RSS LiveFeed Help
zit1343
Post Fri Jul 13, 2012 3:30 pm
RSS LiveFeed Help
I have Sony Blu Ray Player
I have windows PC with Serviio with 0.6.2
in that under online sources, I added
https://sites.google.com/site/serviiors ... annels.rss
https://sites.google.com/site/serviiors ... Sports.rss
and 1 more which I made myself
and saved it.
but when I try to play it on my Sony blu ray player it says
There is no playable file
Plz help
Post Fri Jul 13, 2012 3:38 pm
Re: RSS LiveFeed Help
As it says:
NOTE: If a stream does not appear in the menu, or if you get an error like “Unsupported File Format” when attempting to play a listed stream, it means the stream is NOT transmitting, so do not ask, "Why can't I see a stream ?"
Only some of those channels are working right now.
zit1343
Post Fri Jul 13, 2012 3:56 pm
I know, I read that in many of your post but I edit one of your rss file and uploaded it to my site... your file had old rtmp link,
http://zmv.freeiz.com/LiveFeeds_Bollywood_Music.rss
this link proves that stream is up and working [url]http://www.9xjalwa.in/livetv.aspx
[/url]
if you compare playpath, I updated it currently it is 9xjalwa3, also swf but I dont know what is swfVfy=0 for
 <item>
      <title>9xM Bollywood Music </title>
      <link>http://9xM</link>
      <media:stream url="rtmp://210.210.27.37/live playpath=9xjalwa3 swfUrl=http://www.9xjalwa.in/livetv/jalwa.swf pageUrl=http://www.9xm.in/livetv/livetv.aspx swfVfy=0 live=1" type="video" />
      <media:thumbnail url="http://webretina.com/wp-content/uploads/2011/12/9XM_logo.png" />
   </item>
   <item>
      <title>9xM Tashan Bollywood Music </title>
      <link>http://9xMT</link>
      <media:stream url="rtmp://210.210.27.37/live playpath=9xjalwa3 swfUrl=http://www.9xjalwa.in/livetv/jalwa.swf pageUrl=http://www.9xtashan.in/livetv.aspx swfVfy=0 live=1" type="video" />
      <media:thumbnail url="http://dishtracking.com/blog/wp-content/uploads/2011/08/9X-Tashan.jpg" />
   </item>
this is how I enter in Serviio to play it on my Sony home theater
zit1343
Post Fri Jul 13, 2012 4:14 pm
nevermind it had to fix one more thing the url for the site it wasn't correct.
now the rss loads and shows 3 stream I only have code below in that rss file
thanks alot man it works.... wow I can't believe it
now I will add lots and lots of Indian channels wow
<?xml version="1.0" encoding="UTF-8" ?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/">
<channel>
   <title>Bollywood Music </title>
   <link>https://zmv.freeiz.com/LiveFeeds_Bollywood_Music.rss</link>
   <description>Bollywood Music from vkserviio</description>
   <item>
      <media:stream url="rtmp://210.210.27.37/live playpath=9xjalwa3 swfUrl=http://www.9xjalwa.in/livetv/jalwa.swf pageUrl=http://www.9xjalwa.in/livetv.aspx swfVfy=0 live=1" type="video" />
   </item>
   </channel>
</rss>
Post Fri Jul 13, 2012 4:47 pm
I have corrected the links both the one you provided and zoomTV. Thanks for letting me know they were outdated.
zit1343
Post Fri Jul 13, 2012 5:00 pm
Ok I encountered problem, I don't know if you ever seen it..
after selecting channel I want to watch. my tv screen goes red color only option I have to is unplug power cord and plug back in,
do you know anything about that?
Post Fri Jul 13, 2012 8:28 pm
No. Try the link with ffplay.
npuser
Post Fri Jul 13, 2012 11:53 pm
zit1343 wrote: my tv screen goes red color only option I have to is unplug power cord
Notorious Sony issue. Have a look at this post for a possible workaround. http://forum.serviio.org/viewtopic.php?p=40886&sid=85c4f2169d6ecd623453fd706034f677&sid=85c4f2169d6ecd623453fd706034f677#p40886 it should point you to right direction.
Npuser
Users browsing this forum: Baidu [Spider], Google [Bot] and 53 guests
