[Solved] How do I make this link work in Serviio ?
popeyeg
Post Wed Jul 11, 2012 2:40 am
rtmp://76.10.221.71/live/_definst_ playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=1
Again, THis link is active and work fine in VLC player but doesn't show up in Serviio. I have upto date FFMPG codec.
ffmpeg version N-34431-g039e9fe Copyright (c) 2000-2012 the FFmpeg developers
built on Jul 4 2012 16:53:11 with gcc 4.6.3
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-x11grab
libavcodec 54. 32.100 / 54. 32.100
libavformat 54. 14.100 / 54. 14.100
libavdevice 54. 0.100 / 54. 0.100
libavfilter 3. 0.101 / 3. 0.101
popeyeg
Post Wed Jul 11, 2012 2:43 am
Re: How do I make this link work in Serviio ? Please help
popeyeg wrote:rtmp://76.10.221.71/live/_definst_ playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=15
I also tried: [quote="popeyeg"]rtmp://76.10.221.71/live/_definst_ app=tv playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=15
popeyeg
Post Wed Jul 11, 2012 2:55 am
The LOG ! : FFMPEG -i
popeyeg@ubuntu:~$ ffmpeg rtmp://76.10.221.71/live/_definst_ app=tv playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=15
[1] 3848
No command 'amp' found, did you mean:
Command 'ams' from package 'ams' (universe)
Command 'xmp' from package 'xmp' (universe)
Command 'amd' from package 'am-utils' (universe)
Command 'amq' from package 'am-utils' (universe)
Command 'cmp' from package 'diffutils' (main)
Command 'arp' from package 'net-tools' (main)
Command 'asp' from package 'asp' (universe)
Command 'atp' from package 'atp' (universe)
Command 'apm' from package 'apmd' (main)
Command 'amph' from package 'amphetamine' (universe)
Command 'bmp' from package 'ztex-bmp' (universe)
Command 'mp' from package 'mp' (universe)
Command 'a2p' from package 'perl' (main)
Command 'map' from package 'sgt-puzzles' (universe)
Command 'amap' from package 'amap-align' (universe)
amp: command not found
[1]+ Stopped ffmpeg rtmp://76.10.221.71/live/_definst_ app=tv playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro
[2] 3851
[2]- Done vw=600
[2] 3854
[2]- Done vh=480
Post Wed Jul 11, 2012 2:06 pm
The link as you first posted works fine for me in Serviio and in ffmpeg using both N-33591 and latest N-42368
You have to enclose the link in ".." for the ffmpeg command to work because it contains spaces.
popeyeg
Post Wed Jul 11, 2012 3:44 pm
jhb50 wrote:The link as you first posted works fine for me in Serviio and in ffmpeg using both N-33591 and latest N-42368
So how you add this to Serviio Concsole ?
Under Online Resource => Live Streams =>
Entire stream under double quotes ?
I didn't use the quote while saving it in my Serviio Console, that's why it didn't show up on my TV ?
Post Wed Jul 11, 2012 4:18 pm
Under Online Resource => Live Streams => Yes
Entire stream under double quotes ? No. Only in ffmpeg command.
Test with ffmpeg first.
popeyeg
Post Thu Jul 12, 2012 2:13 am
Well, its not working for me. How do I "enable-librtmp" ?
popeyeg@ubuntu:~$ ffmpeg -i "rtmp://76.10.221.71/live/_definst_ app=tv playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=15"
[rtmp @ 0x1e956e0] Server error: Connection failed: Application rejected connection.
rtmp://76.10.221.71/live/_definst_ app=tv playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&amp;vw=600&amp;vh=480&amp;domain=1tvlive.in swfVfy=true live=true timeout=15: Operation not permitted
Post Thu Jul 12, 2012 8:38 am
popeyeg
Post Thu Jul 12, 2012 5:10 pm
zip wrote:you have to build ffmpeg with it. http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
Sigh ! I will do it again and report back if it still doesn't work.
I already built this last week but I guess you expert know more than I do.
NOTE [color=#00BF00]Admins Please Keep this thread Open.[/color]
xs2inattar
Post Fri Jul 13, 2012 4:58 pm
remove app=tv and replace &amp; with simple & and try again.
You should use the following link in serviio.
rtmp://76.10.221.71/live/_definst_ playpath=zeelivetvoxpro swfUrl=http://www.veemi.com/player/player-licensed.swf pageUrl=http://www.veemi.com/embed.php?v=zeelivetvoxpro&vw=600&vh=480&domain=1tvlive.in swfVfy=1 live=1
Tested the above and working fine :)
popeyeg
Post Sun Jul 15, 2012 5:00 am
YOU ARE GENIUS.
I SHOULD HAVE BUILD my CODECS per above LINK.
THANK YOU SO MUCH.
NOW ALL MOST ALL THE LINKS WORK FOR ME.
ps: the CAPS are for excitement and thank you.
Note: Admin Please mark this thread as close.
Suggestion: Please Post above link as STICKY NOTE in this forum for others to know, how to build this codec.
Users browsing this forum: Baidu [Spider], Google [Bot] and 25 guests
