Problems with secured shoutcast streams
Satras
Post Sat Jul 14, 2012 10:18 pm
I'm a premium Member of di.fm. For paying customers, they offer 128K and 256K Audio streams in the following format
http://1.2.3.4:80/trance_hi?mysecurehash
Till earlier this week, this all worked fine. Starting this week I got a new playback device which is connected using Wifi and the 256K stream was too high for it (bad coveradge of wifi signal), so I started to play around with their low streams and after a bit of testing, I was no longer able to add any of the secured streams. I mean I was able to add them but none of my playback devices could connect to this stream.
The standard low streams are working fine and if I copy and paste the above code into Winamp, it starts to play.
I'm out of ideas.
Any Help ? thanx !
Post Tue Jul 17, 2012 12:39 pm
Re: Problems with secured shoutcast streams
provide detailed log (and make sure you remove any mention of your secure hashtag from it) :-)
Satras
Post Tue Jul 17, 2012 1:44 pm
Sorry, forgotten to attach it.
Will do it when I'm back home later
Satras
Post Tue Jul 17, 2012 3:35 pm
This should be it, I was able to do this remotely.
Post Tue Jul 17, 2012 4:27 pm
there is nothing with 'trance_hi' in the log
Satras
Post Tue Jul 17, 2012 7:28 pm
Its
http://1.2.3.4:80/trance?mysecureid
Not sure why it was trance_hi in my first tests.
But I guess its working now ?! Cause one of my Playback devices started playing the streams again. But the new kitchen Radio does not. This is odd now.
Before I started playing around both where streaming ok. I will do some more tests on the weekend.
Satras
Post Wed Jul 18, 2012 7:30 am
Did some more tests yesterday evening and my WDTVLive could play the stream therefore I believe everything with Serviio is ok.
Just my Kitchen Radio refuses to play the streams... any Idea why this is the case ?
It does not even show the radio stream in the Online Menu
Post Wed Jul 18, 2012 12:20 pm
post result of
ffmpeg -i "http://........ stream url here ..."
Satras
Post Thu Jul 19, 2012 7:33 am
not sure what you want me to do. Sorry
Post Thu Jul 19, 2012 2:23 pm
viewtopic.php?f=5&t=1123
use you stream's URL as the file name and wrap it in quotes, as in my previous post, like:
ffmpeg -i "http://1.2.3.4:80/trance_hi?mysecurehash"
Satras
Post Thu Jul 19, 2012 6:50 pm
C:\Users\Administrator>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i http:/
/1.2.3.4:80/trance?mysecurehash
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[aac @ 00388460] max_analyze_duration 5000000 reached at 5015510
[aac @ 00388460] Estimating duration from bitrate, this may be inaccurate
Input #0, aac, from 'http://1.2.3.4:80/trance?mysecurehash':
  Duration: N/A, bitrate: 124 kb/s
    Stream #0:0: Audio: aac, 44100 Hz, stereo, s16, 124 kb/s
you might want to change the board setting to start a new page at 20 or 35 posts.. makes it easier to read.. but this is just my oppinion :)
Post Fri Jul 20, 2012 12:56 pm
It's an AAC stream, so depends if the device can play that. Serviio currently cannot transcode AAC streams, so they can only be played natively. It's possible that the other bitrates are served as mp3.
Satras
Post Fri Jul 20, 2012 2:38 pm
Damn.. those Idiots :(
Thanx for your help !
this indicates a MP3 Stream right ?
Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten.
nfig
[mp3 @ 016c84a0] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 016c84a0] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'http://1.2.3.4:80/trance_hi?mysecurehash0':
Duration: N/A, start: 0.000000, bitrate: 256 kb/s
Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16, 256 kb/s
Post Fri Jul 20, 2012 3:14 pm
yes
Satras
Post Sat Jul 21, 2012 3:18 pm
Thanx for your help ! this really helped me fixing it.
Users browsing this forum: Google [Bot] and 29 guests
