Samsung E Series (UE40ES6570)
retro
Post Fri Jul 13, 2012 8:12 am
im using serviio for a long time now with my UE46D6700 and everything works fine. So i bought a UE40ES6570 for my sleeping room. I am using the C/D Series Profile for the new one.
The weard thing is that it is working fine for about 5 - 10 minutes and then i got the message Device disconnected. Afterthat i dont see the serviio server for about 10 minutes on this device. The other
TV works fine the whole time. After the 10 minutes i can start a new stream for about 5 - 10 mins and then again.
Im playing the same file on the D as on the E series TV ....
Has anybody the same problems or maybe a solution ?
nice regards,
Retro
retro
Post Fri Jul 13, 2012 8:49 am
Re: Samsung E Series (UE40ES6570)
I have enabled debugging and streamed 1 file. Nothing special i have seen in the log, but after the disconnect a picture will be requested ....
here is the log. The UE40ES6570 is the device with the ip 32. I hope that helps!
2012-07-13 10:35:11,485 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-13 10:35:11,485 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-07-13 10:35:11,485 INFO [MediaServer] Petr Nejedly 2009-2011
2012-07-13 10:35:11,485 INFO [MediaServer] http://www.serviio.org
2012-07-13 10:35:11,485 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2012-07-13 10:35:11,485 INFO [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2012-07-13 10:35:11,485 INFO [MediaServer] File encoding: windows-1252
2012-07-13 10:35:11,501 INFO [MediaServer] Headless mode enabled: true
2012-07-13 10:35:11,501 INFO [MediaServer] User home dir: C:\
2012-07-13 10:35:11,501 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-07-13 10:35:11,501 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-13 10:35:12,078 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-07-13 10:35:12,203 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-07-13 10:35:12,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-07-13 10:35:16,118 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-07-13 10:35:16,727 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-07-13 10:35:20,034 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-07-13 10:35:20,065 INFO [WebServer] Socket buffer set to 65535 bytes
2012-07-13 10:35:20,081 INFO [Device] Created UPnP Device with UUID: 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa, bound address: 192.168.0.1
2012-07-13 10:35:20,159 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-07-13 10:35:20,174 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-07-13 10:35:20,174 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-07-13 10:35:20,174 INFO [PluginCompilerThread] Started looking for plugins
2012-07-13 10:35:20,689 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-07-13 10:35:20,814 INFO [WebServer] WebServer starting on port 8895
2012-07-13 10:35:20,845 DEBUG [DiscoveryManager] UPNP device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa (192.168.0.1) is available
2012-07-13 10:35:20,845 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-07-13 10:35:20,845 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-07-13 10:35:20,845 INFO [EventDispatcher] Starting EventDispatcher
2012-07-13 10:35:20,876 INFO [RendererSearchSender] Searching for Renderer devices
2012-07-13 10:35:20,876 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-07-13 10:35:20,908 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.0.1, timeout = 0
2012-07-13 10:35:21,101 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth4 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.0.1, timeout = 0
2012-07-13 10:35:21,101 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth5 (Intel(R) 82578DM Gigabit Network Connection) and address 81.217.35.88, timeout = 0
2012-07-13 10:35:21,132 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-07-13 10:35:21,132 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.32:7676/smp_14_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-07-13 10:35:21,132 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.1:55234
2012-07-13 10:35:21,148 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 0ee6b281-00fa-1000-8ee1-4844f7cf89b7 from address /192.168.0.32:50605
2012-07-13 10:35:21,148 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.1:55234
2012-07-13 10:35:21,148 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.32:7676/smp_14_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-07-13 10:35:21,148 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 0ee6b281-00fa-1000-8ee1-4844f7cf89b7 from address /192.168.0.32:52710
2012-07-13 10:35:21,148 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 0ee6b281-00fa-1000-8ee1-4844f7cf89b7 from address /192.168.0.32:46976
2012-07-13 10:35:21,163 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.0.1, timeout = 0
2012-07-13 10:35:21,163 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:21,163 DEBUG [RendererManager] Adding renderer Renderer [uuid=0ee6b281-00fa-1000-8ee1-4844f7cf89b7, ipAddress=192.168.0.32, name=UE40ES6570, profileId=7, manuallyAdded=false, forcedProfile=true] to list of active renderers
2012-07-13 10:35:21,179 DEBUG [WebServer] Incoming connection from /192.168.0.21:37364
2012-07-13 10:35:21,179 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa from 192.168.0.21 (headers = [HOST: 192.168.0.1:8895,DATE: Fri, 13 Jul 2012 08:33:30 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.28, UPnP/1.0, Intel SDK for UPnP devices /1.2])
2012-07-13 10:35:21,179 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.21
2012-07-13 10:35:21,179 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.1:8895,DATE: Fri, 13 Jul 2012 08:33:30 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.28, UPnP/1.0, Intel SDK for UPnP devices /1.2]
2012-07-13 10:35:21,382 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.21
2012-07-13 10:35:21,475 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-07-13 10:35:21,491 DEBUG [WebServer] Incoming connection from /192.168.0.21:37367
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=0901bd53-aee1-4f86-98d5-0af9250fcd67) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://192.168.0.21:49153/
2012-07-13 10:35:21,491 DEBUG [WebServer] Incoming connection from /192.168.0.21:37368
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=2f33699b-52b1-4edb-9e0f-f8839fbe50df) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.0.21:49153/
2012-07-13 10:35:21,491 DEBUG [WebServer] Incoming connection from /192.168.0.21:37369
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service X_MS_MediaReceiverRegistrar
2012-07-13 10:35:21,491 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=83a01b1e-2a70-47b5-b871-ceb81728c5f2) for service urn:microsoft.com:serviceId:X_MS_MediaReceiverRegistrar reporting to http://192.168.0.21:49153/
2012-07-13 10:35:21,818 DEBUG [WebServer] Incoming connection from /192.168.0.32:33880
2012-07-13 10:35:21,818 DEBUG [WebServer] Incoming connection from /192.168.0.32:33881
2012-07-13 10:35:21,818 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa from 192.168.0.32 (headers = [HOST: 192.168.0.1:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]UE40ES6570/1.0 DLNADOC/1.50])
2012-07-13 10:35:21,818 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:21,818 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.1:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]UE40ES6570/1.0 DLNADOC/1.50]
2012-07-13 10:35:21,818 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D-series)'
2012-07-13 10:35:21,834 DEBUG [WebServer] Incoming connection from /192.168.0.32:33882
2012-07-13 10:35:21,834 DEBUG [WebServer] Incoming connection from /192.168.0.32:33883
2012-07-13 10:35:21,834 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-07-13 10:35:21,850 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-07-13 10:35:21,865 DEBUG [EventDispatcher] Sending event notification #0 for subscription 2f33699b-52b1-4edb-9e0f-f8839fbe50df to endpoint http://192.168.0.21:49153/
2012-07-13 10:35:21,865 DEBUG [WebServer] Incoming connection from /192.168.0.32:33884
2012-07-13 10:35:21,865 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-07-13 10:35:21,865 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-07-13 10:35:21,865 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.21:49153
2012-07-13 10:35:21,881 DEBUG [WebServer] Incoming connection from /192.168.0.32:33885
2012-07-13 10:35:21,881 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-07-13 10:35:21,881 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-07-13 10:35:21,881 DEBUG [WebServer] Incoming connection from /192.168.0.32:33886
2012-07-13 10:35:21,881 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2012-07-13 10:35:21,896 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-07-13 10:35:21,896 DEBUG [WebServer] Incoming connection from /192.168.0.32:33887
2012-07-13 10:35:21,896 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2012-07-13 10:35:21,928 DEBUG [EventDispatcher] Event notification sent and received successfully
2012-07-13 10:35:21,928 DEBUG [EventDispatcher] Sending event notification #0 for subscription 0901bd53-aee1-4f86-98d5-0af9250fcd67 to endpoint http://192.168.0.21:49153/
2012-07-13 10:35:21,928 DEBUG [RequestExecutor] Sending HTTP request to 192.168.0.21:49153
2012-07-13 10:35:23,129 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (Intel(R) 82578DM Gigabit Network Connection) and address 81.217.35.88, timeout = 0
2012-07-13 10:35:23,129 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:24,112 DEBUG [WebServer] Incoming connection from /192.168.0.33:52842
2012-07-13 10:35:24,112 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa from 192.168.0.33 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.1:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2012-07-13 10:35:24,112 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2012-07-13 10:35:24,112 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.1:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2012-07-13 10:35:24,112 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-07-13 10:35:24,127 DEBUG [WebServer] Incoming connection from /192.168.0.33:52843
2012-07-13 10:35:24,127 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-13 10:35:25,094 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-07-13 10:35:27,138 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-07-13 10:35:35,515 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.0.1, timeout = 0
2012-07-13 10:35:35,515 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:37,481 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (Intel(R) 82578DM Gigabit Network Connection) and address 81.217.35.88, timeout = 0
2012-07-13 10:35:37,481 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:39,447 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-07-13 10:35:44,626 DEBUG [WebServer] Incoming connection from /192.168.0.32:33893
2012-07-13 10:35:44,641 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:44,641 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:45,234 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:45,250 DEBUG [WebServer] Incoming connection from /192.168.0.32:33895
2012-07-13 10:35:45,250 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetSemanticQueryCapabilities"' from 192.168.0.32:
2012-07-13 10:35:45,250 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:45,265 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
2012-07-13 10:35:45,577 DEBUG [WebServer] Incoming connection from /192.168.0.32:33897
2012-07-13 10:35:45,577 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2012-07-13 10:35:47,169 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-07-13 10:35:47,169 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:35:47,169 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-13 10:35:47,184 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:35:47,184 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-13 10:35:47,200 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-13 10:35:47,215 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-13 10:35:49,852 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.0.1, timeout = 0
2012-07-13 10:35:49,852 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:49,867 DEBUG [WebServer] Incoming connection from /192.168.0.32:33898
2012-07-13 10:35:49,867 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:49,867 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:49,867 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:49,899 DEBUG [WebServer] Incoming connection from /192.168.0.32:33899
2012-07-13 10:35:49,899 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:49,899 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:49,914 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:50,164 DEBUG [WebServer] Incoming connection from /192.168.0.32:33900
2012-07-13 10:35:50,164 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:50,164 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:50,164 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:50,195 DEBUG [WebServer] Incoming connection from /192.168.0.32:33901
2012-07-13 10:35:50,195 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:50,195 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:50,195 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:50,211 DEBUG [WebServer] Incoming connection from /192.168.0.32:33902
2012-07-13 10:35:50,211 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.32:
2012-07-13 10:35:50,211 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:50,304 DEBUG [ContentDirectory] Browse() called for renderer UE40ES6570 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-13 10:35:50,320 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-07-13 10:35:50,335 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2012-07-13 10:35:51,022 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-07-13 10:35:51,053 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-07-13 10:35:51,084 DEBUG [VideoDAOImpl] Retrieving number of video initials
2012-07-13 10:35:51,817 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth5 (Intel(R) 82578DM Gigabit Network Connection) and address 81.217.35.88, timeout = 0
2012-07-13 10:35:51,817 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa
2012-07-13 10:35:52,301 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:52,317 DEBUG [WebServer] Incoming connection from /192.168.0.32:33903
2012-07-13 10:35:52,317 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.32:
2012-07-13 10:35:52,317 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:52,317 DEBUG [ContentDirectory] Browse() called for renderer UE40ES6570 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-13 10:35:52,317 DEBUG [VideoDAOImpl] Retrieving number of video initials
2012-07-13 10:35:52,597 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2012-07-13 10:35:52,785 DEBUG [SeriesDAOImpl] Retrieving number of series
2012-07-13 10:35:52,925 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2012-07-13 10:35:52,925 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2012-07-13 10:35:53,050 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2012-07-13 10:35:53,050 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2012-07-13 10:35:53,159 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2012-07-13 10:35:53,409 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:53,611 DEBUG [WebServer] Incoming connection from /192.168.0.32:33904
2012-07-13 10:35:53,611 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-13 10:35:53,783 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-07-13 10:35:57,105 DEBUG [WebServer] Incoming connection from /192.168.0.32:33905
2012-07-13 10:35:57,106 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.0.32:
2012-07-13 10:35:57,106 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:57,113 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:57,131 DEBUG [WebServer] Incoming connection from /192.168.0.32:33906
2012-07-13 10:35:57,132 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.32:
2012-07-13 10:35:57,132 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:57,140 DEBUG [ContentDirectory] Browse() called for renderer UE40ES6570 (profile 7) with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-13 10:35:57,140 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=1)
2012-07-13 10:35:57,280 DEBUG [SeriesDAOImpl] Reading a Series (id = 58)
2012-07-13 10:35:57,295 DEBUG [GenreDAOImpl] Reading a Genre (id = 8)
2012-07-13 10:35:57,312 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:35:57,377 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:35:57,725 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:35:57,757 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3946 and profile Samsung TV / player (C/D-series)
2012-07-13 10:35:57,762 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10543)
2012-07-13 10:35:57,948 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:35:57,949 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:35:57,952 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2012-07-13 10:35:58,025 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2012-07-13 10:35:58,035 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:58,054 DEBUG [WebServer] Incoming connection from /192.168.0.32:33907
2012-07-13 10:35:58,055 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.32:
2012-07-13 10:35:58,055 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,061 DEBUG [ContentDirectory] Browse() called for renderer UE40ES6570 (profile 7) with parameters: objectID = V_LV, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-13 10:35:58,062 DEBUG [VideoDAOImpl] Retrieving list of 10 last viewed videos (from=0, count=30)
2012-07-13 10:35:58,198 DEBUG [SeriesDAOImpl] Reading a Series (id = 58)
2012-07-13 10:35:58,199 DEBUG [GenreDAOImpl] Reading a Genre (id = 8)
2012-07-13 10:35:58,200 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:35:58,201 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:35:58,203 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:35:58,474 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6249 and profile Samsung TV / player (C/D-series)
2012-07-13 10:35:58,474 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7927)
2012-07-13 10:35:58,491 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6249)
2012-07-13 10:35:58,493 DEBUG [MediaItemDAOImpl] Getting file of media item 6249
2012-07-13 10:35:58,496 DEBUG [SeriesDAOImpl] Reading a Series (id = 54)
2012-07-13 10:35:58,498 DEBUG [GenreDAOImpl] Reading a Genre (id = 6)
2012-07-13 10:35:58,499 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3322)
2012-07-13 10:35:58,500 DEBUG [MediaItemDAOImpl] Getting file of media item 3322
2012-07-13 10:35:58,566 DEBUG [VideoDAOImpl] Reading a Video (id = 3322)
2012-07-13 10:35:58,567 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3322 and profile Samsung TV / player (C/D-series)
2012-07-13 10:35:58,568 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9919)
2012-07-13 10:35:58,581 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3322)
2012-07-13 10:35:58,582 DEBUG [MediaItemDAOImpl] Getting file of media item 3322
2012-07-13 10:35:58,585 DEBUG [SeriesDAOImpl] Reading a Series (id = 54)
2012-07-13 10:35:58,586 DEBUG [GenreDAOImpl] Reading a Genre (id = 6)
2012-07-13 10:35:58,588 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3321)
2012-07-13 10:35:58,589 DEBUG [MediaItemDAOImpl] Getting file of media item 3321
2012-07-13 10:35:58,603 DEBUG [VideoDAOImpl] Reading a Video (id = 3321)
2012-07-13 10:35:58,604 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3321 and profile Samsung TV / player (C/D-series)
2012-07-13 10:35:58,605 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9918)
2012-07-13 10:35:58,614 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3321)
2012-07-13 10:35:58,615 DEBUG [MediaItemDAOImpl] Getting file of media item 3321
2012-07-13 10:35:58,618 DEBUG [SeriesDAOImpl] Reading a Series (id = 74)
2012-07-13 10:35:58,619 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2012-07-13 10:35:58,620 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4776)
2012-07-13 10:35:58,621 DEBUG [MediaItemDAOImpl] Getting file of media item 4776
2012-07-13 10:35:58,623 DEBUG [VideoDAOImpl] Reading a Video (id = 4776)
2012-07-13 10:35:58,625 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4776 and profile Samsung TV / player (C/D-series)
2012-07-13 10:35:58,625 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11373)
2012-07-13 10:35:58,627 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4776)
2012-07-13 10:35:58,628 DEBUG [MediaItemDAOImpl] Getting file of media item 4776
2012-07-13 10:35:58,631 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2012-07-13 10:35:58,661 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2012-07-13 10:35:58,715 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:35:58,794 DEBUG [WebServer] Incoming connection from /192.168.0.32:33908
2012-07-13 10:35:58,795 DEBUG [ResourceTransportRequestHandler] GET /resource/9918/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,795 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,797 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,799 DEBUG [ResourceTransportRequestHandler] Request for resource 9918 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,806 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9918)
2012-07-13 10:35:58,807 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 9918
2012-07-13 10:35:58,809 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5252
2012-07-13 10:35:58,810 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,810 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5252,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,823 DEBUG [WebServer] Incoming connection from /192.168.0.32:33909
2012-07-13 10:35:58,824 DEBUG [ResourceTransportRequestHandler] GET /resource/9919/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,824 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,825 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,826 DEBUG [ResourceTransportRequestHandler] Request for resource 9919 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,826 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9919)
2012-07-13 10:35:58,827 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 9919
2012-07-13 10:35:58,827 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3812
2012-07-13 10:35:58,827 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,827 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3812,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,870 DEBUG [WebServer] Incoming connection from /192.168.0.32:33910
2012-07-13 10:35:58,871 DEBUG [ResourceTransportRequestHandler] GET /resource/10541/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,871 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,872 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,873 DEBUG [ResourceTransportRequestHandler] Request for resource 10541 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,873 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10541)
2012-07-13 10:35:58,873 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 10541
2012-07-13 10:35:58,874 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3469
2012-07-13 10:35:58,874 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,874 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3469,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,902 DEBUG [WebServer] Incoming connection from /192.168.0.32:33911
2012-07-13 10:35:58,903 DEBUG [ResourceTransportRequestHandler] GET /resource/10542/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,903 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,904 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,904 DEBUG [ResourceTransportRequestHandler] Request for resource 10542 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,904 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10542)
2012-07-13 10:35:58,905 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 10542
2012-07-13 10:35:58,905 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3376
2012-07-13 10:35:58,906 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,906 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3376,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,916 DEBUG [WebServer] Incoming connection from /192.168.0.32:33912
2012-07-13 10:35:58,916 DEBUG [ResourceTransportRequestHandler] GET /resource/10543/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,917 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,917 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,918 DEBUG [ResourceTransportRequestHandler] Request for resource 10543 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,918 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10543)
2012-07-13 10:35:58,919 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 10543
2012-07-13 10:35:58,920 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3983
2012-07-13 10:35:58,920 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,920 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3983,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,923 DEBUG [WebServer] Incoming connection from /192.168.0.32:33913
2012-07-13 10:35:58,924 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-13 10:35:58,928 DEBUG [WebServer] Incoming connection from /192.168.0.32:33914
2012-07-13 10:35:58,929 DEBUG [ResourceTransportRequestHandler] GET /resource/10693/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,929 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,930 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,930 DEBUG [ResourceTransportRequestHandler] Request for resource 10693 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,930 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10693)
2012-07-13 10:35:58,931 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 10693
2012-07-13 10:35:58,931 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 2997
2012-07-13 10:35:58,932 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,932 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2997,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,941 DEBUG [WebServer] Incoming connection from /192.168.0.32:33915
2012-07-13 10:35:58,942 DEBUG [ResourceTransportRequestHandler] GET /resource/7927/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,942 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,943 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,944 DEBUG [ResourceTransportRequestHandler] Request for resource 7927 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,944 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7927)
2012-07-13 10:35:58,945 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 7927
2012-07-13 10:35:58,945 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8067
2012-07-13 10:35:58,945 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,945 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 8067,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,956 DEBUG [WebServer] Incoming connection from /192.168.0.32:33916
2012-07-13 10:35:58,956 DEBUG [ResourceTransportRequestHandler] GET /resource/11372/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,957 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,958 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,958 DEBUG [ResourceTransportRequestHandler] Request for resource 11372 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,958 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11372)
2012-07-13 10:35:58,959 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 11372
2012-07-13 10:35:58,959 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 2910
2012-07-13 10:35:58,960 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,960 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2910,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,968 DEBUG [WebServer] Incoming connection from /192.168.0.32:33917
2012-07-13 10:35:58,969 DEBUG [ResourceTransportRequestHandler] GET /resource/11373/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:35:58,969 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:35:58,970 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:35:58,970 DEBUG [ResourceTransportRequestHandler] Request for resource 11373 and type 'COVER_IMAGE' received
2012-07-13 10:35:58,971 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11373)
2012-07-13 10:35:58,971 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 11373
2012-07-13 10:35:58,972 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3718
2012-07-13 10:35:58,972 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:35:58,972 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3718,Date: Fri, 13 Jul 2012 08:35:58 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:36:03,385 DEBUG [WebServer] Incoming connection from /192.168.0.32:33918
2012-07-13 10:36:03,386 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.32:
2012-07-13 10:36:03,386 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:03,393 DEBUG [ContentDirectory] Browse() called for renderer UE40ES6570 (profile 7) with parameters: objectID = V_LV^V_3946, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-13 10:36:03,393 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:03,395 DEBUG [SeriesDAOImpl] Reading a Series (id = 58)
2012-07-13 10:36:03,396 DEBUG [GenreDAOImpl] Reading a Genre (id = 8)
2012-07-13 10:36:03,397 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:03,397 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:03,400 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:03,401 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3946 and profile Samsung TV / player (C/D-series)
2012-07-13 10:36:03,401 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10543)
2012-07-13 10:36:03,402 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:03,403 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:03,406 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2012-07-13 10:36:03,419 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-13 10:36:03,561 DEBUG [WebServer] Incoming connection from /192.168.0.32:33919
2012-07-13 10:36:03,562 DEBUG [ResourceTransportRequestHandler] HEAD /resource/3946/MEDIA_ITEM/AVI*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.1:8895]]
2012-07-13 10:36:03,562 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:03,563 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:03,563 DEBUG [ResourceTransportRequestHandler] Request for resource 3946 and type 'MEDIA_ITEM' received
2012-07-13 10:36:03,563 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3946 (local)
2012-07-13 10:36:03,564 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:03,565 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:03,566 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3946, format AVI and profile Samsung TV / player (C/D-series)
2012-07-13 10:36:03,567 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-07-13 10:36:03,567 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-msvideo,Content-Length: 367593472,Date: Fri, 13 Jul 2012 08:36:03 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-07-13 10:36:03,573 DEBUG [WebServer] Incoming connection from /192.168.0.32:33920
2012-07-13 10:36:03,573 DEBUG [ResourceTransportRequestHandler] GET /resource/3946/MEDIA_ITEM/AVI*0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.1:8895]]
2012-07-13 10:36:03,573 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:03,574 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:03,574 DEBUG [ResourceTransportRequestHandler] Request for resource 3946 and type 'MEDIA_ITEM' received
2012-07-13 10:36:03,575 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3946 (local)
2012-07-13 10:36:03,575 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:03,576 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:03,577 DEBUG [VideoDeliveryEngine] Delivering item '3946' for client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:03,577 DEBUG [VideoDeliveryEngine] Delivering file 'Stargate SG-1.S01E03.Emancipation.avi' in native format
2012-07-13 10:36:03,577 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:03,622 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3946) as read
2012-07-13 10:36:03,791 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-07-13 10:36:03,791 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 367593472
2012-07-13 10:36:03,792 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:36:03,792 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 0-367593471/367593472,Content-Length: 367593472,Date: Fri, 13 Jul 2012 08:36:03 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=2652000;]]
2012-07-13 10:36:03,811 DEBUG [WebServer] Incoming connection from /192.168.0.32:33921
2012-07-13 10:36:03,811 DEBUG [ResourceTransportRequestHandler] GET /resource/3946/MEDIA_ITEM/AVI*0 HTTP/1.0, headers = [Range: bytes=366309012-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.1:8895]]
2012-07-13 10:36:03,812 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:03,812 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:03,813 DEBUG [ResourceTransportRequestHandler] Request for resource 3946 and type 'MEDIA_ITEM' received
2012-07-13 10:36:03,813 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3946 (local)
2012-07-13 10:36:03,814 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:03,815 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:03,818 DEBUG [VideoDeliveryEngine] Delivering item '3946' for client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:03,818 DEBUG [VideoDeliveryEngine] Delivering file 'Stargate SG-1.S01E03.Emancipation.avi' in native format
2012-07-13 10:36:03,818 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:03,822 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1284460
2012-07-13 10:36:03,822 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:36:03,822 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 366309012-367593471/367593472,Content-Length: 1284460,Date: Fri, 13 Jul 2012 08:36:03 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-07-13 10:36:03,830 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-07-13 10:36:04,005 DEBUG [WebServer] Incoming connection from /192.168.0.32:33922
2012-07-13 10:36:04,006 DEBUG [ResourceTransportRequestHandler] GET /resource/3946/MEDIA_ITEM/AVI*0 HTTP/1.0, headers = [Range: bytes=10252-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.1:8895]]
2012-07-13 10:36:04,006 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:04,007 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:04,008 DEBUG [ResourceTransportRequestHandler] Request for resource 3946 and type 'MEDIA_ITEM' received
2012-07-13 10:36:04,008 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3946 (local)
2012-07-13 10:36:04,008 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:04,009 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:04,010 DEBUG [VideoDeliveryEngine] Delivering item '3946' for client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:04,010 DEBUG [VideoDeliveryEngine] Delivering file 'Stargate SG-1.S01E03.Emancipation.avi' in native format
2012-07-13 10:36:04,010 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:04,013 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 367583220
2012-07-13 10:36:04,013 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:36:04,014 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 10252-367593471/367593472,Content-Length: 367583220,Date: Fri, 13 Jul 2012 08:36:04 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-07-13 10:36:04,077 DEBUG [WebServer] Incoming connection from /192.168.0.32:57132
2012-07-13 10:36:04,078 DEBUG [ResourceTransportRequestHandler] HEAD /resource/3946/MEDIA_ITEM/AVI*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-07-13 10:36:04,078 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:36:04,079 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:36:04,082 DEBUG [ResourceTransportRequestHandler] Request for resource 3946 and type 'MEDIA_ITEM' received
2012-07-13 10:36:04,082 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3946 (local)
2012-07-13 10:36:04,082 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:04,083 DEBUG [VideoDAOImpl] Reading a Video (id = 3946)
2012-07-13 10:36:04,085 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3946, format AVI and profile Samsung TV / player (C/D-series)
2012-07-13 10:36:04,085 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3946)
2012-07-13 10:36:04,086 DEBUG [MediaItemDAOImpl] Getting file of media item 3946
2012-07-13 10:36:04,088 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-07-13 10:36:04,089 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-msvideo,Content-Length: 367593472,Date: Fri, 13 Jul 2012 08:36:04 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-07-13 10:36:38,736 INFO [UpdateChecker] Checking if a new version is available
2012-07-13 10:36:42,288 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-13 10:36:42,290 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:36:42,523 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-07-13 10:36:42,850 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-07-13 10:36:42,955 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-07-13 10:36:45,341 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-13 10:36:45,342 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:36:47,309 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:36:47,309 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:36:56,803 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.33:58227
2012-07-13 10:36:56,803 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.33:58227
2012-07-13 10:36:56,804 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.33:58227
2012-07-13 10:36:56,805 DEBUG [WebServer] I/O error: Connection reset
2012-07-13 10:36:56,806 DEBUG [WebServer] Incoming connection from /192.168.0.33:52938
2012-07-13 10:36:56,810 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa from 192.168.0.33 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.1:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2012-07-13 10:36:56,810 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2012-07-13 10:36:56,811 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.1:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2012-07-13 10:36:56,814 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.33
2012-07-13 10:36:56,817 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-07-13 10:36:56,846 DEBUG [WebServer] Incoming connection from /192.168.0.33:52940
2012-07-13 10:36:56,846 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-13 10:37:47,314 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:37:47,314 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:38:05,847 DEBUG [WebServer] I/O error: Connection reset
2012-07-13 10:38:47,327 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:38:47,327 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:39:47,340 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:39:47,340 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-13 10:40:14,469 DEBUG [WebServer] Incoming connection from /192.168.0.32:56572
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] GET /resource/10543/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.0.1:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-13 10:40:14,469 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.32
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.32, Profile=Samsung TV / player (C/D-series)'
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] Request for resource 10543 and type 'COVER_IMAGE' received
2012-07-13 10:40:14,469 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10543)
2012-07-13 10:40:14,469 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 10543
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 3983
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-13 10:40:14,469 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3983,Date: Fri, 13 Jul 2012 08:40:14 GMT,Server: Windows Server 2008 R2, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-13 10:40:14,547 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:06
2012-07-13 10:40:15,516 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-07-13 10:40:47,341 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-13 10:40:47,341 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
retro
Post Sat Jul 14, 2012 12:48 pm
If it helps i could do a pcap recording of the
Playing on the e and d Series, or whatever
u need!
Nice Regards,
Retro
retro
Post Mon Jul 16, 2012 10:20 am
Hi again,
i dont know if this gets deleted, and i like serviio very much, but no response, so i tried ps3mediaserver again and voila, it works with the E Series. The PS3Mediasserver is not that comfortable then serviio, but first
it works ! and secound if u have a really bit library like a few K files, serviio gets slow, ps3mediaserver does not because it implements only file browsing.
Maybe u can take a look at ps3mediaserver, its under the gpl, to get an idea whats wrong with serviio and Samsung E Series.
Nice Regards,
Retro
Post Tue Jul 17, 2012 1:38 pm
Thanks, might catch something in the log. Will investigate, in the meantime enjoy streaming with PS3MS.
retro
Post Tue Jul 17, 2012 5:42 pm
i would enjoy using serviio again, so if i can help (im a developer and can do debugging or capture streams) plz tell me and i will assist.
Nice Regards,
Retro
Post Tue Jul 17, 2012 8:55 pm
the log above is not colmplete right? I'm looking for
[DiscoveryAdvertisementNotifier] Will advertise again in <time>
and whether it really happens (it should send 6 ssdp messages to each NIC after the specified time)
