. When I'm experimenting on my package for Synology NAS I often backup my DB and restore later so I don't have to rebuild it when testing stuff. All check boxes in the console remain as they were, and feeds too.
Users browsing this forum: Baidu [Spider], Google [Bot] and 72 guests
