Error on Mac OS X 10.8 Mountain Lion
miriv365
Post Sat Jul 14, 2012 1:25 am
Serviio doesn't seem to be working with 10.8 Mountain Lion. I set the log to debug and get the following error. Any help would be appreciated:
2012-07-13 20:21:31,641 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-07-13 20:21:31,670 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-13 20:21:31,670 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. 6a61243292ee)
2012-07-13 20:21:31,670 INFO [MediaServer] Petr Nejedly 2009-2011
2012-07-13 20:21:31,670 INFO [MediaServer] http://www.serviio.org
2012-07-13 20:21:31,670 INFO [MediaServer] Java 1.6.0_33-Apple Inc.
2012-07-13 20:21:31,670 INFO [MediaServer] OS Mac OS X x86_64 10.8
2012-07-13 20:21:31,670 INFO [MediaServer] File encoding: UTF-8
2012-07-13 20:21:31,671 INFO [MediaServer] Headless mode enabled: true
2012-07-13 20:21:31,671 INFO [MediaServer] User home dir: /Users/michaelrivera
2012-07-13 20:21:31,671 INFO [MediaServer] Temp dir: /var/folders/tx/gsw1tfrj0bvfpvzccd43th4r0000gn/T/
2012-07-13 20:21:31,671 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-13 20:21:31,806 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-07-13 20:21:31,836 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.net.BindException: Address already in use
java.lang.RuntimeException: java.net.BindException: Address already in use
at org.serviio.ui.restlet.RestletServer.runServer(RestletServer.java:80)
at org.serviio.MediaServer.main(MediaServer.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at apple.launcher.LaunchRunner.run(LaunchRunner.java:116)
at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:51)
at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
Caused by: java.net.BindException: Address already in use
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:383)
at java.net.ServerSocket.bind(ServerSocket.java:328)
at java.net.ServerSocket.bind(ServerSocket.java:286)
at org.restlet.engine.http.connector.BaseServerHelper.createServerSocket(BaseServerHelper.java:118)
at org.restlet.engine.http.connector.BaseServerHelper.start(BaseServerHelper.java:251)
at org.restlet.engine.http.connector.HttpServerHelper.start(HttpServerHelper.java:69)
at org.restlet.Server.start(Server.java:585)
at org.restlet.Component.startServers(Component.java:601)
at org.restlet.Component.start(Component.java:528)
at org.serviio.ui.restlet.RestletServer.runServer(RestletServer.java:78)
... 8 more
miriv365
Post Sat Jul 14, 2012 2:02 am
Re: Error on Mac OS X 10.8 Mountain Lion
Never mind, I got it.. it's working now.. kind of... it's launching.. and not quitting...
repeters
Post Sun Jul 15, 2012 12:19 am
What did you do to get it working?
helicoil
Post Sun Jul 29, 2012 11:02 am
BUMP!
Getting the same error when launching ver1.0 in Mountain Lion. Running Java SE 6 (1.6.0_33-b03-424)
helicoil
Post Sun Jul 29, 2012 11:20 am
Sorted - well, worked for me
Go to System Prefs/Security & Privacy/General
Allow Applications downloaded from: Anywhere
patters
Post Tue Jul 31, 2012 7:56 am
I think that's some new thing to try and encourage you to only use software from their App Store. Apple trying to turn your computer into an iPad then.
helicoil
Post Tue Jul 31, 2012 10:28 am
Yep, definitely feeling "herded".
BTW, ipad app - "BUZZ Player" works well with serviio, I think it's a couple of quid from memory.
Users browsing this forum: Baidu [Spider] and 239 guests
