Disable thumbnail generation
martinbangsoe
Post Mon Jul 16, 2012 9:13 am
When using Serviio on a NAS it is extremely annoying that you can't tell serviio to NOT generate thumbnails for images. It is too resource consuming for a small NAS.
I would really like an option to disable thumbnail generation. Is is possible to disable it now somehow? Eg. via some config file?
Martin
Post Mon Jul 16, 2012 9:58 am
Re: Disable thumbnail generation
There isn't an option to do it at the moment.
martinbangsoe
Post Mon Jul 16, 2012 10:34 am
No config-file og hidden text-file somewhere where you can do some sort of trick? I would REALLY like to have it disabled! :geek:
Return to Feature requests
