Problems with server on ubuntu 11.10, webui client
slegdon
Post Tue Jul 17, 2012 10:48 pm
OK, so I've searched the forums, FAQ and wiki for a resolution to this problem, but haven't found anything that describes exactly the same symptoms as I'm having.
I've installed the server on ubuntu 11.10, and set it up to run via upstart, following some instructions that I have now lost... The server starts fine, and renderers on my network can see it (I Can see connections from my Sony TV in the logs, and Serviio pops up in the TV's menus).
I installed WebUI on the same host and set that up to start with upstart too. It also starts up and can bee seen in the log. However, as soon as I hit http://host:8123/serviio/console in a browser, I get a string of errors like this in the log:
2012-07-16 00:21:39,766 ERROR [RefDataCache] Error getting cpu-cores
2012-07-16 00:21:39,770 ERROR [RefDataCache] Ressource
Internal Connector Error (1002) - Connection refused
at org.restlet.resource.ClientResource.handle(ClientResource.java:861)
at org.restlet.resource.ClientResource.handle(ClientResource.java:883)
at org.restlet.resource.ClientResource.handle(ClientResource.java:798)
at org.restlet.resource.ClientResource.get(ClientResource.java:541)
at org.serviio.restui.fast.RefDataCache.getData(Unknown Source)
at org.serviio.restui.fast.RefDataCache.getAll(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
at org.restlet.resource.ServerResource.get(ServerResource.java:645)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
at org.restlet.resource.Finder.handle(Finder.java:510)
at org.restlet.routing.Filter.doHandle(Filter.java:156)
at org.restlet.routing.Filter.handle(Filter.java:203)
at org.restlet.routing.Router.doHandle(Router.java:497)
at org.restlet.routing.Router.handle(Router.java:737)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
at org.restlet.Application.handle(Application.java:388)
at org.restlet.Component.handle(Component.java:388)
at org.restlet.Server.handle(Server.java:488)
at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
where the first line is different for each.
I have -Dserviio.remoteHost set to the ubuntu server's IP address in serviio.sh and serviio-webui.sh.
I have tried changing /etc/hosts to eliminate the loopback address, but this doesn't help.
I have verified that conf and logs directories have sane permissions.
I have reconfigured where the Derby database is stored, to somewhere outside of /usr with wide open permissions, just in case it was that.
The host has no firewall rules configured.
I've also tried setting up the console on a remore windows box, but that wouldn't start either.
The ubuntu server is headless, so I can't install the standard console on it.
Undoubtedly, I've done something wrong, but I can't spot it. Does anyone have any ideas?
S
slegdon
Post Thu Jul 19, 2012 6:43 pm
Re: Problems with server on ubuntu 11.10, webui client
Ok. I have more info.
I find that I can access Serviio's rest api without issues from a browser on another machine, but if I try the same from the Ubuntu server using wget it hangs and has to be killed (Ctrl C). Once I do this, the correct data looks like it's been written to wget's output file.
Does this give anyone a clue?
slegdon
Post Thu Jul 19, 2012 6:49 pm
And I'm running on Sun java 1.6.0_26 64 bit
Users browsing this forum: No registered users and 114 guests
